Hi all!
Quick question, haven't been able to find the answer. Roughly how many GA piston Lycomings have been built? Within a few hundred thousand, at least, but the number doesn't have to be exact. I'd like to compare how many were made versus how many wankel rotary engines, just as a data point. Thanks! Ben Hallert PP-ASEL - http://hallert.net/cozy/ |
Way, way too many.
Ben Hallert wrote:
Ben.. I dont have an answer to your question, but I always keep an eye out for the rotary minded. I looked at your webpage.. saw what youve got there, and some of the rationalizations that you've listed there. Glad to have you in the ranks of builders now.. (well.. almost builder... you've placed the order for parts). If you are serious about the rotary, I would recommend the Rotary Engine Listserv, hosted by Marvin Kaye on his LancairOnline website. This is a fairly active listserv that has group discussion and data points from around the world regarding the rotary engine in aircraft. We have folks with mazda auto backgrounds, racing background and most importantly folks with stick time behind and in front of Mazda/Rotary engines in aircraft. I didn't see your name there as a poster, so I am making the assumption you are unaware of it (sorry if its in error). The websites: Homepage: http://www.flyrotary.com/ Archive: http://lancaironline.net/lists/flyrotary/List.html I see how you've found Tracy Crook's website, as well as the Cozy Grrrls site. Good starting points... Have you checked out John Slades site (he's actually FLYING a cozy with a rotary, and has completed his flight test.. he has had a real rough go at making things work and is now enjoying excellent success and performance)? The website for him is http://www.canardaviation.com/ No offense intended towards John Matcho and the Canard Zone, but there is another forum that is hosted by John Slade and a few others called the Canard Aviation Forum (you can get to it from the above address). The traffic there is much more involved and frequent than at the zone in my opinion. Nothing wrong with belonging to both.. as I do. Regarding some of the content on your page: I would ask that you keep an open mind about the in-flight adjustable pitch props. In the 3-5 years it will take you to be close to first flight and needing to make that purchase, perhaps there will be more data. I do know that the certified planes I've flown with CS props, I like the performance that they give me, both on climb AND descent. Given that you the Cozy (and other canards) tend to land and take off at faster speeds (due to no flaps and the canard having a higher AOA), anything that helps you accelerate faster gets you off the ground sooner. A CS or adjustable pitch prop can help get you in and out of places that you otherwise would be unable or barely able to use. Enjoy the build, hope to see you on those other outlets.. Dave |
Hi Dave,
Thanks for the reply! I joined the flyrotary list a few days ago, I just haven't introduced myself yet. I tend to lurk and read as much as possible, but I imagine I'll pipe up when it's time to lay out some cash for the engine. I've read John Slades website with much interest, and have pored over his install and test experiences. Unless there's a big shift between now and the end of my build, I'm guessing the design of the scoop/cooling system will be my biggest hurdle, but heck, they're not experimental aircraft for nothing, right? ![]() I've definately got an open mind on the adjustable props. I too am very interested in the shortened takeoff (The Cozy is usually quoted as having a 1,500 foot takeoff and landing roll because it's a pusher), and the more I think about it, the more I want that CS prop. The main reason I'm shying away from it at the moment is that I'm concerned about the added complexity (I've already got an experimental airframe AND engine) and I've heard some things about Ivo props that makes me want to do more research before spending money, but time will tell. I changed that item to be a little less set in stone, and I will keep an eye on it. Best regards, Ben Hallert http://hallert.net/cozy/ |
![]() Ben Hallert wrote: Hi all! Quick question, haven't been able to find the answer. Roughly how many GA piston Lycomings have been built? Within a few hundred thousand, at least, ..... Odd Q to ask on a newsgroup. From Lycoming's own website: "...The company has built more than 325,000 piston aircraft engines and powers more than half the world's general aviation fleet..." Daniel |
Ben Hallert wrote:
Hi Dave, (SNIP) The main reason I'm shying away from it at the moment is that I'm concerned about the added complexity (I've already got an experimental airframe AND engine) and I've heard some things about Ivo props that makes me want to do more research before spending money, but time will tell. I changed that item to be a little less set in stone, and I will keep an eye on it. Not a problem... I've heard a few things too that made us question that decision on several levels, but for the powerplant we are using, and in the configuration we are using, it seems like a win/win. We (the community) should have some good data in one direction or the other within the few years it will take you to build. Dave |
Excellent! Thanks, I must have searched for just not quite the right
terms. It does sound a bit odd, but I'm just collecting data I can use as part of my engine selection criteria. It's not the whole story, or even most of it, but it's a little piece of info that might be useful in the right context. Thanks! Ben Hallert http://hallert.net/cozy/ |
Custom Built Model of your Aircraft | customairmodels | Aviation Marketplace | 2 | November 10th 05 09:56 AM |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Lycoming's views on best economy settings | [email protected] | Piloting | 37 | July 8th 04 04:00 PM |
YO-3A QUIET STAR built by lockheed | KURT OLNEY | Military Aviation | 0 | January 19th 04 07:01 AM |
Low flying over built up areas | Martin Evans | General Aviation | 9 | October 8th 03 08:25 AM |
