Two problems...
1. Two antennas fed together would effectively look like a 25 Ohm load to the transponder, which is designed for 50 Ohm loads. SWR would be 2:1, so some of the output power from the transponder would be reflected back to the unit. Any power reflected reduces power being radiated out of the antenna, reducing range. 2. Mounting the antennas on the side would make the radio wave horizontally polarized. ATC receive site is set for vertical polarization. There would be a 20 dB loss of signal just due to the differences in polarities (which means the signal would seem 100 times weaker at each end, thus reducing range again). Scott Gary Emerson wrote: Had this random thought over the weekend. Figured there were people on RAS that might have information to say whether this would help or hurt the transmit "power" of a transponder. Instead of mounting a single antenna on the belly of the fuse where it can get beat up in the trailer, off field landings or just rocks and mud on the runway, what about a pair of antennas mounted on the side of the fuse on the tail boom similar to static ports. If you ran a single co-axial cable and then put a T at the end and then ran a short piece to each side of the boom then you'd have, in concept anyway, a good 360 "view". It may well be that antennas don't like this sort of arrangement so I figured I'd ask. Also has the obvious downsides of needing the factory to build this in to the plane and doubling your antenna costs. The benefit is that it does move the antenna farther from the pilot. |
Two problems...
1. Two antennas fed together would effectively look like a 25 Ohm load to the transponder, which is designed for 50 Ohm loads. SWR would be 2:1, so some of the output power from the transponder would be reflected back to the unit. Any power reflected reduces power being radiated out of the antenna, reducing range. No. It is done all the time - feeding two or more antennas. It is simple to do. If you feed a 50 ohm antenna with a 1/4 wave of 75 ohm line, the impedance is converted to 100 ohms. Then, place two 100 ohm feedlines in parallel and you have 50 ohms. To determine the proper 1/4 wave length, you would multiply a normal 1/4 length time the velocity factor of the coax. If the determined length is not sufficient for the spacing, you would use 3/4 wavelength line. Not simple - but not difficult. 2. Mounting the antennas on the side would make the radio wave horizontally polarized. ATC receive site is set for vertical polarization. There would be a 20 dB loss of signal just due to the differences in polarities (which means the signal would seem 100 times weaker at each end, thus reducing range again). No. The antennas could be mounted vertically, as in a vertical dipole. A few other configurations could also be used to obtain vertical polarization - but you could not mount a normal vertical in a horizontal plane, since it would become horizontal polarization. Colin |
![]() "Scott" wrote in message ... Two problems... 1. Two antennas fed together would effectively look like a 25 Ohm load to the transponder, which is designed for 50 Ohm loads. SWR would be 2:1, so some of the output power from the transponder would be reflected back to the unit. Any power reflected reduces power being radiated out of the antenna, reducing range. It would be worse than that because the 50ohm cable impedance to the T-Junction would be in series with the 25ohms created by the two parallel 50ohm stubs, which would present 75ohms equivalent to the transponder. This will reduce the power for radiation whilst increasing the stress on the transponder's output. To add insult to injury the reflected wave back from the impedance mismatch at the junction would have exactly double the voltage (in the opposite polarity) when it gets to the transponder output and could very likely blow the finely tuned output amplifier. The beauty of this type of malfunction (also common in high-speed electronic signals) is that the act of measuring the wave with say an oscilloscope conveniently causes the reflected wave to disappear. 2. Mounting the antennas on the side would make the radio wave horizontally polarized. ATC receive site is set for vertical polarization. There would be a 20 dB loss of signal just due to the differences in polarities (which means the signal would seem 100 times weaker at each end, thus reducing range again). Scott Gary Emerson wrote: Had this random thought over the weekend. Figured there were people on RAS that might have information to say whether this would help or hurt the transmit "power" of a transponder. Instead of mounting a single antenna on the belly of the fuse where it can get beat up in the trailer, off field landings or just rocks and mud on the runway, what about a pair of antennas mounted on the side of the fuse on the tail boom similar to static ports. If you ran a single co-axial cable and then put a T at the end and then ran a short piece to each side of the boom then you'd have, in concept anyway, a good 360 "view". It may well be that antennas don't like this sort of arrangement so I figured I'd ask. Also has the obvious downsides of needing the factory to build this in to the plane and doubling your antenna costs. The benefit is that it does move the antenna farther from the pilot. |
One thing is for sure, there is a pretty sizable knowledge base
