Using Ethanol in Your Plane
Old March 5th 06, 03:49 AM posted to rec.aviation.owning
Default Using Ethanol in Your Plane
There's a California fellow over on the Cherokee 235/236 user's group who is
using ethanol-laced mogas in his Cherokee 235, exclusively, and without
difficulty.
He admits that he *has* ruined his fiberglass tip tanks -- at something like
$3500 each -- but this has not deterred him from simply shutting them off
and using the aluminum main tanks.
I'm intrigued by his experiment. Although we Iowans just last week defeated
a bill that would have mandated ethanol in all of our gasoline (thanks to
the many here who wrote letters to our legislators!), that threat is always
looming on the horizon.
Jim Weir, you out there? Have you done any barn yard experimenting with
ethanol in your 182?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 5th 06, 12:27 PM posted to rec.aviation.owning
"Jay Honeck" wrote in message
newsdtOf.836777$xm3.407625@attbi_s21...
is using ethanol-laced mogas in his Cherokee 235, exclusively, and without
difficulty.
like $3500 each -- but this has not deterred him from simply shutting them
off and using the aluminum main tanks.
defeated a bill that would have mandated ethanol in all of our gasoline
(thanks to the many here who wrote letters to our legislators!), that
threat is always looming on the horizon.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Isn't the issue that because of the required fuel/air mixture, an engine
running on Ethanol is going to run lean, assuming the carb or fuel injection
system is configured for gasoline?
Other than the wingtip issues, I wonder if there are hidden problems due to
the ethanol. No telling what impact ethanol has on fuel tank sealant,
hoses, seals, etc.
KB
Old March 5th 06, 01:19 PM posted to rec.aviation.owning
: Isn't the issue that because of the required fuel/air mixture, an engine
: running on Ethanol is going to run lean, assuming the carb or fuel injection
: system is configured for gasoline?
That would be a definate concern. Ethanol is a fine fuel for SI engines, but
it should be optimized for it. That means higher compression, and a richer fuel
schedule.... *double* for 100% ethanol IIRC.
: Other than the wingtip issues, I wonder if there are hidden problems due to
: the ethanol. No telling what impact ethanol has on fuel tank sealant,
: hoses, seals, etc.
Also correct. Seals, hoses, gaskets, and aluminum corrosion are concerns. I
recall reading about that on the EA85 website. Something about the additives they had
to add to the 85% ethanol to keep it from attacking the aluminum.
I have no doubt that it can be done, but I wouldn't want to just do it
willy-nilly. That's one case where certification requirements would be a *good*
thing IMO.
-Cory
* Cory Papenfuss *
Old March 5th 06, 04:31 PM posted to rec.aviation.owning
Hmmm. I hadn't heard that before Why would alcohol attack aluminum?
thing IMO.
Agreed. EAA is our best (and probably only) hope in this regard, but
I'm not optimistic. They've basically stated that it's just "too hard"
to get gasohol STC'd, which leaves many of us between a rock and hard
place.
I was just surprised -- and hopeful -- to hear about someone openly
flying a certificated aircraft with 15% gasohol, apparently without
difficulty.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 5th 06, 04:49 PM posted to rec.aviation.owning
: Hmmm. I hadn't heard that before Why would alcohol attack aluminum?
Just to recall that I'd actually read it somewhere, I did a quick google:
http://aiche.confex.com/aiche/2005/t...ram/P18201.HTM
http://www.eaa.org/communications/ea...11_cessna.html
: I have no doubt that it can be done, but I wouldn't want to just do it
: willy-nilly. That's one case where certification requirements would be a *good*
: thing IMO.
: Agreed. EAA is our best (and probably only) hope in this regard, but
: I'm not optimistic. They've basically stated that it's just "too hard"
: to get gasohol STC'd, which leaves many of us between a rock and hard
: place.
Of course, the *real* solution is to realize that producing ethanol as a
substitute synthetic fuel is a bad idea in general.
http://petroleum.berkeley.edu/papers...hanol.2005.pdf
Study concludes that it Costs 57% more fossil energy to produce the ethanol
than the energy contained within it.
