Why didn't the Cessna 337 make it?
Old March 5th 06, 07:57 PM posted to rec.aviation.piloting
Default Why didn't the Cessna 337 make it?
Matt Whiting wrote
Are these mainly the bizjets?
And F-4s, F-14s, F-18s and the like.
Bob Moore
  #83
Old March 12th 06, 10:41 PM posted to rec.aviation.piloting
On Sun, 05 Mar 2006 19:57:58 GMT, Bob Moore
Yes, my brother in law has a multi rating with centerline
restriction... ex-USAF (F-15 etc.); he now instructs people with a lot
more money than I have in L-39's.
-Dana
If replying by email, please make the obvious changes.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson
  #84
Old June 2nd 06, 06:29 PM posted to rec.aviation.piloting
On Fri, 03 Mar 2006 21:52:09 -0600, Big John
James
Never heard of leading with rear engine to make sure it was running.
That procedure was to get you moving so the front prop wouldn't pick
up rocks and throw into rear prop. We used to carry a little *******
Doesn't everybody?
file (6 inches) and on pre flight if found a nick in prop leading edge
Errrr...Ahhhh...wait... that was a pooly selected insertion spot and
could lead one to the wrong interpetation.
But only a 6" file? They must have been little nicks. :-))
www.rogerhalstead.com
we ran file along edge to take nick out.
Big John
On Mon, 27 Feb 2006 21:43:08 -0600, "Jim Macklin"
But it happened several times. The fix was to issue a POH
change to require all take-offs lead with the rear throttle.
James H. Macklin
ATP,CFI,A&P
  #85
Old June 2nd 06, 06:37 PM posted to rec.aviation.piloting
On Sat, 4 Mar 2006 22:41:04 -0600, "Jim Macklin"
Sounds underpowered, cheap and make-shift. I wonder why
they sold/bought so many of them?
In "our world" where people don't shoot at you, at least not very
often, it was big, roomy, and you did have a second engine without the
problems of asymmetrical thrust on an engine failure.
OTOH As I recall it was not all that fast, used a lot of gas, and as
John said, noisy and not well ventilated
If you wanted to really use gas you could get the turbo charged
version. I don't know how many of those they sold.
We had one (turbo charged version) here on the field about 10 years
ago. The guy said he'd always wanted one, but only kept it about a
year. It was eating him out of house and home for gas and maintenance.
I don't know if it was due to that specific plane or it was a trait of
the breed.
"Big John" wrote in message
| Jim
| Just a few of the things.
| Bought to use on trail. However if you lost an engine over
the trail
| the single engine altitude way they were loaded prevented
you from
| getting over the mountains and back to VN to land.
| At cruise power, when FACing, you could turn about 270
degree's and
| then got the stall warning and had to go to METO power to
stay
| airborne and FAC.
| In 0-1 you could drop a wing and kick rudder and be on
target to fire
| a Willie Pete marking rocket. In 0-2 you had to fly a
coordinated turn
| from a base leg to the launch heading and then coordinate
corrections
| to get pipper on target.
| In 0-1 you lost about 150 altitude and didn't pick up any
airspeed to
| speak of. In 0-2 you picked up a lot of airspeed and lost
a lot of
| altitude and had to pull a high 'G' recovery. Doing this
all day tired
| you out in heat and also put you closer to any ground fire
from target
| area.
| Bird had 'X' number of feet of ground roll on take off.
You couldn't
| pull off and stagger into the air in a short field.
| If you landed on Laderite (sp)you almost always got rear
prop damage
| from front prop picking up rock, gravel, Msc and it
hitting the rear
| prop and causing damage.
| Cockpit was pretty air tight and hot at low altitude (FAC
altitude) in
| heat and moisture. No way to keep cool like you could in
the 0-1 with
| the windows open. And more and more and
more...............
| Big John
| On Fri, 3 Mar 2006 21:57:17 -0600, "Jim Macklin"
| wrote:
| I know they bought a lot of them, but it seems from your
| tone, that you know first-hand. Tell us all.
