DuPont makes Variprime 615S/625S Self-Etching Primer. It has been
recommended to me by a retired FAA engineer. I saw an Ercoupe and some Cessna wings being rebuilt at Wesport Airport (Dead Cow) in Wichita. Both were primed with Variprime. I am considering using Variprime to corrosion proof my Skylark. Several years ago I painted a C-205. The process used was Alumi-Prep 33, Alodine, Dexter 10P-2/EC 139 Epoxy Primer and AlumiGrip paint(US Paint). I also have some Dexter 10P-2 Epoxy Primer, MIL-P-23377. The Dexter product worked very nicely on the C-205. It too is being considered for corrosion proofing. I look forward to hear about everyones experineces and recommendations. |
recommended to me by a retired FAA engineer. As far as I know, this self etching primer needs to be coated with a sealer, such as urethane paint. O It is porous, and therefore is not a moisture barrier. I use Akzo Nobel 2 part epoxy primer (the ugly lime green stuff). You need to do the alodine thing (pain in the butt), however the surface now is scratch proof and moisture resistant. It meets Boeing spec. BMS 10-11 for fuel resistance etc. Very good stuff, and about the same cost as Variprime if you include the Alodine. Labor cost is the only variant. You can get other brands that meet BMS 10-11 as well. You can also get some self etching spray bombs, such as Marhyde, however they scratch very easily. |
Variprime works just fine... It contains zinc and is a corrosion
inhibiter... It is hard once cured... While it may not be as impermeable to moisture as some topcoats, unless you are immersing the plane in the ocean, it is good enough... Now if you are doing the interior of an assembled aircraft where the fayed joint surfaces cannot be coated, why not skip the work and cost of a primer and just fog the metal with ACF50 every other year? denny |
![]() "Denny" wrote: just fog the metal with ACF50 every other year? Do you use that stuff? What do you think of it? I've been using CorrosionX for years with good results, but I've heard ACF50 is better and doesn't weep out of the airplane as much. -- Dan C172RG at BFM |
They are both good prducts and work as advertised... ACF50 seems to
make less mess... If you are happy with X, I wouldn't change... I was just making the point that the exposed metal surfaces in an assembled airplane are not the major site of corrosion, it is the fayed joints, and coating them on the outside with paint will not protect them... I spoze one could spray Variprime and also use ACF50, seems redundant though... denny |
On interior surfaces large aircraft use a product called Dinitrol. It
gets sprayed on at manufacture and is there for the life of the aircraft. It keeps moisture from getting between the joints. On 21 Apr 2005 03:34:21 -0700, "Denny" wrote: They are both good prducts and work as advertised... ACF50 seems to make less mess... If you are happy with X, I wouldn't change... I was just making the point that the exposed metal surfaces in an assembled airplane are not the major site of corrosion, it is the fayed joints, and coating them on the outside with paint will not protect them... I spoze one could spray Variprime and also use ACF50, seems redundant though... denny Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
gets sprayed on at manufacture and is there for the life of the aircraft. It keeps moisture from getting between the joints. That's the stuff my A&P had me paint all over the spar (and adjoining structure) when we performed the dreaded Service Bulletin 1006 on my Cherokee 235, a few years back. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
They are both good prducts and work as advertised... ACF50 seems to make less mess... If you are happy with X, I wouldn't change... I was just making the point that the exposed metal surfaces in an assembled airplane are not the major site of corrosion, it is the fayed joints, and coating them on the outside with paint will not protect them... I spoze one could spray Variprime and also use ACF50, seems redundant though... They tell me that good old LPS-2 works quite well. You can tell if they did a good job if you take the plane out and let it set in the sun. It'll drip for about two weeks. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com denny |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Non Chromate Anti Corrosion and Paint Prep X-it Prekote? | All Thumbs | Home Built | 7 | May 5th 04 04:21 PM |
Corrosion Protection on Alluminum Sheet Aircraft? | DL152279546231 | Home Built | 6 | February 10th 04 05:10 AM |
How much corrosion is too much? | Carl Orton | Owning | 5 | February 2nd 04 01:31 AM |
Corrosion X Applicators | Hankal | Owning | 5 | July 7th 03 06:07 PM |
