#21
Doug wrote:
Depends on the grass. Grass strips vary from putting green smooth to plane riping holes, rocks and logs. Examine grass beforehand. Funny, I've never seen a grass landing strip that had rocks and logs. If you are landing off-airport that is certainly a possibly, but the subject clearly says airstrip, just random field out in the middle of nowhere. Matt |
A Lieberman wrote:
On Sat, 17 Jun 2006 18:14:25 +0100, Quilljar wrote: No difference, just land normally... Incorrect advice..... You want to land as softly and as slowly as possible on a grass strip. Baloney. He didn't ask about landing on a soft field, he said a grass airstrip. Grass doesn't imply a soft field at all. Also want to keep the nosewheel off terra firma as long as possible so it doesn't run the risk of "digging in" from the weight of the engine and prop when the nose wheel does touch down. Again, only if this is a soft field. Grass strip isn't synonymous with soft field. If you don't know the difference, I suggest some remedial instruction. After touchtown, the yoke should be full aft. This is true for all landings :-) Taxiing on soft fields is also significantly different. You hold the yoke back full aft and taxi with more power to ease the pressure of the nose wheel. Right, but he didn't ask about a soft field. Matt |
drclive wrote:
Can anybody point out a good bibliography or article that describes the differences in landing on a grass airstrip for the first time, tips and advices? Thanks Actually, I find my landings are better on grass that hard surface. I feel real good then go to my homme airport with asphalt and do terrible. A friend of mine has a 3000' E/W grass strip right up on a lake. Fun to fly in and out of. However, you have to watch landing in the evening to the west. The sun will blind you. Because of the upslope, protocol is to land up hill to the west and take off downhill to the east and over the lake, unless the wind is such that that you should use the appropriate runway. 90% ofthe time the wind is out for the south. -- Regards, Ross C-172F 180 hp KSWI |
Ross wrote:
drclive wrote: Can anybody point out a good bibliography or article that describes the differences in landing on a grass airstrip for the first time, tips and advices? Thanks Actually, I find my landings are better on grass that hard surface. I feel real good then go to my homme airport with asphalt and do terrible. A friend of mine has a 3000' E/W grass strip right up on a lake. Fun to fly in and out of. However, you have to watch landing in the evening to the west. The sun will blind you. Because of the upslope, protocol is to land up hill to the west and take off downhill to the east and over the lake, unless the wind is such that that you should use the appropriate runway. 90% ofthe time the wind is out for the south. I agree. I love landing on grass. In the C150 I learned in, I could hear and feel the blades hitting the tires and knew just when touchdown was going to occur. It made for consistly smoother touchdowns. Also, grass is much easier on the tires and brakes. Matt |
A Lieberman wrote:
On Sat, 17 Jun 2006 18:34:42 GMT, Matt Whiting wrote: drclive wrote: Can anybody point out a good bibliography or article that describes the differences in landing on a grass airstrip for the first time, tips and advices? Thanks What sort of differences? Landing on grass isn't much different than hard surface unless the grass is very tall, very wet, or hiding mud. :-) I'd have to disagree with you on this. It also depends on the soil composition. If it's clay and dry and hard as concrete, yes, no difference other then the grass that you describe above. If it any other type of soil composition where the weight of the plane may sink a little, then soft field take off and landing techniques are in order (yoke full aft when on ground and prop is turning). See my other postings on the technique. Allen See earlier message of mine on landing on grass, but one should always know the soil of the intended grass runway and taxi with the yoke full back. The 3000' field I mentioned is in perfect condition. But I have been on some that are very rough. This field will drain quite nicely, but there are soft spots that you need to know about. We had to push a Warrior out of the soft spot one time. He was trying to taxi out with full power and four adults in the plane. We got him to get the other three out and with a little engine and pushing in the right spots he got out. -- Regards, Ross C-172F 180 hp KSWI |
A Lieberman wrote: How does one do this from pattern altitude at an airport they have never been to? With a low, slow pass a little to one side so you can see the landing area. Quite a common practice for those who land on other than prepared surfaces. |
#28
You are the second person who can't distinguish between a grass strip and a soft field.
Yanno, a grass strip should be treated as a soft field unless you know otherwise. An unfamiliar grass strip can hide problems that an unfamiliar asphalt strip would not. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#29
Ross wrote:
A Lieberman wrote: On Sat, 17 Jun 2006 18:34:42 GMT, Matt Whiting wrote: drclive wrote: Can anybody point out a good bibliography or article that describes the differences in landing on a grass airstrip for the first time, tips and advices? Thanks What sort of differences? Landing on grass isn't much different than hard surface unless the grass is very tall, very wet, or hiding mud. :-) I'd have to disagree with you on this. It also depends on the soil composition. If it's clay and dry and hard as concrete, yes, no difference other then the grass that you describe above. If it any other type of soil composition where the weight of the plane may sink a little, then soft field take off and landing techniques are in order (yoke full aft when on ground and prop is turning). See my other postings on the technique. Allen See earlier message of mine on landing on grass, but one should always know the soil of the intended grass runway and taxi with the yoke full back. Even when taxiing back after landing into a 30K headwind? Matt |
#30
Jose wrote:
You are the second person who can't distinguish between a grass strip and a soft field. Yanno, a grass strip should be treated as a soft field unless you know otherwise. An unfamiliar grass strip can hide problems that an unfamiliar asphalt strip would not. You should familiarize yourself with any runway before landing on it. And asphalt can hide problems that grass doesn't (black ice for one). Matt |
Nevada County (Grass Valley) Airport - local transport? | bk | General Aviation | 2 | January 26th 05 11:51 PM |
Greasy Grass | George Shirley | Naval Aviation | 1 | October 30th 04 06:20 PM |
Mooney M20 K on Grass ? | vfr2003 | Owning | 10 | August 18th 04 04:18 PM |
Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 03:00 PM |
Buildng a grass airstrip | Yosef Mendelsohn | General Aviation | 3 | May 13th 04 05:44 AM |
