http://www.scn.org/~bk269/gps.html
This is an interesting site that explains why some pilots (seemingly mostly running Garmin-brand portable GPS units) are having trouble with losing satellite lock. So far I've not had any trouble with our new 496 (and I've never had any trouble with the Lowrance or AvMap units) -- but it's nice to find an actual explanation for a problem that has struck several folks on this group. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article .com,
"Jay Honeck" wrote: http://www.scn.org/~bk269/gps.html This is an interesting site that explains why some pilots (seemingly mostly running Garmin-brand portable GPS units) are having trouble with losing satellite lock. So far I've not had any trouble with our new 496 (and I've never had any trouble with the Lowrance or AvMap units) -- but it's nice to find an actual explanation for a problem that has struck several folks on this group. I'm not an EE so I can't comment on this guy's conclusions, other than to say that the Garmin installation manuals for panel-mount GPS units specifically warn against running the GPS antenna cable near nav/com radios. My avionics shop told me that modern radios are sufficiently shielded, but obviously, some older radios are not. Garmin uses the same active antenna system for panel-mount as they do for portable. I can also say that I have KX170B nav/coms and have never had a problem with interference on the 396. JKG |
I can tell you with 100% certainty that when I put the suction cup antenna
in the center of the windshield above the Narco stack in our 172 and transmit on 119.4, I lose all satellites. This has happened to me with my old III Pilot and also my Garmin 196. If I put the antenna in the very lower left corner away from the radio stack it seems ok. It is just that plane. In my specific instance it happens not departing, but when I switch to tower frequency and transmit when landing. Usually right after I call the field in site and they switch me to tower. Two separate Garmin units, two different antenna's. It requires a power on and off. I can also count on losing all satellites when flying right over the approach control radar antenna on the KLN90B in the panel on another airplane and it requires a power cycle. It only has happened at my home airport. I'm not an EE so I can't comment on this guy's conclusions, other than to say that the Garmin installation manuals for panel-mount GPS units specifically warn against running the GPS antenna cable near nav/com radios. My avionics shop told me that modern radios are sufficiently shielded, but obviously, some older radios are not. Garmin uses the same active antenna system for panel-mount as they do for portable. I can also say that I have KX170B nav/coms and have never had a problem with interference on the 396. JKG |
I have a Garmin GPS III Pilot portable and have never had a problem. I have
used it in 172s, 182s, and various Piper aircraft both sitting on the glareshield with its little stubby antenna, as well as sitting on the right seat using a portable "full-size" antenna with the suction cup unit on the bottom right corner of the windscreen. Marc "Jonathan Goodish" wrote in message ... In article .com, "Jay Honeck" wrote: http://www.scn.org/~bk269/gps.html This is an interesting site that explains why some pilots (seemingly mostly running Garmin-brand portable GPS units) are having trouble with losing satellite lock. So far I've not had any trouble with our new 496 (and I've never had any trouble with the Lowrance or AvMap units) -- but it's nice to find an actual explanation for a problem that has struck several folks on this group. I'm not an EE so I can't comment on this guy's conclusions, other than to say that the Garmin installation manuals for panel-mount GPS units specifically warn against running the GPS antenna cable near nav/com radios. My avionics shop told me that modern radios are sufficiently shielded, but obviously, some older radios are not. Garmin uses the same active antenna system for panel-mount as they do for portable. I can also say that I have KX170B nav/coms and have never had a problem with interference on the 396. JKG |
On Fri, 04 Aug 2006 09:37:44 -0400, Jonathan Goodish
wrote: In article .com, "Jay Honeck" wrote: http://www.scn.org/~bk269/gps.html This is an interesting site that explains why some pilots (seemingly mostly running Garmin-brand portable GPS units) are having trouble with losing satellite lock. We had a problem in our PA28 with a Skymap II (panel mounted GPS) when using an antenna on the top of the instrument panel. The culprit was the Narco IDME 825 and depended which frequency the DME was tuned. The DME transmitter blocked the GPS receiver. There was a considerable improvement when we fitted an external roof antenna. We have now fitted a Skymap IIIc GPS which is understand has a better receiver and so far appears ok. |
A friend of mine has used http://www.mumetal.com/ on the top of his radio
stacks to shield compasses from magnetic and electro magnetic interference. He's had wonderful results with this material. Possibly a combination of mumetal and an RF shield, say from fotofab, would provide positive results. Jim "Jay Honeck" wrote in message oups.com... http://www.scn.org/~bk269/gps.html This is an interesting site that explains why some pilots (seemingly mostly running Garmin-brand portable GPS units) are having trouble with losing satellite lock. So far I've not had any trouble with our new 496 (and I've never had any trouble with the Lowrance or AvMap units) -- but it's nice to find an actual explanation for a problem that has struck several folks on this group. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I think its usually a software problem. I've had various issues with
losing signal in different scenarios with my Garmin handhelds and Garmin has always provided me a ROM update which appears to address the issue. -Robert Jay Honeck wrote: http://www.scn.org/~bk269/gps.html This is an interesting site that explains why some pilots (seemingly mostly running Garmin-brand portable GPS units) are having trouble with losing satellite lock. So far I've not had any trouble with our new 496 (and I've never had any trouble with the Lowrance or AvMap units) -- but it's nice to find an actual explanation for a problem that has struck several folks on this group. |
"Jonathan Goodish" wrote: My avionics shop told me that modern radios are sufficiently shielded, but obviously, some older radios are not. Garmin uses the same active antenna system for panel-mount as they do for portable. I've had two radios that would flat-line GPS reception in the airplane. One was a Sporty's handheld NAV/COM, the other was a Cessna ARC 385 panel NAV/COM. The Sporty's would squash my portable GPS reception just by being on; the ARC 385 would kill panel and portable GPS when transmitting. -- Dan C-172RG at BFM |
I have a full Narco stack in my Cherokee and keep the antennae for my Garmin
196 just to the left side of the windshield brace. I've never have seen a problem with the GPS in the past 5 years. This spring I upgraded the radios to the 12D+ package with the same results. Mike "Jay Honeck" wrote in message oups.com... http://www.scn.org/~bk269/gps.html This is an interesting site that explains why some pilots (seemingly mostly running Garmin-brand portable GPS units) are having trouble with losing satellite lock. So far I've not had any trouble with our new 496 (and I've never had any trouble with the Lowrance or AvMap units) -- but it's nice to find an actual explanation for a problem that has struck several folks on this group. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
wrote in message ... : On Fri, 04 Aug 2006 09:37:44 -0400, Jonathan Goodish : wrote: : : In article .com, : "Jay Honeck" wrote: : http://www.scn.org/~bk269/gps.html : : This is an interesting site that explains why some pilots (seemingly : mostly running Garmin-brand portable GPS units) are having trouble with : losing satellite lock. : : : We had a problem in our PA28 with a Skymap II (panel mounted GPS) when : using an antenna on the top of the instrument panel. The culprit was : the Narco IDME 825 and depended which frequency the DME was tuned. The : DME transmitter blocked the GPS receiver. There was a considerable : improvement when we fitted an external roof antenna. We have now : fitted a Skymap IIIc GPS which is understand has a better receiver : and so far appears ok. Didn't know DME transmitted... |
| GPS loss of signal explanation | Jay Honeck | Piloting | 28 | August 8th 06 05:05 PM |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 06:31 PM |
