#21
Ethanol isn't currently a solution to anything other than
Archer-Daniels-Midland. It's not a viable source of energy (current production techniques use as much oil to grow and process the ethanol than the oil it would replace in the market). Further, the use of it as an oxygenate in reformulated fuels is suspect as well. While this is undoubtedly true, it's sadly irrelevant. The politicians -- not the scientists, or even the economists -- have made the decision to go ahead with ethanol, and we're going to be stuck with it. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() wrote in message ups.com... Most new cars sold today in Brazil are fuel flexible. This is made posible with electronic fuel injection systems. Ethanol today is 1/2" price of gasoline and 1/3 of Avgas in Brazil. Cars run on Ethanol have consums more than cars run on gasoline. Many new cars sold today in AMERICA are fuel flexible. Here is a list for 2006. http://www.eere.energy.gov/cleanciti...fv/models.html |
![]() "Icebound" wrote in message ... Many new cars sold today in AMERICA are fuel flexible. Here is a list for 2006. http://www.eere.energy.gov/cleanciti...fv/models.html Sorry... wrong link.. Here is the correct one: http://www.eere.energy.gov/afdc/pdfs/my2006_afv_atv.pdf |
#24
On 6 Mar 2006 22:13:26 -0800, "M" wrote:
True. Not only the range will be less gallon for gallon, it'll be less pound for pound as well, because ethanol has lower specific energy content by weight as well compared with gasoline. However, a spark ignited engine specifically designed for burning ethanol can be lighter because the lower CHT, which reduces the need of cylinder cooling, which in term allows a cowling design that has smaller cooling drag. Cooling drag is one of the biggest drag components in total drag. I don't know the answer, but it's possible an airframe and engine combination specifically designed for ethanol fuel might be just as just as good in terms of performance and range, compared with today's gasoline powered piston planes. The energy in a gallon of Ethanol is considerably less than a gallon of gas. E85 which is 85% Ethanol and 15% gas requires about 25 to 30% more fuel flow to produce the same energy as straight gas. Straight Ethanol contains only 66% the energy of gas which means you'd need to carry 54% more for the same energy output. So, although it's lighter it takes a whole lot more. Taken in perspective, to get the range I get with 100 gallons I'd need 154 gallons. That is 4 gallons more than both my mains hold. Looking in to the long term future, the day will come when airline industry sees the need to invest in alternative and renewable fuel for Quite likely but part of that is going to be due to higher prices for fuel. The break even point (which is an ever moving target) is around $3.50 a gallon. Once we reach that point renewable fuels become economically viable. Just briefly Alcohol futures hit higher than crude last summer, but in general Ethanol is more expensive than gas, particularly when the subsidies are taken into consideration. Plus the generation of Alcohol is not all that efficient. It depends on which study you read, but the return is between 1.35 and 1.56 gallons energy wise (give or take a few hundredths). That means you get back between 1.35 and 1.56 gallons for every gallon of fuel used to produce the stuff. To produce that much Alcohol would take over 400,000,000 acres of corn. We currently have about 80,000,000 in production nation wide. However even 1.56 is not considered sufficient to make the fuel a viable source long term. It really needs to be on the order of 2:1 or two gallons out for every gallon in. http://en.wikipedia.org/wiki/Ethanol..._United_States the sole reason of economy. When that happens we'll probably see ethanol powered jet engines. Hopefully there will still be private Peanut oil, or some other high energy (BTU) source. Alcohol just doesn't have the BTUs First, from the national security approach, or dependence on foreign oil, we only need to increase the national average mileage by about 7 MPG to eliminate the need for importing crude to use as auto fuel. It's currently very close to 21 MPG average. It hit about 22 MPG about 8 or 10 years back before trucks started outselling cars. It'd only take about 15% going to hybrid cars to do this. piston flying in this country and we'll start to see clean sheet design piston engine and airframe based on a new fuel. Maybe instead of ethanol, we'll have diesel engine burning corn oil :-) and Jet engines. However we run the very serious risk of running into the same problems as Brazil where they use sugar cane as an efficient source of Ethanol. http://en.wikipedia.org/wiki/Ethanol...l_implications They diverted so much land into the production of sugar cane for fuel that they lost a lot of biodiversity which led to sharply higher food prices and crime due to unemployment. Kyle Boatright wrote: A couple of things about Ethanol: 1) It has higher octane than avgas. 2) It has lower specific energy content. That means you can raise the compression ratio, but gallon for gallon, your range will be less. My wife is currently driving a hybrid that uses 13:1 in the gas engine which is probably made possible by the use of variable cam timing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com KB |
#25
On Tue, 07 Mar 2006 19:17:45 -0500, Ron Natalie
