Learning from an owner annual
Old May 14th 06, 07:11 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Learning from an owner annual
After 6 years of Mooney ownership I'm doing my first owner assisted
annual. Most of my previous annuals have been done by factory service
centers. I'm quite a good wrench around cars so this experience is
mostly about me learning the standards & practices of aircraft work.
I'm amazed by a couple things...
1) The number of things I found that were not done that I'd paid to
have done at previous annuals.
2) The number of things done wrong (like no cotter key in the wheel).
3) The amount of work an annual really requires. It took me 6 hours
just to remove all the inspection panels (including drilling out
several dozen screws). Lubing the 150 lube points wont go too quick
either.
Its also interesting to me how many things are safety wired while other
things (that seem more important) are not. Brake calapers are safety
wired but fuel lines are not, etc. Its quite depressing to see my plane
in so many pieces. I've also discovered that its extreamly irritating
that the aircraft parts places are closed on weekends.
I would highly recommend this experience to any aircraft owner who is
comfortable with a wrench.
-Robert
Old May 14th 06, 07:48 AM posted to rec.aviation.piloting,rec.aviation.owning
Good maintenance takes time and time equals money. There is
too much poor maintenance, sometimes because the aircraft
owner just doesn't have the money to do the work and
sometimes because the shop, trying to keep cost down cuts
corners. All aircraft owners should have the basic library
of the shop manuals and FAA regs in parts 43 and 91. The
FAA manual 43.13 [latest edition and all parts] as well as
some of the mechanics handbooks that are on the commercial
market will help the owner do a better job and save money
[and maybe lives] in the long run.
You will understand more about your airplane, why certain
parts are cheaper to replace anytime you have access to
them, such as alternator belts when the prop is off. You'll
know why it costs $30 in labor to put 15 cents worth of
grease in a landing gear bushing.
As you're doing the owner assisted annual, have the A&P
point out the things you can do as an owner as preventative
maintenance and how to make the logbook entry. Things like
lubrication and cleaning, replacing light bulbs and such
will save you money and reduce wear and tear on the
airplane. You have to use the right grease and oils, not 3
in 1 from the grocery store. You can also get some aircraft
grade cotter pins and safety wire and replace those that are
damaged or missing.
Buy your A&P some of his favorite ______ or take him [and
maybe his wife too] to a nice place to eat, like Outback or
whatever is good locally. Say Thank You, mechanics don't
hear that often enough.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
assisted
factory service
experience is
aircraft work.
I'd paid to
the wheel).
me 6 hours
drilling out
too quick
| either.
wired while other
are safety
see my plane
irritating
owner who is
| -Robert
Old May 14th 06, 11:35 AM posted to rec.aviation.piloting,rec.aviation.owning
-Robert
I couldn't agree more. Knowing more about the aircraft systems will make
you more aware of potential problems. You'll be a safer pilot because you
inspect and test things more intelligently.
Old May 14th 06, 11:37 AM posted to rec.aviation.piloting,rec.aviation.owning
Yep, I found that when I got started, too. (I recently finished my 8th
owner-assisted annual)
Yep. And wires poorly routed in the engine compartment. And heat
ducts carpeted over. The list was fairly extensive.
This seems odd, Robert. Is your plane parked outside? Why would those
inspection panel screws be so corroded? Unless...were they never
removed recently? (More work undone-but-paid-for?)
I strip a fair number of screws every year -- but I've NEVER had to
drill any out on either of the planes we've owned.
What I like is when you have everything in neat little tupperware cups
underneath the appropriate parts of the plane -- and then the shop
moves the plane. Or they pull an extension cord under your plane, and
lasso all the parts buckets. Or they get kicked over. THAT is my pet
peeve about doing an annual.
Agree 100%. I have a voluminous knowledge of the inner workings of my
aircraft, solely because of doing the owner-assisted annuals.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 14th 06, 02:08 PM posted to rec.aviation.piloting,rec.aviation.owning
Buy a [big] box or two of slide-lock baggies, put the
parts, with a label and tape them to the area near the
inspection cover. You can even add notes to yourself or the
other mechanic who is working on the airplane.
