I'm not sleeping after getting the report grounding my Luscombe 8A
after its first annual as my plane. All the advise about a pre-buy inspection is true! I thought my plane was too to do that at a long distance. (My plane came from Georgia, I'm in California). The outboard five feet of the wings and the tailwheel were assembled with non-structural pop rivets. I'm lucky the ferry pilot made it here. I expected some "old plane" problems, not thousands of dollars in substandard repairs. I have contacted the previous owner and am hoping to work something out. Has anyone experienced something like this? How did you deal with this? Linda N71467 |
Welcome to airplane ownership. First of all, don't panic and do
something "right now". Take a step back. An odd part of airplane ownership is that one mechanic's "airworthy" can be another mechanic's "death trap". Those rivets may be entirely proper for that application. They may have been installed by the factory. There are several types of "pop" rivets for airplane applications that ARE structural. Is the work signed off anywhere in the logbooks? When receiving a major dollar report of imminent doom from anyone who repairs mechanical things, I usually get a second opinion. Especially if I am told that "you are lucky you made it here". In addition, who says you are "grounded"? Hopefully that is not a word that came from this mechanic. No mechanic has that authority. Now, if s/he wants to call the local FAA folks in to take a look, they can do that. I would bet money they will not. Other wrenches have weighed in on this forum and they generally agree that mechanics CAN refuse to sign off the bird as airworthy, but that is all. You are in a classic "no leverage" situation and you should consider getting out of it. If the work was signed off under the previous owner's stewardship, give them a call and get the mechanic's telephone number. Tell the old mechanic what your new wrench is telling you and ask them what they think about the situation. In general, I advise healthy suspicion. If the work does not appear in the logbooks or you cannot contact the person who did it, have the plane buttoned up and take it somewhere else locally. If the mechanic jumps up and down about how you will be instantly killed if you attempt to fly the plane OR you cannot bring yourself to do it, then you might try something else. Tell the wrench that you MUST have a second (or third) opinion by someone you are bringing in. S/he should not object because they have already made the case that an unmistakable and dangerous condition exists. By their own warning of doom, anyone with an A&P license should spot this immediately and agree. Get a mechanic with experience in that airplane type, even if you have to pay them to fly in. Given the potential expense, it may be worth it. If they won't allow anyone else to look at it, I would then INSIST they button it up immediately and put it outside. If they won't do that, call the police. Only AFTER you have established that an airplane was signed off as airworthy and it was not (in the opinion of at least 2 independent sources) should you consider pursuing the person who signed off the work. Until then, use whoever signed it off as a resource. Good Luck, Mike ncoastwmn wrote: I'm not sleeping after getting the report grounding my Luscombe 8A after its first annual as my plane. All the advise about a pre-buy inspection is true! I thought my plane was too to do that at a long distance. (My plane came from Georgia, I'm in California). The outboard five feet of the wings and the tailwheel were assembled with non-structural pop rivets. I'm lucky the ferry pilot made it here. I expected some "old plane" problems, not thousands of dollars in substandard repairs. I have contacted the previous owner and am hoping to work something out. Has anyone experienced something like this? How did you deal with this? Linda N71467 |
Thanks for the advise. My plane is already buttoned up and available to
me while I make my decision about what to do. I understand about the different types of blind rivets and tha's what we I will be replacing the old ones with, if I don't just replace components. On to conversations with the last mechanic and finding a second opinion. Thanks, Linda N71467 |
![]() ncoastwmn wrote: Thanks for the advise. My plane is already buttoned up and available to me while I make my decision about what to do. I understand about the different types of blind rivets and tha's what we I will be replacing the old ones with, if I don't just replace components. On to conversations with the last mechanic and finding a second opinion. Thanks, Linda N71467 Linda, Mike has given you excellent advice. On my first annual, I was told that I had an illegal prop installed. It would be $2000 for a used one to replace it. I investigated on my own and found out that the prop wasn't illegal, it just had a part # that was hard to read which caused the mechanic to look up erroneous information. You definitely need to determine just what type of rivets are installed. As Mike has pointed out, Cherrymax and some others are approved for major structural use by Boeing, Lockheed and most aircraft companies. The Aerostar, an expensive and high performance twin, came from the factory with hundreds of them in the wing and elsewhere. Many homebuilts use Q type pop rivets in major areas like the wing spar and they are holding up well. If yours are in the wing skins as I suspect, it would not make it dangerous for most types of pop rivets. The only place where many do not recommend using them is in the engine inlet. Like Mike said, don't panic. Check things out. Bruce N30464 |
Moving the Annual Up | Jay Honeck | Owning | 26 | February 21st 05 12:34 AM |
Christmas Annual - long drivel | Denny | Owning | 23 | December 31st 04 08:52 PM |
Annual Report Final. "Long" | NW_PILOT | Owning | 20 | October 28th 04 07:20 PM |
Annual Report Final. "Long" | NW_PILOT | Piloting | 22 | October 28th 04 07:20 PM |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
