C182 Fuel Problem
Old April 27th 06, 01:45 AM posted to rec.aviation.piloting
Default C182 Fuel Problem
Has anyone heard of a problem in earlier (1974) C182s where one fuel tank will draw down 3/4
before drawing from other tank when fuel selector in "Both" position? If so, any articles online?
Richard
Old April 27th 06, 02:34 AM posted to rec.aviation.piloting
"Richard Ross" wrote in message
will draw down 3/4
Yes. Cessna Pilots Association knows all about this. They have articles
online, but you have to be a member of CPA to view them. I think they're a
great organization. AVweb may have articles on this subject, too.
Old April 27th 06, 02:41 AM posted to rec.aviation.piloting
This is a common occurrence with older 182s. I understand that it is
due to the design of the venting system - that was supposedly corrected
in later models. I have read an article on the sugject, but don't
remember where I saw it.
David Johnson
Old April 27th 06, 07:55 AM posted to rec.aviation.piloting
Same problem on many Cessna high-wing singles. They have tried to place
the little, forward-facing vent just behind the strut, to minimize the
slight static pressure that develops in flight, but you'll still have a
faster draw from one side. In my experience, newer models are no better.
There are literally dozens of articles on the subject, and as many
proposals for fixes. Some of these are probably good, and you should do
some internet research if this is bothering you. My own fix is simply to
switch to right tank only once I'm in cruise, and manage the disparity
from there. Back to both, of course, in the pre-land checklist.
GF
Old April 27th 06, 03:09 PM posted to rec.aviation.piloting
Check the fuel tank cap seals. On that airplane they have
O-rings that are supposed to be checked yearly (there's an AD on it) to
prevent leaks, both water in and air out. The O-rings get old, hard,
and cracked. A leak on the right side will create a slightly lower
pressure that on the left, and the left tank will drain faster. A big
enough leak will suck a lot of fuel out of the tank and collapse the
bladder.
Cessna sells a kit to replace those caps with the style we see
on the 172, minimizing the problem.
We run three Cessna 172s, an R182 and two Citabrias, all
with the same venting system, and as long as we keep the seals tight
the fuel drains evenly. As soon as a cap develops a leak the uneven
drainage shows up.
The vent under the left wing bothers some people, as they
think the left tank gets more pressure than the right, but if things
are otherwise sealed the pressures are equal in both tanks (Boyle's
Law) and uneven drainage is more likely due to restrictions in the fuel
lines. When the tanks are full or near full there's some fuel movement
between tanks (left to right) through the vent interconnect, but
certainly not 3/4 of a tank's worth.
The fuel cap AD:
http://www.airweb.faa.gov/Regulatory...C?OpenDocument
AOPA's take on the 182 uneven fuel feeding:
http://www.cessna.org/store/buyers_g..._excerpts.html
AN exceprt from that excellent article: "This condition can be
minimized somewhat by adjusting the position of the fuel vent behind
the lift strut on the left wing, making sure that fuel caps seal
tightly so that the "head pressure" in one tank is not altered by a
leaking cap..."
Dan
Old April 27th 06, 04:30 PM posted to rec.aviation.piloting
On Wed, 26 Apr 2006 19:34:09 -0600, Jon Woellhaf wrote:
They have articles
I'm a [relatively new] CPA member. What's the best way to locate these
articles?
- Andrew
Old April 27th 06, 04:57 PM posted to rec.aviation.piloting
Richard,
What you are seeing is normal.
You will see many so called "fixes", but none of them address the fact that
most Cessnas have done this forever, even brand new, and will continue to. I
have ferried many new Cessnas from Wichita and they all did the same thing,
including a gorgeous A185E I bought new for myself.
If it bothers you or you get a heavy wing in flight just switch to the
fuller tank for a while. I've never heard of a Cessna running out of fuel
when "both" is selected and there was usable fuel in one wing .
That's not to say that you might not actually have a problem, like a
blockage in a vent line or something. I'm just saying that if you have it
checked out and they find nothing, don't worry.
Best,
Karl
ATP, CFI, ETC.
"Curator" N185KG
will draw down 3/4
Richard
Old April 27th 06, 06:51 PM posted to rec.aviation.piloting
"Andrew Gideon" wrote in message
news
They have articles
articles?
- Andrew
Log in and take the TechNotes link. Then take the TechNotes link. See
TechNote 003.
Old April 27th 06, 10:56 PM posted to rec.aviation.piloting
That problem is present on a 1986 'R' model that I fly, the FBO guy at a
nearby airport always comments on it when I stop by for cheap(er) fuel.
Hello, my name is Mike, and I am an airplane addict...
Old April 28th 06, 02:03 AM posted to rec.aviation.piloting
The 182R and 182S that I fly have the same habit.
Starting new C172s navghtivs Piloting 76 September 10th 05 09:33 PM
Running dry? Greg Copeland Piloting 257 August 26th 05 03:47 PM
Mandatory SB565 Lycoming fuel pump Paul kgyy Owning 18 March 22nd 05 03:22 PM
Most experienced CFI runs out of gas Robert M. Gary Piloting 54 November 19th 04 01:24 AM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