Now, given the unique requirements of GA aircraft fuels (low volume required
compared to automotive gasoline, high octane required), it might be viable as an
alternative to 100LL even considering the additional fossil energy required. For an
automotive fuel ingredient, it is there for purely political (read: financial)
reasons.
: I was just surprised -- and hopeful -- to hear about someone openly
: flying a certificated aircraft with 15% gasohol, apparently without
: difficulty.
There's no doubt it can be done:
http://www.age85.org/
BUT, it must be done correctly to be safe. In particular, thorough
examination and testing of all components of the fuel system, engine, and airframe. I
would suggest you may want to forward this information to the guy doing it. Legal
issues aside, it's probably not a good idea without careful testing.
-Cory
* Cory Papenfuss *
Old March 5th 06, 06:42 PM posted to rec.aviation.owning
"KB" == Kyle Boatright writes:
KB "Jay Honeck" wrote in message
KB newsdtOf.836777$xm3.407625@attbi_s21...
group who is using ethanol-laced mogas in his Cherokee 235,
exclusively, and without difficulty.
something like $3500 each -- but this has not deterred him from
simply shutting them off and using the aluminum main tanks.
He has ruined his tip tanks at a loss of $7000 but is using mogas
"without difficulty". Right. That guy is every bit as stupid and
confused as the moron who blundered into the D.C. ADIZ a few months
ago, and is as likely to give GA an equally bad name.
Old March 8th 06, 12:18 AM posted to rec.aviation.owning
hoses, seals, etc.
Ethanol unlike gasoline is hydroscopic. This causes problems with
swelling of rubber fuel components as well as increased corrosion
problems.
Old March 5th 06, 07:19 PM posted to rec.aviation.owning
Unlike some on this newsgroup, Jay, I'm not quick to admit in public to
busting the FARs. Especially since I use my FAA wallpaper to accumulate a
few AMUs from time to time.
Having said that, I have this friend named Ernie ... and before Ernie knew
that California gasoline contained alcohol he flew his elderly 182 for a
couple of years with no apparent difficulties. However, when Ernie found
out that California fuel contained about 5% ethanol, he considered that the
rubber bladder fuel tanks and the neoprene carb needle probably wouldn't be
overjoyed sitting all winter in an ethanol bath and hasn't used it since.
Capiche?
CFI A&G, A&P/IA and planning on staying that way for a while.
Old March 5th 06, 08:57 PM posted to rec.aviation.owning
Gotcha.
However, could you not take your 182 into the "Experimental" category, and
experiment to your heart's content? True, the resale value of your 182
would plummet to near zero, but (a) you'd be saving fifty bucks every time
you filled the tanks, (b) you aren't ever planning to sell the plane,
anyway, and (c) you'd be doing everyone a great public service.
What's a few bucks, when in exchange you can get that warm, fuzzy feeling
inside from helping your fellow pilots?
It sure would be good to know -- from a knowledgeable source -- that the
stuff works safely in airplanes. I'm sick of hearing "it can't be done"
from our AOPA and EAA reps, when clearly that's a load of B.S.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 6th 06, 09:19 PM posted to rec.aviation.owning
On Sun, 5 Mar 2006, RST Engineering wrote:
However, when Ernie found out that California fuel contained about 5%
ethanol, he considered that the rubber bladder fuel tanks and the
neoprene carb needle probably wouldn't be overjoyed sitting all winter
Did Ernie ever take a look at those & other parts to see if they were
actually affected by the ethanol?
On a related note, I'd be very interested in hearing about experiences or
knowledgeable opinions on using ethanol in an IO-360-A1A. In particular,
I'd like to know if there's anything in the fuel injection system that
would be negatively affected by ethanol, and what octane I need to stay
above to avoid any chance of detonation (8.7:1 compression). It's in an
experimental airplane so there's no concerns about legality.
-Dan
Can a Plane on a Treadmill Take Off? cjcampbell Piloting 286 February 17th 06 10:02 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
