When I select airspace B or C my screen turns completely
red or Blue... Class D airspace is ok but class B, C turns the screen red or blue and only the turnpoints are visible... Fl is set to FL200...Version 3.5a I tried everthing... LV Gregg Leslie |
Hi Gregg,
Are you referring to SeeYou or SeeYou Mobile? I recently found that I needed to uncheck the checkbox labeled "use colors as defined in file" with the latest version of the airspace file from SeeYou. You can find the checkbox in the Tools/Airspace window. In the same screen you can define whether the airspace types are filled or just outlined. I prefer to have the outlined only. Let me know if that doesn't solve your problem. -- Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Gregg Leslie" wrote in message ... When I select airspace B or C my screen turns completely red or Blue... Class D airspace is ok but class B, C turns the screen red or blue and only the turnpoints are visible... Fl is set to FL200...Version 3.5a I tried everthing... LV Gregg Leslie |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 01:51 AM |
| Negative XPDR - under the outer ring of Class C | bcjames | Piloting | 8 | August 31st 04 12:49 AM |
| Two airspace classes for one airspace? (KOQU) | John R | Piloting | 8 | June 30th 04 05:46 AM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 10:10 PM |
