#21
Doug wrote:
Just take off in Atlanta and climb to 6500'. Stay at that altitude and when you get to Boulder, you will be at pattern altitude! (actually pattern altitude is 6300'). Run at full power. Lean for best rpm (at 6300'). See how far out the lean knob is? That is how far out it should be for takeoff too (plus 3 half turns in). We lean on the ground at runup for takeoffs at these altitudes. Learn how to do that if you don't know how. This time of year is bumpy below the cumulus and if we have rain, it is thunderstorms you can see and go around. So go around them. The weather is good for flying in the summer in Colorado. Have fun and see ya! By September, the Tstorms will be gone (we hope!) but it'll still be a bit warm. Mid-Kansas, go up to 8500 -- air will be smoother (usually), and a great view of the Rockies. |
Jim Macklin wrote:
Just be aware that on a hot day in the Denver area, 35C is possible, even higher on the air above the paved runway. That can make the density altitude near 10,000 feet on the surface. Take-off performance and service ceilings will be reduced. Climb gradient will be shallow. Pack like a backpacker. If you land with a lot of luggage, remember for the return home, UPS and FedEx can reduce you load of non-essentials for the departure for home. Today, it was 37-40C depending where you were. |
It was 40 C here in Wichita today, MSL 1332, DA about 4,500.
"Blanche Cohen" wrote in message ... | Jim Macklin wrote: | Just be aware that on a hot day in the Denver area, 35C is | possible, even higher on the air above the paved runway. | That can make the density altitude near 10,000 feet on the | surface. Take-off performance and service ceilings will be | reduced. Climb gradient will be shallow. Pack like a | backpacker. If you land with a lot of luggage, remember for | the return home, UPS and FedEx can reduce you load of | non-essentials for the departure for home. | | Today, it was 37-40C depending where you were. | | |
Jim Macklin wrote:
It was 40 C here in Wichita today, MSL 1332, DA about 4,500. "Blanche Cohen" wrote in message | Jim Macklin wrote: | Just be aware that on a hot day in the Denver area, 35C is | possible, even higher on the air above the paved runway. | That can make the density altitude near 10,000 feet on the | surface. Take-off performance and service ceilings will be | reduced. Climb gradient will be shallow. Pack like a | backpacker. If you land with a lot of luggage, remember for | the return home, UPS and FedEx can reduce you load of | non-essentials for the departure for home. | | Today, it was 37-40C depending where you were. True, Jim. But around here, 37C means 9500 DA on the ground. And it's why I drove to Leadville for sightseeing, while many of the Colorado Pilots Assoc. Flew to Montrose (MTJ) for a weekend flyin. Due to DA, I couldn't take my regular 2.2 hour flight (couple of passes, no big deal -- usually), and the low-er-land route would have taken me 5 hours (with a stop for fuel). Not worth it. I've flown into Leadville, but never got away from the airport. This time -- typical tourist, and loved it. |
The point is that whenever the ambient temperature is above
ISA standard, the density altitude and thus aircraft performance will be worse. Hot days in Wichita is like a standard day in Denver and a hot day in Denver is like Leadville. With a non-turbocharged engine, the service ceiling may be at the surface. -- James H. Macklin ATP,CFI,A&P "Blanche Cohen" wrote in message ... | Jim Macklin wrote: | It was 40 C here in Wichita today, MSL 1332, DA about 4,500. | | "Blanche Cohen" wrote in message | | Jim Macklin wrote: | | Just be aware that on a hot day in the Denver area, 35C | is | | possible, even higher on the air above the paved runway. | | That can make the density altitude near 10,000 feet on | the | | surface. Take-off performance and service ceilings will | be | | reduced. Climb gradient will be shallow. Pack like a | | backpacker. If you land with a lot of luggage, remember | for | | the return home, UPS and FedEx can reduce you load of | | non-essentials for the departure for home. | | | | Today, it was 37-40C depending where you were. | | True, Jim. But around here, 37C means 9500 DA on the ground. | And it's why I drove to Leadville for sightseeing, while many | of the Colorado Pilots Assoc. Flew to Montrose (MTJ) for | a weekend flyin. Due to DA, I couldn't take my regular 2.2 hour | flight (couple of passes, no big deal -- usually), and the | low-er-land route would have taken me 5 hours (with a stop for | fuel). Not worth it. I've flown into Leadville, but never | got away from the airport. This time -- typical | tourist, and loved it. | | |
Gageteers, we need a digital heading sensor | Bill Daniels | Soaring | 32 | June 26th 04 06:07 AM |
KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 02:01 AM |