| | Jim
| | Not so. Be glad to tell you the limitations of 0-2 in
VN.
| | Big John
| | On Mon, 27 Feb 2006 20:18:12 -0600, "Jim Macklin"
| | wrote:
| | It was not a safer twin since the failure of an engine
| was
| | not as quickly detected since there was no yaw, just
| reduced
| | performance. It did not have good baggage areas and
it
| was
| | noisy inside.
| | It was successful as a FAC aircraft in VN as the O-2
| | "Dudley Henriques" wrote in
| | message
link.net...
| | | "john smith" wrote in message
| | | Looking at the design of the C377, it seems
like
| it
| | should have been
| | | more
| | | of a winner. Why did it flop?
| | | My old CFI said guys would forget to start the
back
| | engine or not notice
| | | that it would quit and end up crashing, true or
not
| I
| | don't know but it
| | | was
| | | his story. I always thought it was an odd looking
| | piece.
| | | To that I would add that I personally think the
200
| hp
| | O-360's are not
| | | enough power for the size and weight of the
aircraft.
| | | Maintenance wise, we had a cracked case on one of
| | engines that was a bit
| | | costly to fix :-) and you had to monitor the EGT
| | carefully on takeoff
| | | because the noise was so bad you couldn't pick up an
| | engine problem during
| | | the run, but aside from that, fun to fly!
| | | Dudley Henriques
  #86
Old June 2nd 06, 10:44 PM posted to rec.aviation.piloting
It is in the manual to use the rear engine first, to be sure
it is still running, I seem to remember it was a SB after
some accidents.
As to carrying a 6 inch file to dress prop nicks, that is
allowed ONLY for A&P [P actually] and requires a logbook
endorsement. There are strict allowances for the depth and
position of a nick that can be dressed and the nick must be
properly blended so there are no stress-risers.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Roger" wrote in message
| wrote:
| James
was running.
wouldn't pick
little *******
| Doesn't everybody?
leading edge
insertion spot and
| Big John
POH
throttle.
| James H. Macklin
| ATP,CFI,A&P
  #87
Old June 2nd 06, 10:47 PM posted to rec.aviation.piloting
Actually I [Jim Macklin] did not say it was cheap,
under-powered and make-shift.
Cessna even tried to put it on floats but it ate props with
water spray.
James H. Macklin
ATP,CFI,A&P
some support
not very
without the
gas, and as
charged
10 years
it about a
maintenance.
was a trait of
| the breed.
| | Jim
over
| the trail
prevented
| you from
| degree's and
to
| stay
| | airborne and FAC.
| target to fire
| coordinated turn
coordinate
| corrections
any
| airspeed to
lost
| a lot of
this
| all day tired
fire
| from target
| | area.
| You couldn't
rear
| prop damage
| hitting the rear
(FAC
| altitude) in
in
| the 0-1 with
| more...............
| | Big John
your
| | | Jim
in
| VN.
| | | Big John
engine
| | was
just
| | reduced
and
| it
| | was
| | | noisy inside.
O-2
in
| | | message
link.net...
| like
| | it
| | | should have been
| | | | more
| back
or
| not
| | I
| | | don't know but it
| | | | was
looking
| | | piece.
| 200
| | hp
| | | O-360's are not
| aircraft.
| the
an
| | | | Dudley Henriques
  #88
Old June 4th 06, 04:43 AM posted to rec.aviation.piloting
the breed.
Not just turbocharged... pressurized AND turbocharged!
  #89
Old June 4th 06, 04:44 AM posted to rec.aviation.piloting
In article em2gg.25301$ZW3.22928@dukeread04,
water spray.
Wadn't that the 336?
  #90
Old June 4th 06, 05:50 AM posted to rec.aviation.piloting
Probably, basically the same airplane with fixed gear.
Cessna did their seaplane testing at Grand Lake, in north
east Oklahoma. A pilot named George "Mally" Malischii [sp]
who also was a seaplane instructor for Spartan and a DPE.
some support
| "Jim Macklin"
with
| water spray.
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
