Why didn't the Cessna 337 make it?
Old February 28th 06, 08:56 PM posted to rec.aviation.piloting
Default Why didn't the Cessna 337 make it?
"Dylan Smith" wrote in message
The people who are liable to VMC roll a conventional twin are probably
the same people who will stall a 337 while taking their time over trying
to figure out which engine has quit.
I don't see how this is an issue. With centerline thrust, the pilot
shouldn't NEED to know which engine has quit. The primary reason for
knowing which engine has quit in a convential twin is so you can use the
correct control inputs. With centerline thrust, you just keep flying the
airplane. Why would any pilot spend any time trying to figure out which
engine has quit on a 337? What are they going to do with that information,
at least in the immediate sense?
Pete
  #52
Old February 28th 06, 09:00 PM posted to rec.aviation.piloting
I have been thinking that it would be cool to refit an old 337 with
twin jet engines mounted in place of the rear engine with snorkles for
the intakes and a nose extension fairing in place of the front engine
for drag reduction and CG adjustment. Given the advances in small jet
engines in recent years, this might be feasible. Imagine the rate of
climb you would get. You could run the throttles at a modest setting
for cruise.
There is an experimental aircraft for you!
Dean
Dallas wrote:
Looking at the design of the C377, it seems like it should have been more of
a winner. Why did it flop?
Dallas
  #53
Old February 28th 06, 09:09 PM posted to rec.aviation.piloting
wrote)
I have been thinking that it would be cool to refit an old 337 with twin
jet engines mounted in place of the rear engine with snorkles for the
intakes and a nose extension fairing in place of the front engine for drag
reduction and CG adjustment. Given the advances in small jet engines in
recent years, this might be feasible. Imagine the rate of climb you would
get. You could run the throttles at a modest setting for cruise.
I'm waiting to see the real world numbers for the HondaJet - Plane and/or
engine.
Engine guys at Oshkosh said Honda was considering selling just the power
plant to others.
Montblack
  #54
Old February 28th 06, 09:10 PM posted to rec.aviation.piloting
Perhaps there is a need to feather the prop on the dead engine to cut drag?
  #55
Old February 28th 06, 09:12 PM posted to rec.aviation.piloting
snip
Actually, you would be implementing / developing an STC, not building a new
experimental aircraft... The rules are a bit stricter for that...
  #56
Old February 28th 06, 09:22 PM posted to rec.aviation.piloting
You need to know hoe to identify the dead engine and feather
the correct prop, otherwise you're going down. In a
conventional twin identification is holding heading with
rudder, "dead foot dead engine" and the litany is
CONTROL
POWER (up)
DRAG (gear and flaps)
IDENTIFY
VERIFY
FEATHER
FLY
secure it
In the 336/337 it isn't as easy or obvious which engine is
sick or dead.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
message ...
twin are probably
time over trying
the pilot
reason for
you can use the
keep flying the
figure out which
that information,
| Pete
  #57
Old February 28th 06, 09:25 PM posted to rec.aviation.piloting
Knowing how flimsily Cessna tends to make their designs,
using the thinnest possible metals, etc, a re-engine job is
critical. Airplanes have speed and power limits, both for
structural strength and aerodynamics...the 337 is pretty
well at that point as sold by Cessna.
337 with
snorkles for
front engine
in small jet
the rate of
modest setting
| for cruise.
| Dean
| Dallas
  #58
Old February 28th 06, 09:30 PM posted to rec.aviation.piloting
"Grumman-581" wrote in message
drag?
Ahh...good point, thanks.
  #59
Old February 28th 06, 09:31 PM posted to rec.aviation.piloting
The Eclipse 500 will sell for about what a new Beech 58G
Baron will sell for, as soon as I win the lottery, I'll make
my deposit.
James H. Macklin
ATP,CFI,A&P
some support
"Montblack" wrote in
message ...
| wrote)
old 337 with twin
snorkles for the
jet engines in
of climb you would
cruise.
| engine.
just the power
| plant to others.
| Montblack
  #60
Old February 28th 06, 09:37 PM posted to rec.aviation.piloting
Hi Jim,
That is true, but if the jet engines were small enough they wouldn't
necessarily overpower the airframe. There are some really small
turbines out these days...
Dean
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
