#51
"Dylan Smith" wrote in message
... [...] The people who are liable to VMC roll a conventional twin are probably the same people who will stall a 337 while taking their time over trying to figure out which engine has quit. I don't see how this is an issue. With centerline thrust, the pilot shouldn't NEED to know which engine has quit. The primary reason for knowing which engine has quit in a convential twin is so you can use the correct control inputs. With centerline thrust, you just keep flying the airplane. Why would any pilot spend any time trying to figure out which engine has quit on a 337? What are they going to do with that information, at least in the immediate sense? Pete |
#52
I have been thinking that it would be cool to refit an old 337 with
twin jet engines mounted in place of the rear engine with snorkles for the intakes and a nose extension fairing in place of the front engine for drag reduction and CG adjustment. Given the advances in small jet engines in recent years, this might be feasible. Imagine the rate of climb you would get. You could run the throttles at a modest setting for cruise. There is an experimental aircraft for you! Dean Dallas wrote: Looking at the design of the C377, it seems like it should have been more of a winner. Why did it flop? Dallas |
#53
wrote)
I have been thinking that it would be cool to refit an old 337 with twin jet engines mounted in place of the rear engine with snorkles for the intakes and a nose extension fairing in place of the front engine for drag reduction and CG adjustment. Given the advances in small jet engines in recent years, this might be feasible. Imagine the rate of climb you would get. You could run the throttles at a modest setting for cruise. I'm waiting to see the real world numbers for the HondaJet - Plane and/or engine. Engine guys at Oshkosh said Honda was considering selling just the power plant to others. Montblack |
#54
... I don't see how this is an issue. With centerline thrust, the pilot shouldn't NEED to know which engine has quit. Perhaps there is a need to feather the prop on the dead engine to cut drag? |
#55
oups.com... I have been thinking that it would be cool to refit an old 337 with twin jet engines mounted in place of the rear engine with snorkles for the intakes and a nose extension fairing in place of the front engine for drag reduction and CG adjustment. snip There is an experimental aircraft for you! Actually, you would be implementing / developing an STC, not building a new experimental aircraft... The rules are a bit stricter for that... |
#56
You need to know hoe to identify the dead engine and feather
the correct prop, otherwise you're going down. In a conventional twin identification is holding heading with rudder, "dead foot dead engine" and the litany is CONTROL POWER (up) DRAG (gear and flaps) IDENTIFY VERIFY FEATHER FLY secure it In the 336/337 it isn't as easy or obvious which engine is sick or dead. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Peter Duniho" wrote in message ... | "Dylan Smith" wrote in message | ... | [...] | The people who are liable to VMC roll a conventional twin are probably | the same people who will stall a 337 while taking their time over trying | to figure out which engine has quit. | | I don't see how this is an issue. With centerline thrust, the pilot | shouldn't NEED to know which engine has quit. The primary reason for | knowing which engine has quit in a convential twin is so you can use the | correct control inputs. With centerline thrust, you just keep flying the | airplane. Why would any pilot spend any time trying to figure out which | engine has quit on a 337? What are they going to do with that information, | at least in the immediate sense? | | Pete | | |
#57
Knowing how flimsily Cessna tends to make their designs,
using the thinnest possible metals, etc, a re-engine job is critical. Airplanes have speed and power limits, both for structural strength and aerodynamics...the 337 is pretty well at that point as sold by Cessna. wrote in message oups.com... |I have been thinking that it would be cool to refit an old 337 with | twin jet engines mounted in place of the rear engine with snorkles for | the intakes and a nose extension fairing in place of the front engine | for drag reduction and CG adjustment. Given the advances in small jet | engines in recent years, this might be feasible. Imagine the rate of | climb you would get. You could run the throttles at a modest setting | for cruise. | | There is an experimental aircraft for you! | | Dean | | Dallas wrote: | Looking at the design of the C377, it seems like it should have been more of | a winner. Why did it flop? | | | Dallas | |
#58
"Grumman-581" wrote in message
... Perhaps there is a need to feather the prop on the dead engine to cut drag? Ahh...good point, thanks. |
#59
The Eclipse 500 will sell for about what a new Beech 58G
Baron will sell for, as soon as I win the lottery, I'll make my deposit. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Montblack" wrote in message ... | wrote) | I have been thinking that it would be cool to refit an old 337 with twin | jet engines mounted in place of the rear engine with snorkles for the | intakes and a nose extension fairing in place of the front engine for drag | reduction and CG adjustment. Given the advances in small jet engines in | recent years, this might be feasible. Imagine the rate of climb you would | get. You could run the throttles at a modest setting for cruise. | | | I'm waiting to see the real world numbers for the HondaJet - Plane and/or | engine. | | Engine guys at Oshkosh said Honda was considering selling just the power | plant to others. | | | Montblack | |
#60
Hi Jim,
That is true, but if the jet engines were small enough they wouldn't necessarily overpower the airframe. There are some really small turbines out these days... Dean |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
