Why didn't the Cessna 337 make it?
Old February 27th 06, 11:51 PM posted to rec.aviation.piloting
Default Why didn't the Cessna 337 make it?
Looking at the design of the C377, it seems like it should have been more of
a winner. Why did it flop?
Dallas
Old February 27th 06, 11:56 PM posted to rec.aviation.piloting
It made a poor multi trainer for FBOs because the FAA would not issue
"full" multiengine ratings to students who took their checkrides in it.
-Robert
Old February 28th 06, 12:27 AM posted to rec.aviation.piloting
Just what did the FAA issue then?
Old February 28th 06, 12:45 AM posted to rec.aviation.piloting
A multi-engine rating limited to centerline thrust.
Old February 28th 06, 12:31 AM posted to rec.aviation.piloting
A 'centerline only' thrust limitation to the ME rating.
Old February 28th 06, 03:54 AM posted to rec.aviation.piloting
Not only that, but if you have a regular multiengine rating, you still
can't fly the thing unless you get a type rating (or somesuch) for it.
Jose
Money: what you need when you run out of brains.
Old February 28th 06, 04:01 AM posted to rec.aviation.piloting
Not true I think.
If you had a multi-engine rating, a normal checkout was FAA approved if I
remember correctly. I don't believe the center line thrust rating was
mandatory above the regular multi if already held.
Dudley Henriques
"Jose" wrote in message
. com...
Jose
Old February 28th 06, 06:53 AM posted to rec.aviation.piloting
. com...
Not true.
Old February 28th 06, 02:22 PM posted to rec.aviation.piloting
Jose
"Centerline thrust only" is a limitation, not a priveledge.
The 336, 337 and 0-2 did not require a type rating.
Dave
Old February 28th 06, 02:24 PM posted to rec.aviation.piloting
Not correct, at least in the USA. There are some jets that
don't have a Vmca as such because the engines are so close
to the centerline and although they have two engines, they
don't meet the FAA requirement for issuing an unrestricted
multiengine certificate. If you obtain your multiengine
certificate in such an airplane you are issued a multiengine
rating with the centerline thrust limitation. But as it is
a turbojet/12.5 gw, a type rating is required also.
The Cessna 337 is lighter than the weight floor for
requiring a type rating and it is not a turbojet.
James H. Macklin
ATP,CFI,A&P
some support
. com...
rating, you still
somesuch) for it.
| Jose
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
