Question on prop cycle
Old April 23rd 06, 09:14 PM posted to rec.aviation.owning
Default Question on prop cycle
Hi!
I was told by my mechanic to only pull the prop handle until I could audibly
hear a slight pitch change to establish that it was working.
However, the aircraft manual says it should be cycled completely, and on a
cold engine three times to make sure oil is applied to the governor, or the
pitch mechanism.
Can someone elaborate on this?
What is recommended?
Thanks,
Frode
Old April 23rd 06, 09:48 PM posted to rec.aviation.owning
On 04/23/06 13:14, Frode Berg wrote:
Hi!
pitch mechanism.
There's a very good article on AVWeb by John Deakin regarding engine
start and run-up, which includes a large section on prop cycling (near
the end of the article). You can find it he
http://www.avweb.com/news/columns/186619-1.html
Note: You have to register for access to AVWeb's articles, but it's
free, they there is a log of great information there.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old April 23rd 06, 11:17 PM posted to rec.aviation.owning
Go by the book recommendation.
The one thing you don't want to do is to let the RPM drop by more than
around 300 RPM. This puts undue load on the engine.
Old April 23rd 06, 11:30 PM posted to rec.aviation.owning
Are you serious? How much load can you put on an engine that's only
producing 10% power?
-Robert
Old April 24th 06, 01:18 AM posted to rec.aviation.owning
If that's the case you better never actually try to take off.
Old April 24th 06, 03:53 AM posted to rec.aviation.owning
Are you serious? How much load can you put on an engine that's only producing 10% power?
I think the engine is making more than 10% power at 2000rpm (fixed
pitch prop) during the runup. Don't know how much, but it's gotta be
more than 10%.
Old April 24th 06, 05:55 AM posted to rec.aviation.owning
Don't know how much, but it's gotta be more than 10%.
Maybe on a fix pitch, but I doubt it on a constant speed prop. It
doesn't take much power to bring a constant speed prop up to full RPM.
-Robert
Old April 24th 06, 12:05 PM posted to rec.aviation.owning
Nyaa, do it like some pilots at my airport do... Taxi out to the hold
short line, read the POH thoroughly word for word, dial every frequency
on all radios to be sure they are working, meticulously go over every
instrument on the panel, now that the exhaust valves are approaching
white hot go full throttle and cycle that prop at least twenty
times..... Then hang around the pilots lounge and whine about losing
another cylinder, "third one in the past 18 months.. I don't understand
it."...
Old April 25th 06, 12:38 AM posted to rec.aviation.owning
Hey wait, how do you cycle a fixed prop?
-Robert
Old April 25th 06, 06:36 AM posted to rec.aviation.owning
Just going by what I have read in many manuals, what I learned in
schools, siminars and from talking to factory reps.
Just follow the engine/airframe recommendations and you will be ok for
take off.
Why does a prop ice up so apparently readily? The Visitor General Aviation 0 November 8th 05 08:53 PM
Why does a prop ice up so apparently readily? The Visitor Piloting 0 November 8th 05 08:53 PM
Why does a prop ice up so apparently readily? Mike Rapoport Instrument Flight Rules 2 November 8th 05 02:52 PM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Sensenich Wood Prop Question [email protected] Owning 3 April 4th 05 02:32 PM
