My Engine Fire!!
Old March 30th 04, 05:16 AM
Default My Engine Fire!!
It's 10pm. It's 6 degrees outside. I decide to go flying. I fly an Cessna
150.
The engine has a Tanis preheater. During the pre-flight I notice that the
engine block feel reasonably warm. Everything else looks good.
I prime 3 or 5 shots and crank the engine. No joy. I let it crank for a
reasonable time to clear any flooding and repeat.
I prime 3 or 5 shots and crank the engine. Backfire. I pause and wonder
"what the heck, it's never done that before." Then I notice a glow
from
under the engine cowling. And smoke. How weird, that's never happen before.
About two nanoseconds later I realize the engine is on FIRE!!!!!
I begin to bail out of the plane. But I cannot get my seatbelt undone. I
say
out loud "calm down", get my seat belt undone, and leave the plane.
About 30 seconds later, watching a bit of glow and smoke come from under my
cowling, I realize that the plane is not going to immediatly explode. I go
back to the plane and look for a fire extinguisher. There is none, but I do
grab my flight bag and run to the car. No fire extiguisher there either.
By now about a minute has gone by. The glow is gone, but the smoke
continues.
I sit and wait. I'd like to open the oil-access door, but I have no idea if
the fire is out and don't want to add any extra oxygen.
Finally, after 5 minutes, I walk to the plane. The cowling is cool to the
touch. I open the oil access door. Everything looks fine. Great! Now I
can go flying.
Er, not. I decide that people who fly after engine compartment fires are
those people who end up on the "How Stupid Was He" columns in my
favorite
flying magazine. I push the plane back in the hanger.
The mechanic says it might be that I over-primed the engine. It also might
be
an accumuation of oil from an oil leak. Everything important seems to be OK
except my pride.
Conclusions:
1) I forgive myself the panic two seconds with the seat belt. Next time I'll
be calmer but it was my first engine fire and I was un-calm for only two
seconds.
2) One should remember the fuel shut-off valve. It's quite out-of-sight, but
this would have been the only time in my whole flying career that it would
have actually been useful.
3) I'm gonna have to reread the "cold weather starting procedure"
section of
the manual.
4) The inside of the cowl is rather hard to see. How the heck is one suppose
to know if there is oil accumulating? Especially since there were no
significant oil drippings onto the hanger floor and the engine was not
consuming oil unreasonably.
5) Fire extinguishers. For this fire it would have made things worse. For a
different fire, it might have made things better. Hmmmmmm.
6) Insurance. The plane is insured, and I can clearly afford the deductable.
That makes many things OK.
----- Posted via NewsOne.Net: Free (anonymous) Usenet News via the Web -----
http://newsone.net/ -- Free reading and anonymous posting to 60,000+ groups
NewsOne.Net prohibits users from posting spam. If this or other posts
made through NewsOne.Net violate posting guidelines, email
Old March 30th 04, 01:40 PM
JDupre5762
from
say
Before bailing from the plane try this. Throttle and Mixture off and crank the
starter. This should draw the burning gases through the carburetor and into
the cylinders where without any further fuel they will die for lack of oxygen.
I would be that the carburetor's aluminum venturi is distorted or melted away
completely.
John Dupre'
Old March 30th 04, 02:37 PM
Jay Honeck
How so?
Thanks for sharing that story -- it's one of my "worst-case scenarios,"
especially with the kids strapped in the back seats.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 30th 04, 04:33 PM
C J Campbell
Interesting story (assuming you are not an April Fools troll), but you did
not quite learn the right lessons. If it makes you feel any better, one of
my students did the same thing just a couple of weeks ago, except that I was
with him and we used the proper emergency procedure, limiting damage to a
burned air filter and an hour of cleaning soot off the engine.
First of all, you over-primed the engine, but you knew that, didn't you? You
have a pre-heater, which means that you do not use cold weather starting
procedures. Letting it crank a reasonable time to clear any flooding does
not get rid of the fuel on the air filter and everywhere else it has dripped
under the cowling. No more than two shots of primer should have been plenty.
If the engine does not start you stop cranking and find out why.
Secondly, you seriously abused that poor starter. Your POH specifies wait
periods between attempts to start the engine in order to allow the starter
to cool. The service life of the starter is greatly shortened by this kind
of treatment.
As others pointed out, you should have known whether the plane had a fire
extinguisher and where it was located, as well as whether it is effective
against fuel fires. Most aircraft have Halon extinguishers which work well
on such fires.
You also need to study your emergency procedures. Your checklist contains a
procedure for fire while starting the engine and you should have committed
that to memory. You should also practice all these emergency procedures on a
regular basis. Jumping out of an airplane on fire endangers not only your
airplane but all the airplanes around you. The owners of those planes would
have come looking for you expecting compensation for the damage to their
property.
When you put the plane away in the hangar you did not really know that the
fire was out. Something could have been smoldering away in the cowling.
Hours later the fire might have restarted and burned down the hangar, the
neighboring hangars, and all the planes inside them. You could have been
liable for literally millions of dollars of damage. The cowling needs to
come off (all of it, not just the top piece) and you need to take a look
everywhere.
The one thing you did right was not fly the airplane immediately. A mechanic
needs to examine the engine for damage, especially to the air filter,
wiring, and hoses.
Old March 30th 04, 05:29 PM
Mike Z.
Having gone through this past winter with a Tanis, I just want to comment on the priming angle.
After being plugged in all night, low of 10f, now 20f, I give the old girl 1 to 1.5 squirts and she starts in 2 blades. Answering
your questions in advance, I have primer on only one cylinder. Once I start to crank, I will pump the throttle once, maybe twice.
Point of all this being, it appears that the Tanis keeps it warm enough that the engine starts about the same as it would on a nice
75 degree summer day.
Mike Z
wrote in message ...
150.
from
say
continues.
can go flying.
favorite
be
except my pride.
Conclusions:
seconds.
section of
the manual.
Old March 30th 04, 05:53 PM
mikem
(Account of overpriming and resulting engine fire deleted)
Any of the carburettor mounted below engine Lyc and Continental
engines are prone to this...
I had it happen to me in a 182. The 182 is particularly prone
if the engine starts normally, and you taxi the
aircraft a short distance (say to the fuel island), shut off
the engine, leave it off for a few min, and then restart...
What happens is that the metal induction tubes are still cold
soaked; the short run not being sufficient to heat them. Fuel
evaporates normally in the carb during the engine run, but because
of the induction tubes are cold, the fuel droplets condense
on the cold metal surface, like moisture condenses on a cold
beer glass.
As long as the engine is running, there is sufficient flow
up the induction system to suck the fuel into the cylinders.
If you shut off the engine, the condensed fuel runs back down
through the carburettor, and puddles in the carb air box.
A backfire during the next restart attempt is all it takes
to set the puddle of gas alight.
The admonition in the manual for continuing to crank in an
attempt to suck the fire up into the induction is there for
a reason. Be especially wary of an induction fire on the
second restart if the previous engine run was just a few
min...
MikeM
Skylane '1MM
Old March 31st 04, 03:50 AM
Cockpit Colin
By any chance did you also pump the throttle a few times?
Old March 31st 04, 07:41 AM
Marty
"C J Campbell" wrote in message
Good stuff snipped....
on such fires.
CJ,
Is there a special exclusion for the use of Halon in planes?
I thought Halon was outlawed or common use and now required special
permitting.
Great stuff tho.
Marty
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
p3/95 [email protected] Military Aviation 1 September 27th 04 01:27 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 02:41 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
