#41
Derek Copeland wrote:
By comparison the Standard Cirrus was very easy to fly, subject to the usual provisos for all-flying tailplanes. Don't be put off this lovely glider by all the scare stories! When a number of experienced pilots, some of them CFIGs, and some with thousands of hours, who have flown a variety of gliders, issue warnings about a particular glider, that rises above the level of "scare stories". For example, you do not hear this controversy over the LS4. These warnings should be respected and considered carefully, especially if you are a less experienced pilot. The Std. Cirrus is not an LS4 with a quirk or two. For clarification, the Std Cirrus I refer is not the Cirrus 75, but the older models called "Standard Cirrus". The Cirrus 75 had a number of changes, such as better airbrakes, and I am not familiar with it. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
#42
Sorry Eric but you are talking b*ll*cks. The Standard
Cirrus may not have quite the same modern safe handling as a LS4 or a Discus, but any competent pilot should be able to fly one quite easily and safely. They also have the advantage of costing a fraction of the amount expected for these supposedly more desirable types and are not that far short on performance. The differences between the earlier Standard Cirrus and the later Standard Cirrus75 are wing root fillets to improve the low speed handling, bigger airbrakes and I believe slight changes to the wing section and tailplane mounting. The airbrakes on either type can be greatly improved by fitting the bolt on double paddle kits, and I would recommend that these should be fitted. The last couple of versions were fitted with conventional tailplanes after the vogue for all flying tailplanes passed, and these handle pretty much like the Discus. The only issue with all flying-tailplanes is that they tend to trail along the relative airflow. This means that if you let go of the stick the glider will have little stick free stability. If it is not perfectly trimmed out, or hits disturbed air, it will slowly enter an ever increasing phugoid which will not damp itself out. However if you do remember to hold the stick, this problem disappears and the glider will be as stable in pitch as any other type, as long as the cockpit weight limits are observed. How often and for how long do you normally fly without holding the stick? If you could be placed in a Standard Cirrus at 2000 feet and told to get on with flying it, you probably wouldn't even notice that it had an all flying tailplane. The only thing you might find out if you experimented a bit is that the elevator loads do not change with speed. This probably makes it unsuitable for aerobatics unless you are very skilled at doing them, although it is certified as semi-aerobatic. Best to regard it as a soaring machine, which it does very well. Standard Cirri usually clean up in Club Class competitions. All the owners I know love their Standard Cirruses, not least because of the light and precise handling. Derek Copeland ---------------------------------- At 23:24 21 March 2006, Eric Greenwell wrote: Derek Copeland wrote: By comparison the Standard Cirrus was very easy to fly, subject to the usual provisos for all-flying tailplanes. Don't be put off this lovely glider by all the scare stories! When a number of experienced pilots, some of them CFIGs, and some with thousands of hours, who have flown a variety of gliders, issue warnings about a particular glider, that rises above the level of 'scare stories'. For example, you do not hear this controversy over the LS4. These warnings should be respected and considered carefully, especially if you are a less experienced pilot. The Std. Cirrus is not an LS4 with a quirk or two. For clarification, the Std Cirrus I refer is not the Cirrus 75, but the older models called 'Standard Cirrus'. The Cirrus 75 had a number of changes, such as better airbrakes, and I am not familiar with it. -- Change 'netto' to 'net' to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download 'A Guide to Self-launching Sailplane Operation' |
#43
Sorry Eric but you are talking b*ll*cks. Please read this part again:"When a number of experienced pilots, some of them CFIGs, and some with thousands of hours, who have flown a variety of gliders,issue warnings about a particular glider, that rises above the level of 'scare stories'." It's not just me, it's not just an anorak with 20 hours in a 2-33 that scares himself in his first flight in a Std Cirrus. That would be a "scare story". The Standard Cirrus may not have quite the same modern safe handling as a LS4 or a Discus, but any competent pilot should be able to fly one quite easily and safely. That begs the question: "any competent pilot". Yes, someone that can fly it safely can fly it safely. My comments were to the less experienced pilot that might be able to safely fly an LS4 but not the Std Cirrus. They also have the advantage of costing a fraction of the amount expected for these supposedly more desirable types and are not that far short on performance. Yes, they are cheaper, and it's not just because they are older or have less performance. Cheaper