wrote: Jay Honeck wrote: Jim Weir, you out there? Have you done any barn yard experimenting with ethanol in your 182? Ethanol isn't currently a solution to anything other than Archer-Daniels-Midland. It's not a viable source of energy (current production techniques use as much oil to grow and process the http://en.wikipedia.org/wiki/Ethanol...energy_balance Latest studies show it to have improved a bit, but still not enough to make it viable. One unit of oil used in the crude to gas process yields one order of magnitude more fuel than it does Alcohol. The current yields are supposedly some where between 1.35 and 1.56 gallons out for each gallon in. ethanol than the oil it would replace in the market). Further, the use of it as an oxygenate in reformulated fuels is suspect as well. Designing a gasoline vehicle to be fuel-flexible isn't hard. Retrofitting one isn't impossible (but may be more trouble than it's worth). I still think the interim fix is the hybrid with economically viable renewable fuels a ways down the road. Of course the economically viable also depends on the price of gas hitting as staying around $3.50 a gallon. We also have to remember that the current price of Alcohol is as low as it is due to some pretty large subsidies. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#26
On 7 Mar 2006 17:43:06 -0800, wrote:
Most new cars sold today in Brazil are fuel flexible. This is made posible with electronic fuel injection systems. Ethanol today is 1/2" price of gasoline and 1/3 of Avgas in Brazil. Cars run on Ethanol have consums more than cars run on gasoline. And the cost according to studies is: http://en.wikipedia.org/wiki/Ethanol...l_implications Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#27
On Wed, 08 Mar 2006 15:06:33 GMT, "Jay Honeck"
wrote: Ethanol isn't currently a solution to anything other than Archer-Daniels-Midland. It's not a viable source of energy (current production techniques use as much oil to grow and process the ethanol than the oil it would replace in the market). Further, the use of it as an oxygenate in reformulated fuels is suspect as well. While this is undoubtedly true, it's sadly irrelevant. The politicians -- not the scientists, or even the economists -- have made the decision to go ahead with ethanol, and we're going to be stuck with it. The thing is, at present yields we can not come near producing enough to make it competitive. We'd need about 5 to 6 times the acreage in corn than we have at present just to feed our cars. If you do the math that doesn't leave much of anything for growing food. Here the true cost of Alcohol is about $3.50 a gallon, but with the massive subsidies throughout the chain the consumer can only see about $2.50 to $3.00 a gallon. http://en.wikipedia.org/wiki/Ethanol...l_implications Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#28
![]() "Roger" wrote in message ... The thing is, at present yields we can not come near producing enough to make it competitive. We'd need about 5 to 6 times the acreage in corn than we have at present just to feed our cars. If you do the math that doesn't leave much of anything for growing food. Here the true cost of Alcohol is about $3.50 a gallon, but with the massive subsidies throughout the chain the consumer can only see about $2.50 to $3.00 a gallon. http://en.wikipedia.org/wiki/Ethanol...l_implications Wikipedia is an interesting concept, but that very concept leads to politicization of science: ....the answer with the most votes wins, whether it is scientifically supportable or not. I am not disputing, nor acknowledging, the accuracy of this particular article.... But Wikipedia has already had to acknowledge political interference to its articles in 2005 http://www.rockymountainnews.com/drm...513833,00.html Being written only by the readers, wikipedia articles reflect the political bias and scientific ignorance of those readers. The idea is that other readers will eventually correct them, sure.... but in a relatively new topic of discussion such as this one, hard facts are difficult to come by. It is a case of "first one in, wins", at least until the emergence of study and documentation that further supports (or disputes). I urge care in using wikipedia as your information source. |
#29
"Jay Honeck" writes:
Ethanol isn't currently a solution to anything other than Archer-Daniels-Midland. It's not a viable source of energy (current production techniques use as much oil to grow and process the ethanol than the oil it would replace in the market). Further, the use of it as an oxygenate in reformulated fuels is suspect as well. While this is undoubtedly true, it's sadly irrelevant. Undoubtedly? Only for someone with a closed mind. The politicians -- not the scientists, or even the economists -- have made the decision to go ahead with ethanol, and we're going to be stuck with it. You make it sound like all scientists agree with Ron's assertion. T'aint so. http://www.treehugger.com/files/2006..._word_on_e.php --kyler |
#30
![]() This is true. Fundamentally however high compression engines are more efficient because of the higher combustion temperature, and the availability of reasonably priced engine component materials limits the combustion temperature we could have in the engine. Doug wrote: Alcohol also has extremely high octane so you can burn it in a very, very high compression engine. High compression engines are more efficient than lower compression engines. This would makeup for the at least SOME of the lower energy content. |
Can a Plane on a Treadmill Take Off? | cjcampbell | Piloting | 286 | February 17th 06 10:02 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
