Mooney M20 K on Grass ?
Old August 13th 04, 10:02 AM
vfr2003
Default Mooney M20 K on Grass ?
Hi,
I'm interested to buy a Mooney M20K. But the airfield I use is grass airfield.
Do you think that Grass is ok with a M20K or it's dangerous ?
Thanks a lot.
(I must take a decision in few days ... )
Mike.
Old August 13th 04, 01:44 PM
Al Marzo
A friend has an "E" and he doesn't want it on grass. Last year at OSH
we walked through the Mooney camp and he pointed out how low the gear
doors were to the ground. Any little hole hit would obviously cause
damage. From what I've read on a recent thread, Mooney did raise it,
but you'll need to find out which model.
On 13 Aug 2004 02:02:19 -0700, (vfr2003) wrote:
Hi,
Thanks a lot.
Mike.
Old August 16th 04, 03:56 AM
Ron Rosenfeld
On 15 Aug 2004 11:08:58 -0700, (Robert M. Gary) wrote:
I don't think that is true. On the M20E you simply have the single
plate gear door attached to the gear itself. On the J-K's you have
another gear door extension that further reduces the distance from
bottom of tire to gear door. I would say any grass longer than 1"
would tear up the gear door. I have seen J model owners remove that
extra door and achieve the clearance of an E model Mooney.
I've landed my Moony on the beach in Mexico and gravel in Canada but
would never consider landing it on grass. I have hundreds of grass
landings in other planes, but wouldn't consider doing it in my Mooney.
You may be correct about the gear doors, although there are speed mods that
put the extra door on the earlier models. I have the older donuts (still)
so thought my prop clearance (9") was a bit less than the K's.
In any event, I,too, would not land the Mooney on long grass, but I've been
into Katama, Gaddabout Gaddis, Lubec and Basin Harbor a number of times as
well as other fields. But as I said, I do call before hand to ensure the
field is in good shape.
I'm interested in your landing on gravel and beach experiences. We've got
a temporary gravel taxiway in place here in EPM (while the main taxiway is
being reconstructed), and I've been unwilling to even taxi on it for fear
of picking up the stones with the prop. Could you tell me more about those
surfaces you've been on?
--ron
Old August 16th 04, 02:28 PM
Maule Driver
Just to add another thought.... (I have limited Mooney experience/knowledge)
operating occasionally on grass may be different than basing on grass. You
will always have 'bad' grass days on occassion if you base on it. Given the
need to go or get home, you will be sorely tempted to operate on such days
(i.e. mud, soft, or uncut).
Another issue may be insurance if you are basing on grass.
I live on 3400' of grass with trees on both ends and would never consider
owning a Mooney for that reason, even though that would otherwise be my
first choice for a retractable.
Old August 16th 04, 03:11 PM
Dave Butler
Another data point, FWIW. I've never landed my J model on grass, but have
taxied on some pretty rough grass on a couple of occasions, like getting from
the runway to my camp site at OSH. I'm always nervous about it, but have yet to
see any damage. Limited data, 'cause it's not something I do very often. I may
just have been lucky. I'm still going to be nervous when I do that.
Dave
Old August 17th 04, 07:18 PM
Robert M. Gary
Ron Rosenfeld wrote in message . ..
The beach was Alphonsinas in Baja. The beach is actually quite hard
and as long as you avoid the pot holes left by the trucks driving on
it, its almost like landing on a hard surface. I use a technique for
softfield in the case of the beach or gravel. I choose the best spot
for the mains when I do my low pass. On short final I trim the trim
all the way back and push forward on the yoke to hold attitude (the
Mooney is unusual in that back trim actually increases the available
back elevator authority). Once the mains hit (with the nose very high)
I add in some power and can hold the plane on the mains with the nose
very high. Once I find where I want the nose to be, I chop the power.
For takeoff, I do similar. I run the trim all the way back (or 3/4 if
back pax). Hold full back elevator. The nose will pop up pretty quick
on the take off roll (most people have never seen a Mooney's nose pop
up before ). You must be comfortable driving around on only the
mains because the plane isn't anywhere near flying speed. The goal is
to keep the prop as high as possible. I always practice soft field
techniques before going down to Mexico. Most Mooney pilots just land
normal so I'm not sure the condition of their props and gear in
Mexico.
-Robert
Old August 18th 04, 04:17 PM
Ron Rosenfeld
Mexico.
-Robert
Well, that's pretty much what I do going into soft fields -- but they've
all been grass.
On a related note, my IA flew me back to EPM after I dropped my Mooney off
for it's annual. We were in a C172. He took one look at our temporary
gravel taxiway and said no way was he going to taxi on it.
I guess there's gravel and then there's gravel. (Just like there's grass
and then there's grass).
--ron
Mooney drops into my backyard Dave Butler Owning 41 May 11th 04 10:19 PM
10 1/2 Acres Hill Top, 8 miles from Mooney - airport, Kerrville, Texas David Aviation Marketplace 0 March 17th 04 12:44 AM
Mooney info eddie Owning 13 March 12th 04 06:42 PM
Mooney to Offer Light Sport Airplane Rick Pellicciotti Home Built 4 September 24th 03 01:08 PM
Cirrus vs Mooney Charles Talleyrand Owning 6 July 8th 03 11:35 PM