may not be a good value for the less experienced pilot. snip The only issue with all flying-tailplanes is that they tend to trail along the relative airflow. This means that if you let go of the stick the glider will have little stick free stability. If it is not perfectly trimmed out, or hits disturbed air, it will slowly enter an ever increasing phugoid which will not damp itself out. However if you do remember to hold the stick, this problem disappears and the glider will be as stable in pitch as any other type, as long as the cockpit weight limits are observed. How often and for how long do you normally fly without holding the stick? Not very often, but my Std Cirrus was the only one I didn't dare let go of the stick over about 80 mph. Have you missed the discussion of the positive feedback in turbulence from the unbalanced elevator circuit? My other gliders didn't have that. If you could be placed in a Standard Cirrus at 2000 feet and told to get on with flying it, you probably wouldn't even notice that it had an all flying tailplane. I sure did in mine. The only thing you might find out if you experimented a bit is that the elevator loads do not change with speed. This probably makes it unsuitable for aerobatics unless you are very skilled at doing them, although it is certified as semi-aerobatic. Best to regard it as a soaring machine, which it does very well. Standard Cirri usually clean up in Club Class competitions. All the owners I know love their Standard Cirruses, not least because of the light and precise handling. I did not love my Standard Cirrus, but I did like it. It's handling stunk compared to my ASW 20 C. What a difference! The designers have learned a lot since the Standard Cirrus was designed almost 40 years ago. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
#44
Hi Eric
I can only say that as a UK qualified instructor with several hundred hours in the Standard Cirrus, I have briefed many very nervous pilots for their first flight in this type. They are mostly only nervous because of the scare stories put about by people like you. They have all returned with big beaming smiles, asking what all the fuss was about! OK it has very light controls compared with the 'Yank Tank' Schweizers that your CFIGs tend to fly, but as long as this is properly briefed for it doesn't seem to cause a problem. Ideally I would prefer pilots to have had at least some previous experience in other types of standard class gliders. Regards, Derek Copeland -------------------------- At 03:30 22 March 2006, Eric Greenwell wrote: Please read this part again:'When a number of experienced pilots, some of them CFIGs, and some with thousands of hours, who have flown a variety of gliders,issue warnings about a particular glider, that rises above the level of 'scare stories'.' It's not just me, it's not just an anorak with 20 hours in a 2-33 that scares himself in his first flight in a Std Cirrus. That would be a 'scare story'. The Standard Cirrus may not have quite the same modern safe handling as a LS4 or a Discus, but any competent pilot should be able to fly one quite easily and safely. That begs the question: 'any competent pilot'. Yes, someone that can fly it safely can fly it safely. My comments were to the less experienced pilot that might be able to safely fly an LS4 but not the Std Cirrus. They also have the advantage of costing a fraction of the amount expected for these supposedly more desirable types and are not that far short on performance. Yes, they are cheaper, and it's not just because they are older or have less performance. Cheaper may not be a good value for the less experienced pilot. snip The only issue with all flying-tailplanes is that they tend to trail along the relative airflow. This means that if you let go of the stick the glider will have little stick free stability. If it is not perfectly trimmed out, or hits disturbed air, it will slowly enter an ever increasing phugoid which will not damp itself out. However if you do remember to hold the stick, this problem disappears and the glider will be as stable in pitch as any other type, as long as the cockpit weight limits are observed. How often and for how long do you normally fly without holding the stick? Not very often, but my Std Cirrus was the only one I didn't dare let go of the stick over about 80 mph. Have you missed the discussion of the positive feedback in turbulence from the unbalanced elevator circuit? My other gliders didn't have that. If you could be placed in a Standard Cirrus at 2000 feet and told to get on with flying it, you probably wouldn't even notice that it had an all flying tailplane. I sure did in mine. The only thing you might find out if you experimented a bit is that the elevator loads do not change with speed. This probably makes it unsuitable for aerobatics unless you are very skilled at doing them, although it is certified as semi-aerobatic. Best to regard it as a soaring machine, which it does very well. Standard Cirri usually clean up in Club Class competitions. All the owners I know love their Standard Cirruses, not least because of the light and precise handling. I did not love my Standard Cirrus, but I did like it. It's handling stunk compared to my ASW 20 C. What a difference! The designers have learned a lot since the Standard Cirrus was designed almost 40 years ago. |
