Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
IFR logging question - is this legal?
Old July 1st 06, 06:27 PM posted to rec.aviation.ifr,rec.aviation.misc
Bob Moore
Default IFR logging question - is this legal?
Robert M. Gary wrote
Jose wrote:
In IMC, the pilot flying may keep the hood on, and thus a safety pilot
would be required. The pilot flying would then log this as simulated
instrument flight, even though he is in actual.
So your argument is that actual IMC is "simulated instrument flight"?
Sounds like you'd have to be a real Perry Mason to argue that.
Yeah, I also think that argument is full of BS.
Bob Moore
ATP FI
  #32
Old July 1st 06, 08:44 PM posted to rec.aviation.ifr,rec.aviation.misc
Michael Ware
"Jose" wrote in message
. com...
91.109
(b) No person may operate a civil aircraft in simulated instrument
flight unless-
If the fllight is in IMC, then....
1) VFR flight is not legal, therefore...
2) Flight is conducted under IFR.
So, Pilot in Command must either hold an IR, or be a pilot qualifed to fly
the A/C, with a CFII in the other seat (NOT a safety pilot, not the same
thing).
If you are in IMC, why would you need a hood anyway?
  #33
Old July 1st 06, 11:00 PM posted to rec.aviation.ifr,rec.aviation.misc
Jose[_1_]
thing).
True enough, but misses a sliver.
If you are a VFR only pilot, and want to log some instrument PIC time,
and conditions are IMC, you would need the hood to comply with
91.109(b). You could not BE PIC, but you do not need a CFII either.
You can have an instrument rated safety pilot BE PIC while you, as sole
manipulator, log PIC time. You need IR pilot (who also happens to be
the safety pilot) as PIC for the flight to be legal IFR, and you need
the safety pilot (who also happens to be the PIC) to be a crew member
because when you have the hood on, you need somebody to look outside.
This is regardless of whether you are in IMC or VMC. Clearly in VMC,
even IFR, the safety pilot keeps metal from being bent. In IMC, if the
pilot flying is under the hood, he cannot see that it is IMC (and
separation is provided) nor can he see when he breaks in and out of the
clouds (and separation is no longer provided, thus requiring the safety
pilot). So, in either case, as long as the pilot flying is under the
hood, a safety pilot is required, =and= the pilot flying can log PIC
time. If the pilot flying takes the hood off, he can no longer log PIC
time, which may give him incentive to stay hooded.
Jose
  #34
Old July 1st 06, 11:26 PM posted to rec.aviation.ifr,rec.aviation.misc
Michael Ware
.com...
pilot).
OK forget about logging time and hood for a moment. The flight is either VFR
or IFR, it can't just change at will. If it is IFR, then seperation is
provided by ATC, not by someone looking outside. Using the term 'safety
pilot' for IFR is a little misleading. Seems to me you either have the IR
pilot acting as PIC, and the VFR-only pilot is a passenger, OR the IR pilot
is an instructor and the VFR pilot is a student, who also should be able to
log PIC and dual, no? I don't see how the flight can be legal in IMC any
other way.
  #35
Old July 1st 06, 11:38 PM posted to rec.aviation.ifr,rec.aviation.misc
Jose[_1_]
but VMC and IMC can.
If it is IFR, then seperation is provided
Only separation from other IFR traffic. VFR traffic is separated by
eyeball or by clouds. If there are no clouds, then VFR traffic is
separated only by eyeball.
other way.
The IR pilot can be PIC while the VFR-only pilot manipulates the
controls. This is completely legal.
Even if the IR pilot is an instructor, the VFR-only pilot cannot BE PIC
(though then he can log it as PIC time).
I do wish they had not used the same terms to mean different things.
But maybe the FAA has stock in USENET.
Jose
  #36
Old July 2nd 06, 01:37 AM posted to rec.aviation.ifr,rec.aviation.misc
karl gruber[_1_]
VFR
Not true!!!! That's a good recipe for a mid-air.