I've heard of owners replacing the standard fasteners with
nice shiny stainless steel screws. Trouble is you can get
dissimilar metal galvanic reactions and then you have to
drill them out.
James H. Macklin
ATP,CFI,A&P
some support
"Jay Honeck" wrote in message
I'd paid to
finished my 8th
in the wheel).
And heat
me 6 hours
drilling out
Why would those
they never
NEVER had to
tupperware cups
the shop
your plane, and
THAT is my pet
owner who is
workings of my
annuals.
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
Old May 14th 06, 02:27 PM posted to rec.aviation.piloting,rec.aviation.owning
That will work too. One thing to avoid is taking a cover
plate off and leaving it swung aside and fastened with one
screw. You'll certainly walk into it or catch a sleeve and
bend the part and maybe injure yourself or the airplane.
You can use a Sharpie to write on the back of inspection
covers and such, the name and location of each part. You
can tag wire but taking digital photos as you go along is
easy and besides it documents the work as well as locating
the parts.
The key is a system.
James H. Macklin
ATP,CFI,A&P
some support
"B A R R Y" wrote in
message ...
| On Sun, 14 May 2006 08:08:12 -0500, "Jim Macklin"
| Another suggestion:
| Our guy has a bunch of "Tupperware" or fishing tackle
style divided
| organizers. We drop the fasteners in those and label the
top with a
| Sharpie (ex:// RT wing tip, fwd belly panel, etc... over
each
| compartment) and the tail number (there's more than one
plane in the
| hangar). After each plane is complete, the mechanic wipes
the tops of
| the containers with alcohol, removing the marker for the
next plane.
Old May 14th 06, 02:33 PM posted to rec.aviation.piloting,rec.aviation.owning
On 14 May 2006 03:37:06 -0700, "Jay Honeck"
Dude, you really need to take a good look at the underside of a
Mooney, especially an older one. You just "think" a PA28 has a lot of
screws. Unless things have changed a whole bunch, they are mostly
countersunk machine screws, opposed to your universal head PK screws.
Really ups the temptation for a tech/owner to use power tools to crank
the **** out them when closing up. Makes me shudder just thinking
about it..
Mine is wheels off for inspection, somebody steps on the pedals and
blows out the wheel cylinder pistons.
In my case, the transition from allegedly mucho-experienced tech to
private pilot was definitely made a lot easier by having in-depth
knowledge of aircraft systems.
TC
Old May 14th 06, 04:22 PM posted to rec.aviation.piloting,rec.aviation.owning
screw.
I don't think that can happen on a Mooney. The access panels are inches
off the ground. There almost was not enough room for both me and the
drill to work under the plane at the same time.
Old May 14th 06, 04:31 PM posted to rec.aviation.piloting,rec.aviation.owning
For those that do owner assisted annuals now, how do you compensate the
mechanic for misc things like the use of his tools, use of misc parts
(screws, fluids, etc)? Do you pay a flat shop use fee? Do you just make
sure to put something extra in his hourly fee for the work he did? Its
amazing to me how generous A&Ps are to open their tool box to pilots.
In the automotive maintenance world, if you touch a mechanic's tools
you'll probably get hit upside the head. Loaning out tools is almost
unheard of with cars.
-Robert
Old May 14th 06, 04:33 PM posted to rec.aviation.piloting,rec.aviation.owning
corners.
Well you can't get more expensive than the factory service centers I'd
been using. I no longer believe in the top dollar = good maintenance
anymore. When you're paying $105/hr for a $12/hr kid to replace your
access panels and he installs the antennas all backwards, you figure
money doens't necessarily equal good work.
-Robert
2006 Annual -- My 8th Owner Assisted -- Update Jay Honeck Owning 14 March 27th 06 07:11 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