#45
I read Mr. Greenwell's comments with the same respect I usually have
for his comments. I have to disagree with him on this one. Instructors and some seasoned pilots told me what a man-killer a 1-35 was. With 27 total flight hours, I flew it, and I still wonder just what they were referring to. I have 128 hours in a 1-35 and now own a PIK-20B... ooooohhh... those nasty flaps! If I listened to every warning from every misinformed person that doesn't like the subject glider, for whatever reason, I would have never taken that first ride in a Pratt-Reid so many years ago. Just because a guy or lady can be an instructor doesn't mean he or she is an expert or even a good pilot. Conversly, just because someone is a good pilot, doesn't mean that he or she can be a good instructor. Stories about not having the elevator hooked up and the like are very helpful, and they make us all more careful pilots. Stories about the supposed bad behavior of a particular sailplane model only damage our sport. I saw some recent, veiled references to the 1-35 and it's supposed bad habits in Soaring Magazine and they didn't print my reply. I think that's sad, especially for someone that might really enjoy flying one, and for someone that has one for sale. I have 1 flight of 2 hours in a Standard Cirrus. What a nice ship it was... but then... I'm not in the habit of flying hands-off... Just my $.02 worth. Jack Womack Clovis, NM |
#46
Jack wrote:
I read Mr. Greenwell's comments with the same respect I usually have for his comments. I have to disagree with him on this one. Instructors and some seasoned pilots told me what a man-killer a 1-35 was. With 27 total flight hours, I flew it, and I still wonder just what they were referring to. I have 128 hours in a 1-35 and now own a PIK-20B... ooooohhh... those nasty flaps! If I listened to every warning from every misinformed person that doesn't like the subject glider, for whatever reason, I would have never taken that first ride in a Pratt-Reid so many years ago. Just because a guy or lady can be an instructor doesn't mean he or she is an expert or even a good pilot. Conversly, just because someone is a good pilot, doesn't mean that he or she can be a good instructor. Stories about not having the elevator hooked up and the like are very helpful, and they make us all more careful pilots. Stories about the supposed bad behavior of a particular sailplane model only damage our sport. I saw some recent, veiled references to the 1-35 and it's supposed bad habits in Soaring Magazine and they didn't print my reply. I think that's sad, especially for someone that might really enjoy flying one, and for someone that has one for sale. I have 1 flight of 2 hours in a Standard Cirrus. What a nice ship it was... but then... I'm not in the habit of flying hands-off... Just my $.02 worth. Jack Womack Clovis, NM Forgive me, but it's a long, dank, snowy, week at the end of winter... IMHO Jack touches upon a fact of soaring life inescapable for all who fly single seat sailplanes, namely: at some point everyone who does, must rely upon their individual judgment that it is safe for them to fly a given single-seat ship. As obvious and fatuous a statement that may seem to many, it's true whether or not an instructor agrees with him or her, and it has implications for every single-seat gliderpilot. We live in a world in which the routine application of individual judgment helps us survive (and sometimes not). Attempting to abdicate such reality may (arguably) lead to a safer life, but in the case of soaring a genuinely poorer one for most. How many flights would not be made, how many ships not flown, how many growth experiences delayed or never experienced, all because an instructor's judgment conflicted with a seeker of knowledge? Instructors are human, and - in my judgement! - come with human foibles, biases, skills and judgment. For better or worse - and mostly the better! - we're stuck with relying upon their judgments for much of our early training. But there comes a day when if we are to continue to grow as pilots, we inevitably begin to rely more on our own judgment. That's just a fact...whether it's good or bad depends on how sound our own judgment is. As a pilot who transitioned to flaps-only single-seaters from a 1-26 and who has never flown any other types since, I read & heard then when I sought ship-specific knowledge (and continue to read & hear) all sorts of misinformation in the glider world - not merely about flaps - too often presented as fact rather than opinion or judgment. We live in an imperfect world, and I expect that sort of misinformation will be around lots longer than I, so the circle is complete: it's necessary to apply one's own judgment to information presented. The better instructors will help their students understand the need to apply judgment and develop the skills and confidence to do so, while not blindly or uncritically passing along misinformation. Tangentially (but not unrelated, in my view), safety in soaring is 'merely' another side of having fun. Whatever you choose to do, whether legal or of sound judgment or not, if you have an accident while doing it, it will be less fun than if you didn't! Ideas have consequences. May all your ideas prove personally rewarding, your skills up to the tasks' demands, and your judgment sound. Most of all, have fun!!! Regards, Bob W. |
