I'd like to get some general information on flap deployment if someone
would be kind enough to provide it. Is the flap angle normally held constant throughout climb? Ditto for descent. If not, what are the typical rules or schedule for changing the flap angle for a large commercial aircraft? Thanks. |
Is the flap angle normally held constant throughout climb? Ditto for descent. If not, what are the typical rules or schedule for changing the flap angle for a large commercial aircraft? Thanks. The topic can be fairly complicated. Generally speaking, the flaps are retracted one notch after climbing through somewhere between 800' to 1500'. The flaps and slats are further retracted as the airplane accelerates. Climbing with the wing in the 'clean' configuration is most economical. D. |
On a B727, flap retraction is done according to a schedule which correlates
flap settings with airspeed. For example, with a TOGW of 160,000, temp of 59F, and 15 degrees flaps, V2 is 146 knots. Takeoff is done at Flaps 15. Flaps are then retracted to 5 degrees when reaching "V2 + 10" (156 knots), then retracted to 2 degrees when reaching "V2 + 40" (186 knots), and fully retracted at "V2 + 60" (206 knots). Note: When 2 degrees of flaps are used, half of the slats get retracted , with the remaining slats (and the Krueger flaps) retracted with a 0 Flap setting wrote in message oups.com... I'd like to get some general information on flap deployment if someone would be kind enough to provide it. Is the flap angle normally held constant throughout climb? Ditto for descent. If not, what are the typical rules or schedule for changing the flap angle for a large commercial aircraft? Thanks. |
![]() "Dave Doe" wrote in message For example, with a TOGW of 160,000, temp of 59F, and 15 degrees flaps, V2 is 146 knots. Takeoff is done at Flaps 15. Flaps are then retracted to 5 degrees when reaching "V2 + 10" (156 knots), then retracted to 2 degrees when reaching "V2 + 40" (186 knots), and fully retracted at "V2 + 60" (206 knots). Note: When 2 degrees of flaps are used, half of the slats get retracted , with the remaining slats (and the Krueger flaps) retracted with a 0 Flap setting Surely you also calculate your speeds based on a/c weight? (unlike small aircraft). Note above, he did mention "...TOGW of 160000..." |
Yes, we do (Take Off Gross Weight = TOGW)
And stop calling me Shirley! "Dave Doe" wrote in message . nz... In article 8hJvg.161350$k%3.95311@dukeread12, says... On a B727, flap retraction is done according to a schedule which correlates flap settings with airspeed. For example, with a TOGW of 160,000, temp of 59F, and 15 degrees flaps, V2 is 146 knots. Takeoff is done at Flaps 15. Flaps are then retracted to 5 degrees when reaching "V2 + 10" (156 knots), then retracted to 2 degrees when reaching "V2 + 40" (186 knots), and fully retracted at "V2 + 60" (206 knots). Note: When 2 degrees of flaps are used, half of the slats get retracted , with the remaining slats (and the Krueger flaps) retracted with a 0 Flap setting Surely you also calculate your speeds based on a/c weight? (unlike small aircraft). -- Duncan |
"tom418" wrote in message
Note: When 2 degrees of flaps are used, half of the slats get retracted , with the remaining slats (and the Krueger flaps) retracted with a 0 Flap setting You sure about the Krueger flaps? My library is packed away for remodeling preventing me from looking it up, but I'm sure only slats 3 &4 are extended at flaps2, not the Kruegers. D. |
![]() "Capt.Doug" wrote You sure about the Krueger flaps? My library is packed away for remodeling preventing me from looking it up, but I'm sure only slats 3 &4 are extended at flaps2, not the Kruegers. Durn it, I was going to let the Krueger flaps go, when he explained it, as something I really didn't need to know. Now you bring it up again, and now I want to know! g What the heck are Krueger flaps? -- Jim in NC |
Flaps the hinge at the bottom from of the leading edge and
swing down to make a more curved section. Slats are sections of the leading edge that move forward making a slot. -- James H. Macklin ATP,CFI,A&P "Morgans" wrote in message ... | | "Capt.Doug" wrote | | You sure about the Krueger flaps? My library is packed away for remodeling | preventing me from looking it up, but I'm sure only slats 3 &4 are | extended | at flaps2, not the Kruegers. | | Durn it, I was going to let the Krueger flaps go, when he explained it, as | something I really didn't need to know. Now you bring it up again, and now | I want to know! g | | What the heck are Krueger flaps? | -- | Jim in NC | |
Capt.Doug wrote:
"tom418" wrote in message Note: When 2 degrees of flaps are used, half of the slats get retracted , with the remaining slats (and the Krueger flaps) retracted with a 0 Flap setting You sure about the Krueger flaps? My library is packed away for remodeling preventing me from looking it up, but I'm sure only slats 3 &4 are extended at flaps2, not the Kruegers. D. Doug, Re-read his statement. With flaps 2 selected, leading edge slats 2&3, and 6&7 are deployed. The remaining slats, as well as *all* krueger flaps, are retracted. Happy Flying! Scott Skylane |
C172N Flap indicator problem | onesto | Owning | 0 | July 2nd 06 10:47 AM |
Cirrus chute deployment -- an incredible story | Michael182/G | Instrument Flight Rules | 48 | July 14th 05 03:52 PM |
Stuck cowl flap cable | Jim Burns | Owning | 7 | March 24th 05 02:07 PM |
Flap angles | DeltaDeltaDelta | Piloting | 34 | May 18th 04 12:09 AM |
C-130 Unit Completes Two Year Deployment | Otis Willie | Military Aviation | 0 | September 30th 03 10:04 PM |
