I received a notice in the mail. It says,
"If your Lycoming engine has a diaphragm-type fuel pump with Lycoming P/N LW-15473 installed, and has a date code of 3201, the pump must be replaced PRIOR TO NEXT FLIGHT." The defective pumps were shipped from Lycoming between 10/1/01 and 2/2/04. It affects a wide range of engines from 320 to 540, IO, O, AIO, TO |
![]() Paul kgyy wrote: I received a notice in the mail. It says, "If your Lycoming engine has a diaphragm-type fuel pump with Lycoming P/N LW-15473 installed, and has a date code of 3201, the pump must be replaced PRIOR TO NEXT FLIGHT." The defective pumps were shipped from Lycoming between 10/1/01 and 2/2/04. It affects a wide range of engines from 320 to 540, IO, O, AIO, TO Here's the link to the full text : http://www.lycoming.textron.com/supp...tins/SB565.pdf It seems to have affected mostly injected engines (except a TO-320, TO-360 and 1 model of O-540). John Galban=====N4BQ (PA28-180) |
Paul kgyy wrote:
I received a notice in the mail. It says, "If your Lycoming engine has a diaphragm-type fuel pump with Lycoming P/N LW-15473 installed, and has a date code of 3201, the pump must be replaced PRIOR TO NEXT FLIGHT." The defective pumps were shipped from Lycoming between 10/1/01 and 2/2/04. It affects a wide range of engines from 320 to 540, IO, O, AIO, TO Was the notice an AD? If so, it would have a number like 2005-10-11 or something similar. I have not heard of one but you can search AD's he http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet One of the nice features is a listing of all the new AD's in the last 60 days. I checked the last 60 days against Lycoming (just cut the text from the browser and paste it into WordPad) and got nothing. So I doubt this is an AD. Now, if no AD has issued and you are a Part-91 operator (if you don't know whether you are or not - you are; if you were subject to Part 135, 137, 125, 121, etc you would have a certificate and manual, and boy would you know it...) then regardless of what Lycoming says, regardless of how the letter is worded, and regardless of all the FUD (Fear, Uncertainty, Doubt) that gets spread around - you are not grounded and you are not required to replace anything. Having said that, Lycoming is pretty famous for ****ty quality control (they just lost a major lawsuit where they tried to blame it all on a subcontractor) and I don't doubt that they've managed to make (more likely had a contractor make to their spec) a bunch of crappy fuel pumps. Most Lycoming engines have options other than Lycoming for a fuel pump. I suggest you look into replacing your Lycoming fuel pump with a non-Lycoming product. Michael |
Not an AD but an SB from Lycoming. Text:
"New, rebuilt and overhauled engines shipped from Lycoming between Oct 1, 2001 and Feb 2, 2004 with fuel pump P/N LW-15473..." You can read the rest at the link provided earlier and decide if you wish to comply at this time. And decide at what point this may become an AD. |
![]() "Blanche" wrote in message ... Not an AD but an SB from Lycoming. Text: "New, rebuilt and overhauled engines shipped from Lycoming between Oct 1, 2001 and Feb 2, 2004 with fuel pump P/N LW-15473..." You can read the rest at the link provided earlier and decide if you wish to comply at this time. And decide at what point this may become an AD. Yep. A mandatory service bulletin is designed to do two things... 1) Get the word out that there is or may be a problem. 2) Reduce Lycoming's liability. KB |
Kyle Boatright wrote:
Yep. A mandatory service bulletin is designed to do two things... 1) Get the word out that there is or may be a problem. 2) Reduce Lycoming's liability. If you're a commercial operator it has more meaning. |
On 2005-03-16, Michael wrote:
you are not grounded and you are not required to replace anything. And if you need an engine driven pump then you probably already have a backup electrical pump. Would there really be any need to replace the mechanical one before it wears out? -- Ben Jackson http://www.ben.com/ |
![]() Ben Jackson wrote: On 2005-03-16, Michael wrote: you are not grounded and you are not required to replace anything. And if you need an engine driven pump then you probably already have a backup electrical pump. Would there really be any need to replace the mechanical one before it wears out? Seeing as Lycoming is paying for the new pump and 1.5 hrs. of labor for the swap, it would be less than smart to take advantage of the deal and get rid of a potentially bad pump. "Why wouldn't you replace it?" would be a better question. John Galban=====N4BQ (PA28-180) |
![]() Michael wrote: snip In other words - Lycoming's offer is not particularly generous (certainly not up to what you would expect for a recall in the automotive world) and this will probably still cost you. OK, I'll agree that maybe Lyc.'s offer of 1.5 hrs won't cover the labor on some planes. It will on mine (BTDT). As compared to automotive recalls, you're right, but in my experience, the majority of aircraft S.B.s that I see don't offer any compensation from the manufacturer (unless the part or plane is still under warranty). In that respect, I'm pleasantly surprised. John Galban=====N4BQ (PA28-180) |
Night flying in the mountians in a cessna 150, | NW_PILOT | Instrument Flight Rules | 150 | March 4th 05 06:13 PM |
Night flying in the mountians in a cessna 150, | NW_PILOT | Owning | 135 | March 4th 05 06:13 PM |
Night flying in the mountians in a cessna 150, | NW_PILOT | Piloting | 149 | March 4th 05 06:13 PM |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
