Corrosion X
Old June 19th 06, 01:22 PM posted to rec.aviation.owning
Default Corrosion X
On Sat, 17 Jun 2006 01:27:53 -0400, Roger
On 16 Jun 2006 04:02:32 -0700, "Denny" wrote:
This is not rocket science... Bubba the mechanic can do this one... Get
some ACF-50 and a sprayer with a long nozzle, put on your common sense
hat and you and Bubba go for it...
LPS-2 also works. Just don't have this work done in the winter. Once
the temperature comes up, it'll drip for two weeks in the hot sun.
Don't you mean LPS 3? LPS 2 is a lube, LPS 3 is much thicker and is
a corrosion preventative
(and while were on the subject...LPS1 is a non-oily lube)
--Don
Don Byrer
Radar Tech & Smilin' Commercial Pilot Guy
Amateur Radio KJ5KB
kj5kb-at-hotmail.com
"I have slipped the surly bonds of earth; now if I can just land without bending the gear..."
"Watch out for those doves...smack-smack-smack-smack..."
Old June 19th 06, 07:31 PM posted to rec.aviation.owning
Default Corrosion X
www.rogerhalstead.com
I thought it was LPS-3. That's what we use and much cheaper than the
other ones but just as effective.
Old June 19th 06, 09:10 PM posted to rec.aviation.owning
Default Corrosion X
ACF 50 very good at stopping corrosion. In spots where you can clean
it up apply some linseed oil or stand oil. I have used ACF for the
last thirty years on my Cherokee. Also good for old radios and
electrical connections. Rejuventates the plastic also in the interior.
Apply the ACF 50 yourself with compressed air and spray nozzle. It
inproves anything it comes in contact with.
Old June 19th 06, 10:43 PM posted to rec.aviation.owning
Default Corrosion X
"darthpup" writes:
ACF 50 very good at stopping corrosion. [...] Apply the ACF 50
yourself with compressed air and spray nozzle. It inproves anything
Plus it turns peeled apples green, and is a great steak marinade.
- FChE
Old June 20th 06, 05:26 AM posted to rec.aviation.owning
Default Corrosion X
Not sure what "stand oil" is but I do know that linseed oil is
flammable.
Is ACF 50 or Corrosion X flammable?
Old June 21st 06, 02:06 PM posted to rec.aviation.owning
Default Corrosion X
darthpup wrote:
Gasoline is flammable. Engine oil is flammable. Your point?
Just a question.
I know that linseed oil is sometimes used to coat the inside of tubing
on ragwings.
Does linseed oil affect the insulation on wiring?
These may seem like trivial questions to ask but it is the small
details which can bite you at the most oppertune times.
Old June 23rd 06, 07:03 AM posted to rec.aviation.owning
Default Corrosion X
On Mon, 19 Jun 2006 08:22:48 -0400, Don Byrer
Nope, LPS 2. You need the penetrating ability of the solvents in
LPS-2.
LPS-3 is much thicker and I doubt its ability to penetrate into some
areas.
I think of LPS-1 as being WD-40 with a different smell. IE a
penetrating oil that has a lot of solvents that will evaporate.
--Don
Don Byrer
Amateur Radio KJ5KB
Old June 24th 06, 02:33 PM posted to rec.aviation.owning
Default Corrosion X
You don't spray gasoline oil or engine oil all inside your airplane.
"darthpup" wrote in message
Posted via a free Usenet account from http://www.teranews.com
Pilatus B4 and corrosion Mika Koski Soaring 1 April 26th 06 09:50 PM
Corrosion Evaluation Help Dick Home Built 3 July 15th 05 02:51 AM
Surface Corrosion? Joaquin Murrieta Home Built 2 May 3rd 05 01:19 AM
Corrosion Proofing Clay Owning 7 April 22nd 05 12:03 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