#47
![]() "Bob Whelan" wrote in message ... Jack wrote: I read Mr. Greenwell's comments with the same respect I usually have for his comments. I have to disagree with him on this one. Instructors and some seasoned pilots told me what a man-killer a 1-35 was. With 27 total flight hours, I flew it, and I still wonder just what they were referring to. I have 128 hours in a 1-35 and now own a PIK-20B... ooooohhh... those nasty flaps! If I listened to every warning from every misinformed person that doesn't like the subject glider, for whatever reason, I would have never taken that first ride in a Pratt-Reid so many years ago. Just because a guy or lady can be an instructor doesn't mean he or she is an expert or even a good pilot. Conversly, just because someone is a good pilot, doesn't mean that he or she can be a good instructor. Stories about not having the elevator hooked up and the like are very helpful, and they make us all more careful pilots. Stories about the supposed bad behavior of a particular sailplane model only damage our sport. I saw some recent, veiled references to the 1-35 and it's supposed bad habits in Soaring Magazine and they didn't print my reply. I think that's sad, especially for someone that might really enjoy flying one, and for someone that has one for sale. I have 1 flight of 2 hours in a Standard Cirrus. What a nice ship it was... but then... I'm not in the habit of flying hands-off... Just my $.02 worth. Jack Womack Clovis, NM Forgive me, but it's a long, dank, snowy, week at the end of winter... IMHO Jack touches upon a fact of soaring life inescapable for all who fly single seat sailplanes, namely: at some point everyone who does, must rely upon their individual judgment that it is safe for them to fly a given single-seat ship. As obvious and fatuous a statement that may seem to many, it's true whether or not an instructor agrees with him or her, and it has implications for every single-seat gliderpilot. We live in a world in which the routine application of individual judgment helps us survive (and sometimes not). Attempting to abdicate such reality may (arguably) lead to a safer life, but in the case of soaring a genuinely poorer one for most. How many flights would not be made, how many ships not flown, how many growth experiences delayed or never experienced, all because an instructor's judgment conflicted with a seeker of knowledge? Instructors are human, and - in my judgement! - come with human foibles, biases, skills and judgment. For better or worse - and mostly the better! - we're stuck with relying upon their judgments for much of our early training. But there comes a day when if we are to continue to grow as pilots, we inevitably begin to rely more on our own judgment. That's just a fact...whether it's good or bad depends on how sound our own judgment is. As a pilot who transitioned to flaps-only single-seaters from a 1-26 and who has never flown any other types since, I read & heard then when I sought ship-specific knowledge (and continue to read & hear) all sorts of misinformation in the glider world - not merely about flaps - too often presented as fact rather than opinion or judgment. We live in an imperfect world, and I expect that sort of misinformation will be around lots longer than I, so the circle is complete: it's necessary to apply one's own judgment to information presented. The better instructors will help their students understand the need to apply judgment and develop the skills and confidence to do so, while not blindly or uncritically passing along misinformation. Tangentially (but not unrelated, in my view), safety in soaring is 'merely' another side of having fun. Whatever you choose to do, whether legal or of sound judgment or not, if you have an accident while doing it, it will be less fun than if you didn't! Ideas have consequences. May all your ideas prove personally rewarding, your skills up to the tasks' demands, and your judgment sound. Most of all, have fun!!! Regards, Bob W. Who says there isn't wisdom on RAS. Two great opinions in a row. Congratulations Bob and Jack. There are few bad gliders but there are many bad pilots, unfortunately. Bill Daniels |
#48
Jack wrote:
I read Mr. Greenwell's comments with the same respect I usually have for his comments. I have to disagree with him on this one. Instructors and some seasoned pilots told me what a man-killer a 1-35 was. Have you actually owned (like Eric), or at least flown, a Standard Cirrus? The logic underlying your disagreement here escapes me (unless, of course, you actually have a few hundred hours in a Standard Cirrus). The reality is that there are people who make pronouncements based on what they hear, and others who make them based on their own experiences. Ignoring the latter, because of the former, is just plain stupid... Marc |