The pilot STILL has to look outside and provide his own separation, even if
IFR, and especially out of cloud. You can't just fly along fat, dumb, and
happy.........thinking ATC will save you ass! There is all sorts of VFR
traffic climbing and descending through your IFR altitudes.
Karl
ATP CFIAIM
"Curator" N185KG
  #37
Old July 2nd 06, 02:57 AM posted to rec.aviation.ifr,rec.aviation.misc
Robert M. Gary
There is no regulation in the above proposal that requires multiple
pilots (the requirement for the non-flying pilot to log PIC under
61.51(e). The FAR that requires multiple pilots says "simulated
instrument conditions".
91.109(b) No person may operate a civil aircraft in simulated
instrument flight unless-
(1) The other control seat is occupied by a safety pilot who possesses
at least a private pilot certificate with category and class ratings
appropriate to the aircraft being flown.
  #38
Old July 2nd 06, 03:00 AM posted to rec.aviation.ifr,rec.aviation.misc
Robert M. Gary
You actually make an excellent point. We use the term "IMC" and "VMC".
However those terms actually refer to the legal minimums ("IMC" meaning
below VFR minumums). However, a safety pilot is required in IMC
conditions where visibility is clear enough to allow for "see and
avoid" and the flying pilot is under the hood. Above 10,000 feet this
could be as much as 4.9 miles visibility. The safety pilot is requires
anytime the hooded pilot is flying in conditions that allow for
see-and-avoid.
-Robert, CFII
  #39
Old July 2nd 06, 03:08 AM posted to rec.aviation.ifr,rec.aviation.misc
Ron Rosenfeld
On Sat, 01 Jul 2006 08:33:09 +0100, Peter wrote:
Jose wrote
This doesn't contradict me. Note the difference between BEING and
LOGGING PIC.
I didn't wish to go into whether they can *both* log.
The situation here is this:
I am instrument rated. A friend is not, but is legal to fly the plane
in VFR.
He sits in LH seat, is renting the plane, and understandably wants to
end up with a nice 10-hour (it's two long flights) logbook entry, in
return for his money. (I am not sure whether Americans are as dead
keen as Europeans to log everything they pay for )
We will do a long flight, under IFR. Clearly my presence is required
because he doesn't have an IR. Does it mean that I must be PIC on that
flight (because I am the only one with an IR).
The obvious practical reality is that he can do all the flying.
*What* can he log this time as?
If he is the sole manipulator of the controls, he may, under US rules, log
all of the flying time as PIC.
Can he log instrument time, or (if under the hood) simulated
instrument time)? What if the whole flight is VMC on top (most
likely).
If he requires use of the instruments in order to fly the a/c, whether in
actual or simulated, he may log actual instrument time, or simulated
instrument time, as the case may be.
I would be suprised if he could log it as instrument instruction,
because I am not an instructor.
He could NOT log it as dual, as you are not an instructor.
Your name, as safety pilot (for that part of the flight requiring a safety
pilot) must be recorded in his log book.
In the US regs, there is this strange dichotomy between logging PIC, and
acting as PIC. It is possible to act as PIC, but not be able to log it;
and also possible to log PIC, without being authorized to act as PIC.
You could log PIC for that portion of the flight when a safety pilot is
required under 91.109 (i.e. simulated instrument flight). But you would be
the acting PIC for the entire flight if under IFR.
  #40
Old July 2nd 06, 05:29 AM posted to rec.aviation.ifr,rec.aviation.misc
Jose[_1_]
As soon as you put the hood on, you are in simulated instrument
conditions, whether in cloud or not, and whether IFR or not. You may
=also= be in actual instrument conditions, but that is irrelevant.
Using a flight simulator is still simulated flight, even if the
simulator is on board a flying 747.
Jose
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
182RG question Paul Anton Owning 11 May 16th 05 09:45 PM
Could the Press Grow a Spine? WalterM140 Military Aviation 259 July 11th 04 08:35 PM
