PA-32 Weight and Balance
Old May 19th 06, 12:46 PM posted to rec.aviation.owning
Default PA-32 Weight and Balance
Orval Fairbairn wrote:
It is easy to build sample gross weight scenarios and loadings expected
on typical trips.
I did the same for our Sundowner. You can also put several versions of
the sheet on one page to display calculations for different seatings,
takeoff, landing, etc... side by side.
If you add the POH data on it's own tab, VLOOKUP or HLOOKUP can read the
charts. Conditional formatting is nice to alert the user to out of
limits results.
Old May 20th 06, 04:38 PM posted to rec.aviation.owning
"john smith" wrote in message
Does anyone have an electronic weight and balance for PA-32 ?
Do you mean a spreadsheet?
Yes.
Old May 20th 06, 05:34 PM posted to rec.aviation.owning
Yes.
Do you know how to enter equations into spreadsheet cells?
Old May 20th 06, 06:37 PM posted to rec.aviation.owning
"John Doe" wrote in
news:_y9bg.44290$iF3.6732@dukeread01:
I downloaded a free program, AvInfo written by Karl Medcalf, that
calculates and graphically displays your weight and balance. It runs
on Windows and has several features I like: Weights can be named
(i.e., Pax names), Graph can show your specified maximum landing
weight, several aircraft data can be kept by registration number. It
does require a bit of setup but the associated documentation is clear
enough to get you through it.
See: http://users3.ev1.net/~medcalf/avinfo.html
Old May 23rd 06, 01:03 AM posted to rec.aviation.owning
John Doe wrote:
Has anyone ever been able to put 6 adults in a Saratoga without exceeding
the aft CG?
So far, every time I run the numbers with two adults in the aft two seats, I
exceed the aft CG.
Depends also on the model year. You have to work at it to get my '65
PA32-260 out of the CG envelope. Two 240 lb people in the back seats, a
180 lb pilot and no luggage is still within the envelope, although just
barely as long as there is at least 39 gallons of fuel on board. The
front CG limit on mine is even harder to hit: with the maximum 100 lbs
in the front baggage, and two 250 lb people in the front seats, it is
still within the front CG limit.
I believe the rear seats got moved a few inches aft in later model
years, and that the tapered wing has a smaller CG envelope than the
hershey bar wing.
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Pocket PC Weight and Balance Spreadsheet Navzilla Support Piloting 0 October 9th 05 11:47 PM
Cessna 172 F Weight and Balance [email protected] Owning 8 September 22nd 05 02:38 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