#49
Marc Ramsey wrote:
Jack wrote: I read Mr. Greenwell's comments with the same respect I usually have for his comments. I have to disagree with him on this one. Instructors and some seasoned pilots told me what a man-killer a 1-35 was. Have you actually owned (like Eric), or at least flown, a Standard Cirrus? The logic underlying your disagreement here escapes me (unless, of course, you actually have a few hundred hours in a Standard Cirrus). The reality is that there are people who make pronouncements based on what they hear, and others who make them based on their own experiences. Ignoring the latter, because of the former, is just plain stupid... Marc Hi Marc As a DG Driver may we assume you do not have "hundreds of hours in ASW20s and Std Cirrus"? If so I assume you are one of those making pronouncements based on hearsay? Both the preceding posts contain wisdom. My first flight in a single seater of any sort was in my Std Cirrus. Though the CFI and other instructors allowed me to take the flight the responsibility for taking it was mine. Same with any person making a first flight on type in a single seater. The famous inscription at the Temple of Apollo at the entrance to the oracle of Delphi says - "Know thyself" As Bob said, you are responsible for your own safety. Objective self assessment is your only rational option. A responsible pilot researches the aircraft he plans to fly, and prepares. But if the vast number of vociferous critics out there are right there is not a single glider out there that is not fatally flawed in some respect. Hell even the LS4 gets criticism for its collapsing undercarriage. So you have to try to be objective and filter the hyperbole and plain bull. The statistics confirm that it is very seldom the glider at fault when things go horribly wrong. Again from bitter personal experience, that white stripe down the runway from a PIO on landing with the Cirrus cost about $100/metre. I got it wrong, and the Cirrus got away from me - the wheel snatched when I braked, I overcorrected - tip, bounce and bang. My fault - not the glider, blaming the tool is the sign of a poor workman... It would be easier on the old ego to tell tales of wild efforts to control an unforgiving etc. etc. airplane - Conversely if you accept responsibility and learn from the experience you are better for it. Best would be to avoid getting it wrong in the first place. Again, you have to know what your capabilities are, and how they match the characteristics of the glider. I find it interesting to see the number of Std Cirruses flying decades after production ceased - it has to have something going for it. Same with other types. Any number of detractors, but the types popularity indicates otherwise. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
#50
Bruce wrote:
As a DG Driver may we assume you do not have "hundreds of hours in ASW20s and Std Cirrus"? If so I assume you are one of those making pronouncements based on hearsay? Actually, I have about 200 hours in various ASW-20 models, including an ASW-20BL which I owned for a couple of years. You'll note I explicitly indicated that I could not comment on the characteristics of the Standard Cirrus, as I've never even sat in one and made glider noises. The one thing I did say was with respect to my general dislike of gliders with manual elevator hookups. We had recent accident here in the US that indicates one can indeed take off (but not land) with the elevator disconnected in a Standard Cirrus. For your future reference if I say anything about the K-21, Grob 103, ASW-20, Ventus B, Duo, LAK-17A, and yes, DG-101, 300, and 303, it is based on anything from 50 to 300 hours of experience. I don't think you can point to too many of my posts where I talk about about gliders I've never flown. I just bought a DG-600 (a glider with a bad reputation, BTW), so expect further pronouncements. Both the preceding posts contain wisdom. My first flight in a single seater of any sort was in my Std Cirrus. Though the CFI and other instructors allowed me to take the flight the responsibility for taking it was mine. Same with any person making a first flight on type in a single seater. The famous inscription at the Temple of Apollo at the entrance to the oracle of Delphi says - "Know thyself" As Bob said, you are responsible for your own safety. Objective self assessment is your only rational option. Absolutely. My argument is with the notion that because one has had good experiences with a particular glider, anyone who makes a few negative comments must therefore be talking out of their arse, even if they actually have as much or more experience in type. There is a lot of personal preference at work here. ALL gliders have positives and negatives. If someone asks, they need to hear both sides. Marc |
Cirrus demo | Dan Luke | Piloting | 12 | December 4th 05 05:26 AM |
New G-1000 182 & Cirrus SR-22 GTS | Dan Luke | Owning | 22 | June 27th 05 07:18 PM |
New G-1000 182 & Cirrus SR-22 GTS | Dan Luke | Piloting | 24 | June 27th 05 07:18 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
