flap deployment
Old July 21st 06, 06:33 AM posted to rec.aviation.piloting
John Gaquin
Default flap deployment
"Capt.Doug" wrote in message news:1UWvg.433226
You sure about the Krueger flaps? My library is packed away for remodeling
preventing me from looking it up, but I'm sure only slats 3 &4 are
extended
at flaps2, not the Kruegers.
Somewhat correct Doug. At Fl 2, only slats 2,3,6,7 extend. At Fl 5,
remaining slats (1,4,5,8) and all LE flaps (1-6) extend. Retract sequence
is reverse.
Old July 21st 06, 11:57 AM posted to rec.aviation.piloting
tom418[_1_]
Doug, I had edited my original post, and should have mentioned that the
kruegers get retracted when changing from flaps 5 to flaps 2.
At flaps 2, L.E. Flaps 2,3,6 and 7 are extended, and at 0 flaps, these get
retracted also.
"tom418" wrote in message
Note: When 2 degrees of flaps are used, half of the slats get retracted
with the remaining slats (and the Krueger flaps) retracted with a 0 Flap
setting
extended
D.
Old July 21st 06, 12:08 PM posted to rec.aviation.piloting
tom418[_1_]
Correction: At flaps 2, SLATS 2,3,6,7 get retracted.
news:Rq2wg.163322$k%3.21020@dukeread12...
retracted also.
retracted
Flap
setting
remodeling
extended
D.
Old July 21st 06, 03:31 PM posted to rec.aviation.piloting
Morgans[_3_]
"Jim Macklin" wrote in message
news:LbZvg.79434$ZW3.72823@dukeread04...
Flaps the hinge at the bottom from of the leading edge and
swing down to make a more curved section. Slats are
sections of the leading edge that move forward making a
slot.
Ahaa! I thought they were all slats.
Jim in NC
Old July 22nd 06, 04:09 AM posted to rec.aviation.piloting
Capt.Doug
"Morgans" wrote in message Ahaa! I thought they were all slats.
Additionally, on B-727 and B-732, the Krueger flaps will droop down after
the hydraulic pressure is shut off. Turn the hydraulic pumps back on and
they retract quickly. More than one mechanic has been hurt this way.
D.
C172N Flap indicator problem onesto Owning 0 July 2nd 06 10:47 AM
Cirrus chute deployment -- an incredible story Michael182/G Instrument Flight Rules 48 July 14th 05 03:52 PM
Stuck cowl flap cable Jim Burns Owning 7 March 24th 05 02:07 PM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 12:09 AM
C-130 Unit Completes Two Year Deployment Otis Willie Military Aviation 0 September 30th 03 10:04 PM
