Birds on the Tail
Old May 8th 06, 04:09 PM posted to rec.aviation.owning
Default Birds on the Tail
I'm surprised that I have not been able to find much on Google on deterring
birds on the tails of GA aircraft. Maybe I haven't found the magic search
terms yet. Anyhow, has anyone tried this or anything similar with any
success? http://www.absolutebirdcontrol.com/b...er.htm?ABS=BBG. I have
visions of wind meter-type of spinner (with the little cups) lightly-clipped
near the top of the tail but I worry about leaving it on by accident.
A tie-down neighbor has an owl perched on a high pole attached to a weighted
base. His Mooney's tail seems crap-free but I still need to verify its
effectiveness. Maybe I can put the Bird Spider on a similar contraption. I
saw an older post by Margy Natalie about using old CD's or the scare ball
but I'm unsure of the mounting options.
Thanks,
Marco
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old May 8th 06, 08:13 PM posted to rec.aviation.owning
Since there is more than one product on the market, you know that none
of them are the magic answer..
denny
Old May 9th 06, 02:07 AM posted to rec.aviation.owning
Not related to aviation, but once I had a problem with bird droppings
associated with a yagi type antenna
on a ship. I solved it by installing a windmill (made from anemometer
parts) above the antenna. Worked like a charm - so that is definitely a
valid approach.
Once I saw a plane with one of those plastic owls mounted on one of the
prop tips (which was positioned vertically). Don't know how well it
worked, since it wasn't at my home airport, and I never saw the plane
again.
David Johnson
Old May 9th 06, 04:04 PM posted to rec.aviation.owning
If there was only one product on the market then I would have my answer. I
would also have the motive to start a new business venture...
Marco
"Denny" wrote in message
denny
Old May 9th 06, 10:08 PM posted to rec.aviation.owning
I have a pair of real live owls that roost atop my
ham antennas. I have plenty of little birds that vist
the trees below and use my patio as their toilet.
But, I only see the owls on their roost late at night.
Have not seen any mice around in a long time, though.
Although I would not want to man the post 24 x 7, a
Red Rider BB gun might get the message across to
those pesky tail squatters. Aim carefully so as not to induce
'hail damage' on the vertical tail sections :-)
Ronnie
"Marco Leon" mmleon(at)yahoo.com wrote in message
deterring
lightly-clipped
weighted
Thanks,
Marco
Old May 10th 06, 12:53 AM posted to rec.aviation.owning
On Mon, 8 May 2006 11:09:51 -0400, "Marco Leon" mmleon(at)yahoo.com
A shot gun is just the ticket. Get the largest gage you can handle
and open choked. Use fine shot as it doesn't carry as far as buckshot
and limits collateral damage. As to collateral damage, if the
unthinkable should happen, tell the insurance company it was a very
localized hail storm.
However this does have some hidden drawbacks. Keep an eye out on the
near by hangars. Be careful is you see suspicious groups lurking
about carrying rope, or bringing in buckets of tar and down filled
pillows. Also keep an eye out for airport managers and strange
padlocks on your hangar door. Also watch for live skunks in your
hangar, limburger cheese in the heater or just on the manifold some
times shows up as well.
Mount it in place of the rotating beacon while letting the light shine
out its eyes.
According to amateur radio acceptance to really keep the birds away
the owl must face true north.
www.rogerhalstead.com
Thanks,
Marco
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
fatal bird strike StellaStar Piloting 9 July 13th 03 09:41 PM
