Why is a standard hold right turns?
Old July 9th 04, 04:31 PM
Icebound
"Stan Gosnell" wrote in message
... Flying from the
left seat has never made any sense at all to me. ...
Exactly. Boats have their helm on the right, so that helmspersons (choke)
can more easily observe the traffic in their "give-way" zone, the RIGHT.
Its the same rules for aircraft, but from the left seat you have a much more
restricted view of that side.
  #43
Old July 9th 04, 07:28 PM
Roy Smith
In article
e.rogers.com,
... Flying from the
Some boats have their helm on the right. Generally small powerboats.
Larger boats tend to have them on the centerline.
Launches (the small powerboats that take people from a dock out to a
boat on a mooring) almost always have the helm on the left (port) side.
Why? Because they come up to the starboard side of the moored boat, and
it makes it easier for the launch driver to be on the port side, towards
the boat he's approaching. Why do they come up to the starboard side of
the moored boat? Well, I'm not sure, but the explanation I've heard is
that the head (i.e. toilet) discharge is usually on the port side, which
seems like a pretty good reason to me.
Boats often have multiple helm stations. Sometimes there's one up on
the flybridge for use in good weather, and another down below where you
can stay warm and dry. Workboats often have a secondary helm station
near the stern, so you can control the boat while back there pulling in
fishing nets or whatever.
  #44
Old August 24th 04, 09:59 PM
Walter Ellison
Nobody ever mentioned a twin engine aircraft, so this is my guess. In a
twin, where both engines turn in the same direction, there is a slight
asymmetry to the thrust vector, I believe, slightly to the right side of the
airplane. If you were in a turn, at low speed, and you lost and engine, you
would rather be turning into the engine with the power than away from it.
But since you don't know which engine is going to fail, you would rather
turn into the thrust vector than away from it. That's my theory.
"Roy Smith" wrote in message
It has always struck me odd that a standard landing pattern is left
turns and a standard hold is right turns. Having a left patterns for
landing makes a bit of sense, since the pilot is on the left side of the
cockpit and has a better view of the runway making left turns.
But, for IFR holds, there doesn't seem to be any advantage to one way or
the other. Why did they pick right turns to be standard?
  #45
Old August 25th 04, 06:23 AM
Herbert Paulis
VFR hold = left as pilot usually sits on left side and has better view
though
IFR hold = right 1) to better separate from VFR hold 2) no actual need to
look out, esp. in IMC
regards
Herbert
PPL ASEL
IFR student
ardent Cessna lover (172+182)
"Walter Ellison" wrote in message
link.net...
you
  #46
Old August 25th 04, 04:54 PM
Kevin Chandler
In a twin the thrust line is slightly to the right when climbing, just like
a single, which makes the plane yaw left, just like in a single. The left
engine in a twin is the "important" engine. If you lose an engine, you
prefer it not to be the left one. Turning into the one good engine is about
the most difficult thing to do in a twin. If you lose the left engine, it
might take all of your right rudder just to keep it going straight. You
probably don't have enough to perform a right hand turn. It is probably
easier to do a 270 degree left turn than a 90 degree right turn. I don't
think the right hand turns associated with a hold have anything to do with a
twin.
link.net...
you
  #47
Old August 25th 04, 05:38 PM
Newps
In most twins. However there are some that have no critical engine and
some that have both engines as critical.
  #48
Old August 25th 04, 08:55 PM
Steven P. McNicoll
"Herbert Paulis" wrote in message
though
Where did you find that information on VFR holding? How would opposite
directions aid in separating VFR from IFR aircraft?
  #49
Old August 25th 04, 10:14 PM
Kevin Chandler
I know that some planes have counter-rotating engines for the right side;
however, I never knew that planes existed with both engines critical. Are
you saying the counter rotating goes on the left and a normal engine on the
right? Is so, why???? What benefit would there be in that?
Just curious and learning something new everyday.
Kevin
  #50
Old August 26th 04, 01:00 AM
Mike Rapoport
What he is implying is that in some twins you have a major problem if you
lose either engine.
Mike
MU-2
"Kevin Chandler" wrote in message
Kevin
IFR hold short line at uncontrolled airports? Peter R. Instrument Flight Rules 30 June 9th 04 04:47 AM
Hold at VOR for 2v2 Doug Instrument Flight Rules 21 May 27th 04 11:42 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
Random Hold Generator... Tina Marie Instrument Flight Rules 0 November 5th 03 04:21 PM
Need Hold Harmless Waver for Ultralight or Experimental Sale Larry Smith Home Built 9 August 19th 03 02:47 AM
