Hot grass fire at Sun-N-Fun
Old April 7th 06, 03:38 PM posted to rec.aviation.homebuilt
Default Hot grass fire at Sun-N-Fun
From Lakeland Ledger newspaper
23 cars burnt.
http://www.theledger.com/apps/pbcs.d...604070342/1039
Old April 7th 06, 03:49 PM posted to rec.aviation.homebuilt
wrote in message oups.com...
23 cars burnt.
Wow, bummer...
Global warming strikes again?
" John Burton, Sun 'n Fun's president, said the main problem is the persistent drought in the area.
"I don't know the last time we got any significant rainfall here," he said. "
Old April 7th 06, 04:04 PM posted to rec.aviation.homebuilt
23 cars burnt.
This is a well known problem with glider retrieves. If the vehicle pulling
the glider trailer pulls off the highway into a grass field to get near
glider the red hot catalytic converter can set the grass on fire. It's
happened more than once. Driving an off-road vehicle on grasslands is also
a fire hazard. Catalytic converters get red hot.
Avoid driving on dry grass if at all possible. If not, stop and shut off
the engine on the highway sholder to let the cat cool off before driving
onto the field.
Old April 8th 06, 01:41 AM posted to rec.aviation.homebuilt
I remember as a young boy (and I ain't that old now) my uncle converting all
of the farm trucks to "straight pipes". Cut out the catalytic converter, no
muffler, exhaust going straight up instead of under, during a very dry
harvest season. Not the first time it's happened... probably not the last.
"Bill Daniels" bildan@comcast-dot-net wrote in message
23 cars burnt.
pulling the glider trailer pulls off the highway into a grass field to get
near glider the red hot catalytic converter can set the grass on fire.
It's happened more than once. Driving an off-road vehicle on grasslands
is also a fire hazard. Catalytic converters get red hot.
onto the field.
Old April 8th 06, 04:27 AM posted to rec.aviation.homebuilt
"Jase Vanover" wrote in message Not the first time it's happened...
Most of S-n-F's automotive parking is on grass. Central Florida has water
restrictions in place quite early this year. The temp/dew point spread was
30/-1 a few days ago- something I have never seen before in the peninsula. I
wonder if the car owners' insurance will subrogate S-n-F for the claims?
D.
Old April 8th 06, 05:16 AM posted to rec.aviation.homebuilt
My opinion... whenever an airshow has parking on grass fields they
become completely liable for any fires caused by catalytic converters.
It's no secret that all modern vehicles have catalytic converters and
it's no secret that hot catalytic converters WILL cause dry grass to
catch on fire.
IMHO, SNF is completely responsible for any and all damages incurred
because of the fires.
They should have cut the grass earlier and much shorter so it wouldn't
have caught on fire, causing the damage to the cars...
We have the same problem here at the Arlington Airfair... I drive a
full size truck so I'm not likely to cause a fire but any normal sedan,
being much lower, is quite likely to be able to catch the grass on fire.
I figure we've been lucky so far but can't count on that to last
forever...
John
D.
Old April 8th 06, 12:43 PM posted to rec.aviation.homebuilt
"John Ammeter" wrote in message ...
My opinion... whenever an airshow has parking on grass fields they become completely liable for any fires caused by
catalytic converters. It's no secret that all modern vehicles have catalytic converters and it's no secret that hot
catalytic converters WILL cause dry grass to catch on fire.
IMHO, SNF is completely responsible for any and all damages incurred because of the fires.
They should have cut the grass earlier and much shorter so it wouldn't have caught on fire, causing the damage to the
cars...
We have the same problem here at the Arlington Airfair... I drive a full size truck so I'm not likely to cause a fire
but any normal sedan, being much lower, is quite likely to be able to catch the grass on fire. I figure we've been
lucky so far but can't count on that to last forever...
John
Sometime shortly after the catalytic converters were mandated, heat shields were also mandated that are _supposed_ to
prevent this fire problem....
Old April 8th 06, 02:24 PM posted to rec.aviation.homebuilt
The heat shield cuts down on radiant heat from the CC, but if the
heatshield itself is hot enough and TOUCHES the tall dry grass, then you
still have a fire.
Dave
Old April 8th 06, 05:43 PM posted to rec.aviation.homebuilt
Shoot, Uncle John, I don't know how things are up north of us by you, but in
Northern California you couldn't light the grass on fire with a propane
torch and a tank full of gasoline.
83" of rain so far this year, and still pounding down.
size truck so I'm not likely to cause a fire but any normal sedan, being
figure we've been lucky so far but can't count on that to last forever...
John
Old April 8th 06, 07:11 PM posted to rec.aviation.homebuilt
My neighbor fired up a pile of dry blackberry bushes yesterday. That
pile has been sitting there for 6 or 7 months all through the winter
but, when he set it off, within a minute or so you couldn't get within
15 feet of it. It was amazing how fast it burned. With a dry winter,
our forests and grasslands can be the same way.
John
John
Mooney M20 K on Grass ? Andrew Boyd Owning 0 August 13th 04 03:00 PM
"Friendly fire" Mike Naval Aviation 3 April 6th 04 06:07 PM
My Engine Fire!! [email protected] Piloting 21 April 2nd 04 05:02 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
"Friendly fire" Mike Military Aviation 0 March 19th 04 02:36 PM
