PA-32 Weight and Balance
Old May 18th 06, 11:58 AM posted to rec.aviation.owning
Default PA-32 Weight and Balance
Has anyone ever been able to put 6 adults in a Saratoga without exceeding
the aft CG?
So far, every time I run the numbers with two adults in the aft two seats, I
exceed the aft CG.
Old May 18th 06, 01:35 PM posted to rec.aviation.owning
In article NrYag.44229$iF3.30882@dukeread01,
the aft CG?
exceed the aft CG.
It depends on just how big your adults are.
If you are talking about overweight males, the answer is no. You will
probably get five, but be sure to calculate a landing CG to assure that
the CG has not gone aft of limits for landing. If you are taking
baggage, you can play with who sits in the center row of seats and
baggage in the nose compartment to shift things forward.
Old May 18th 06, 07:12 PM posted to rec.aviation.owning
Unless you put overweight males in the front, too.
Old May 19th 06, 02:54 AM posted to rec.aviation.owning
"john smith" wrote in message
the aft CG?
seats, I
exceed the aft CG.
Does anyone have an electronic weight and balance for PA-32 ?
Old May 19th 06, 03:39 AM posted to rec.aviation.owning
Do you mean a spreadsheet?
Old May 19th 06, 04:59 AM posted to rec.aviation.owning
In article _y9bg.44290$iF3.6732@dukeread01,
the aft CG?
seats, I
exceed the aft CG.
It is easy to build one up, using excel. All you need to do is list all
the weights, their arm, multiply weight by arm, sum up the moments and
divide by the sum of the weights.
It is easy to build sample gross weight scenarios and loadings expected
on typical trips.
Old May 19th 06, 05:15 AM posted to rec.aviation.owning
the aft CG?
seats, I
exceed the aft CG.
CoPilot flight planner for the Palm PDA has a customizable W&B you can
apply to any A/C.
The graphical display will show ramp, take off, landing, and no fuel for
a flight.
Jim Pennino
Remove .spam.sux to reply.
Old May 19th 06, 05:29 AM posted to rec.aviation.owning
I do not believe that will help
"Mike Granby" wrote in message
Old May 19th 06, 09:12 AM posted to rec.aviation.owning
Saratoga FG: http://www.wvfc.org/craft/83763.html
Saratoga RG: http://www.wvfc.org/craft/432lt.html
I played around with the numbers, and the Saratoga FG is pretty
easy to get outside the aft limit. On the RG, even with just an
FAA standard 170 lbs pilot, no baggage, and 450 lbs in the rear
seats, it is just within the aft CG.
YMMV,
John
John Clear - http://www.clear-prop.org/
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Pocket PC Weight and Balance Spreadsheet Navzilla Support Piloting 0 October 9th 05 11:47 PM
Cessna 172 F Weight and Balance [email protected] Owning 8 September 22nd 05 02:38 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
