Flatlander heading to Boulder, CO -- need sage advice
Old July 12th 06, 09:30 PM posted to rec.aviation.piloting
Default Flatlander heading to Boulder, CO -- need sage advice
Hey all,
I'm planning to head out in my 68 Cherokee 180 the first week of September
with my 20 yr old son to visit my brother in Boulder, CO. I'm a flatlander
(Atlanta, Georgia area) and though I have no plans to do any mountain flying
and wouldn't without instruction, I'm flying towards the mountains. That's
enough to get me looking for some good advice/pointers. An old pilot friend
of mine said carry more speed on final than usual, that sort of thing.
We'll be loaded lightly.
Give me some good pointers if you will.
Biker Bill
(N6422J)
Old July 12th 06, 09:51 PM posted to rec.aviation.piloting
Hey Bill,
Please DO NOT carry extra speed on final. An aircraft flys on
INDICATED AIRSPEED! Please fly the book speeds. Yes, they really
work! Now, if there are winds, I can recommend adding to that speed
"1/2 the wind speed and all the gust speed, to a limit of 15 MPH
more than the normal approach speed".
Your GROUND speed will be greater than down at your home altitude,
but your airspeed will be correct.
There are many more myths about high density altitude and mountain
flying dispelled in the Colorado Pilots Associations Mountain Flying
and High Elevation Ground School:
http://www.coloradopilots.org/
see Mountain Flying in the left margin.
Please join us some time.
Best regards,
Jer/ "Flight instruction and mountain flying are my vocations!"
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jeratfrii.com http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 240 Young Eagles!
Old July 12th 06, 09:56 PM posted to rec.aviation.piloting
Jim Macklin
First off, you fly the same indicated airspeed, for the
gross weight, whether at 5 MSL or 5,000. Your TAS will be
higher and you will use more runway for take-off and
landings.
Be sure to do a review of proper leaning procedures, proper
leaning is essential to get maximum possible power on
take-off. If you have an EGT, use it to get the true best
power mixture. Otherwise, lean to maximum RPM in a full
power static run-up.
If the wind is from the west, expect turbulence from the
nearby mountains.
Get the Denver local chart.
Be amazed at the 100 plus mile visibility. Fly before it
get hot during the day.
Hire a qualified mountain CFI and go for a sight seeing
flight into the mountains if the weather is good.
The AOPA has some mountain flying articles and an
on-line course
http://www.aopa.org/asf/online_courses/mountain_flying/
download the file
http://www.aopa.org/asf/publications/sa23.pdf on mountain
flying.
James H. Macklin
ATP,CFI,A&P
news | Hey all,
week of September
I'm a flatlander
any mountain flying
mountains. That's
old pilot friend
sort of thing.
| Thanks,
| Biker Bill
| (N6422J)
Old July 12th 06, 10:18 PM posted to rec.aviation.piloting
Peter R.
Hey, Bill, I don't hold a candle to either of the two previous posters in
terms of experience, but I have been to Denver twice in the last year or
so, the most recent being last week where I landed and hangared at Erie
Muni, just east/southeast or so of Boulder.
If you can plan a before-noon arrival into Boulder, you will be less likely
to encounter strong t-storms that seem to build over the mountains during
the morning hours, then drift eastward after noon. I am not sure how
September's weather differs from July's though. Perhaps it is more benign.
I didn't heed my own advice last week and instead arrived VFR ahead of a
cell and had to scramble once down to unload the aircraft before the rain
arrived.
Also, if you haven't already, pick up a copy of the Denver Terminal chart
(even if you are IFR, in the event you want to depart VFR to pick up your
clearance) so that you know the class B shelf altitudes. Just north and
west of Denver, there are all kinds of class B altitudes for you to watch
if you are VFR.
Peter
Old July 13th 06, 12:10 AM posted to rec.aviation.piloting
BTIZ
Carrying extra airspeed on final is how flat landers (low landers) go long
off the end of the runway.
Fly the same speeds you would always fly at your home airport.. just be
aware, that the ground speed (TAS) will be faster and it will "appear" that
you are fast, but wings fly on IAS.
BT
news
Hey all,
flatlander
flying
That's
friend
Biker Bill
(N6422J)
Old July 13th 06, 01:22 AM posted to rec.aviation.piloting
Boulder has some specific traffic conditions. The glider pattern is inside
of the
power pattern. You need to be very aware of the local traffic pattern,
especially the location and direction.
Wind can switch quickly out there. Winds can be quite a factor, and often
vary
considerably in both direction and velocity when wave conditions are
happening.
Oh, and no matter the safety considerations or anything else, don't disturb
the birds or prairie dogs. Live traps have been known to appear overnight
on the ends of the runway. We certainly don't want to endanger the
critters.
wrote in message ...
Hey all,
flying
Biker Bill
(N6422J)
Old July 17th 06, 02:34 AM posted to rec.aviation.piloting
Blanche Cohen
Bill:
You may want to fly into Jeffco (BJC) instead of Boulder. From a
driving POV, it's only about 15-20 min (or less, depending on
traffic). Runways are longer, fuel is more expensive, tower 6am - 10 pm,
no worries about the gliders or the locals who complain about the
noise, etc.
And yes, if you have time, go take a lesson from Jer/
Old July 13th 06, 02:22 AM posted to rec.aviation.piloting
Doug[_1_]
Just take off in Atlanta and climb to 6500'. Stay at that altitude and
when you get to Boulder, you will be at pattern altitude! (actually
pattern altitude is 6300'). Run at full power. Lean for best rpm (at
6300'). See how far out the lean knob is? That is how far out it should
be for takeoff too (plus 3 half turns in). We lean on the ground at
runup for takeoffs at these altitudes. Learn how to do that if you
don't know how. This time of year is bumpy below the cumulus and if we
have rain, it is thunderstorms you can see and go around. So go around
them. The weather is good for flying in the summer in Colorado. Have
fun and see ya!
Old July 13th 06, 06:22 AM posted to rec.aviation.piloting
Andrew Sarangan[_1_]
fun and see ya
Good point about leaning for takeoff power. This is not even mentioned
in many checklists, and is likely to be neglected by most flatlanders.
Gageteers, we need a digital heading sensor Bill Daniels Soaring 32 June 26th 04 06:07 AM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