available via RAS on an incredibly wide array of topics. I think the general concept I had to move to two antennas on the side is vastly outweighed by the complications and I suspected as much. Think I'll just stick to the rod type below and either bend it back or replace it as needed. Gary Gary Emerson wrote: Had this random thought over the weekend. Figured there were people on RAS that might have information to say whether this would help or hurt the transmit "power" of a transponder. Instead of mounting a single antenna on the belly of the fuse where it can get beat up in the trailer, off field landings or just rocks and mud on the runway, what about a pair of antennas mounted on the side of the fuse on the tail boom similar to static ports. If you ran a single co-axial cable and then put a T at the end and then ran a short piece to each side of the boom then you'd have, in concept anyway, a good 360 "view". It may well be that antennas don't like this sort of arrangement so I figured I'd ask. Also has the obvious downsides of needing the factory to build this in to the plane and doubling your antenna costs. The benefit is that it does move the antenna farther from the pilot. |
My ASH-26E was in the final stages of assembly a couple weeks after
9/11/01 and as I got worried about the need for a transponder here in the US, asked the factory to install the antenna. The transponder is still on my birthday/Christmas wishlist.... In any case, I've been "stress testing" the simple rod antenna mounted just aft of the gear doors since the first flight at the end of 2001. It occasionally catches on the tail strap and sometimes the rear of the trailer if the ramp is too low. I've straightened it a few times, but now just leave it "streamlined" at about a 30 degree angle to vertical. Overall it's pretty sturdy and replacement is cheap, with excellent accessibility. Since the location is aft of the gear doors, they're producing some turbulence already, so I doubt the antenna as adding anything to the total drag picture. Might even be possible to cut the antenna near the base and put rejon with a strong spring to make it semi flexible. Any of you RF engineers care to comment on this? -Tom |
Reading the thread, I have two questions:
1. Is the signal picked up by ground stations and other planes significantly diminished if the antenna is mounted vertically somewhere along the top of the rear fuselage of a carbon glider, rather than behind the gear doors? If the ground station is off to the side, then it should pick up the signal OK, and manoeuvres should give a signal. Have any tests been done? This would be further from the pilot and less prone to trailer rash. 2. The thread discusses vertical polarisation. If a glider is thermalling at 45 deg or even 60 deg, with a vertically mounted antenna, is a suitable signal still picked up? A typical cross-country flight involves 20-50 percent of the time thermalling at a bank angle of over 30 degrees. Not much good if invisible for all this part of the flight! Rory |
![]() Gary Emerson wrote: Had this random thought over the weekend. Figured there were people on RAS that might have information to say whether this would help or hurt the transmit "power" of a transponder. Instead of mounting a single antenna on the belly of the fuse where it can get beat up in the trailer, off field landings or just rocks and mud on the runway, what about a pair of antennas mounted on the side of the fuse on the tail boom similar to static ports. If you ran a single co-axial cable and then put a T at the end and then ran a short piece to each side of the boom then you'd have, in concept anyway, a good 360 "view". It may well be that antennas don't like this sort of arrangement so I figured I'd ask. Also has the obvious downsides of needing the factory to build this in to the plane and doubling your antenna costs. The benefit is that it does move the antenna farther from the pilot. Besides the impedance matching problems, you will also be created unpredictable radiation patterns. This will probably create nulls (dead spots) in numerous directions. Might as well not install the transponder. Check out this web site for some examples: http://www.ee.surrey.ac.uk/Personal/...pantarray.html Tom |
with a strong spring to make it semi flexible. Any of you RF engineers care to comment on this? Bad idea. The spring is a very lossy coil. You would have to install a flexible wire inside of the spring to allow bending. That flexible wire is a bad antenna at this frequency, since rf flows on the surface. And, it would be inside of a lossy conductor. You can make the antenna flexible enough to withstand occasional bending, yet solid enough not to bend excessively in flight. The thread discusses vertical polarisation. If a glider is thermalling at 45 deg or even 60 deg, with a vertically mounted antenna, is a suitable signal still picked up? The quoted loss for using the wrong polarity only applies if you are exactly 90 degrees from the desired polarity. Anything in between is significantly less of a problem. As a matter of fact, when you are out thermaling, that very heat that keeps you up will also rotate the polarity of the transmitted signal. In addition to vertical and horizontal polarization, there is circular polarity. Circular polarity has the advantage that it is never more than 3 db down from either horizontal or vertical. Best advice is to just install the vertical so that it is more or less vertical and enjoy yourself. Gliders do not stay in one spot, so if you are nulled out for a second, you will probably be in the clear a second or two later. Colin |
The next issue of the ASA Newsletter will have an article
on how to construct a removable transponder rod antenna with a BNC twist lock connector for bottom mounts. Info on joining ASA can be found here - http://tinyurl.com/4c2sw |
Antenna problems | Mike Rapoport | Owning | 16 | February 9th 05 06:04 PM |
ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 03:27 PM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
transponder codes | Guy Elden Jr. | Piloting | 1 | December 2nd 03 05:21 PM |
Wanted: Transponder antenna | Grandpa B. | Home Built | 22 | November 28th 03 08:03 AM |
