Learning from an owner annual
Old June 14th 06, 05:03 PM posted to rec.aviation.piloting,rec.aviation.owning
Default Learning from an owner annual
THAT is OSH, to me, now. The airshows and stuff are still fun, but the
North 40 is what grass-roots aviation is all about. So, we try to
make sure that Atlas is in tip-top shape every July, for that long, 90
minute flight back to Wittman Field...
And we couldn't party in the parking lot
You've never tail-gated before?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #82
Old June 15th 06, 12:28 AM posted to rec.aviation.piloting,rec.aviation.owning
at OSH? NEVER
  #83
Old June 15th 06, 02:40 AM posted to rec.aviation.piloting,rec.aviation.owning
Shouldn't that be tail-Gator'ed?
  #84
Old July 4th 06, 08:48 PM posted to rec.aviation.owning,rec.aviation.piloting
Default Stuck Screws, was: Learning from an owner annual
Back when I used to work on airplanes as an avionics tech, someone showed me
a neat trick for getting stuck screws loose. When you find a screw that
doesn't want to come loose, or that the screwdriver tip cams out of, put a
little valve grinding compound on the screwdriver tip. Valve grinding
compound comes in a tube at auto parts stores, and has a fairly coarse grit
in it. It gives your screwdriver tip much better traction in a screwhead
that's already been a little damaged, and does a great job of preventing the
screwdriver tip from camming out. There's also something similar available
called "Screw Grab" that I found at a hardware store locally, that has the
same grit in it but in a thinner solution. It works just as well. I rarely
have to drill out screws since I started using those compounds.
Scott Wilson
  #85
Old July 4th 06, 10:26 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter Duniho
wrote in message ...
[...] Valve grinding
grit
I'm sure you'll get replies saying (in effect) "you didn't know that?" But
thanks for posting the tip anyway. Lots of the rest of us didn't know it
either.
  #86
Old July 4th 06, 11:18 PM posted to rec.aviation.owning,rec.aviation.piloting
John Kimmel
grit
either.
The Phillips ACR bit sold by Snap-On has serrations which reduce "cam-out".
John Kimmel
remove x
"He's dead, Jim."
2006 Annual -- My 8th Owner Assisted -- Update Jay Honeck Owning 14 March 27th 06 07:11 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
