GPS loss of signal explanation
Old August 4th 06, 02:22 PM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck
Default GPS loss of signal explanation
http://www.scn.org/~bk269/gps.html
This is an interesting site that explains why some pilots (seemingly
mostly running Garmin-brand portable GPS units) are having trouble with
losing satellite lock.
So far I've not had any trouble with our new 496 (and I've never had
any trouble with the Lowrance or AvMap units) -- but it's nice to find
an actual explanation for a problem that has struck several folks on
this group.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 4th 06, 02:37 PM posted to rec.aviation.piloting,rec.aviation.owning
Jonathan Goodish
In article .com,
this group.
I'm not an EE so I can't comment on this guy's conclusions, other than
to say that the Garmin installation manuals for panel-mount GPS units
specifically warn against running the GPS antenna cable near nav/com
radios. My avionics shop told me that modern radios are sufficiently
shielded, but obviously, some older radios are not. Garmin uses the
same active antenna system for panel-mount as they do for portable.
I can also say that I have KX170B nav/coms and have never had a problem
with interference on the 396.
JKG
Old August 4th 06, 03:17 PM posted to rec.aviation.piloting,rec.aviation.owning
ron
I can tell you with 100% certainty that when I put the suction cup antenna
in the center of the windshield above the Narco stack in our 172 and
transmit on 119.4, I lose all satellites. This has happened to me with my
old III Pilot and also my Garmin 196. If I put the antenna in the very
lower left corner away from the radio stack it seems ok. It is just that
plane.
In my specific instance it happens not departing, but when I switch to tower
frequency and transmit when landing. Usually right after I call the field
in site and they switch me to tower. Two separate Garmin units, two
different antenna's. It requires a power on and off.
I can also count on losing all satellites when flying right over the
approach control radar antenna on the KLN90B in the panel on another
airplane and it requires a power cycle. It only has happened at my home
airport.
JKG
Old August 4th 06, 03:26 PM posted to rec.aviation.piloting,rec.aviation.owning
Marc CYBW
I have a Garmin GPS III Pilot portable and have never had a problem. I have
used it in 172s, 182s, and various Piper aircraft both sitting on the
glareshield with its little stubby antenna, as well as sitting on the right
seat using a portable "full-size" antenna with the suction cup unit on the
bottom right corner of the windscreen.
Marc
"Jonathan Goodish" wrote in message
In article .com,
this group.
JKG
Old August 4th 06, 03:31 PM posted to rec.aviation.piloting,rec.aviation.owning
On Fri, 04 Aug 2006 09:37:44 -0400, Jonathan Goodish
In article .com,
We had a problem in our PA28 with a Skymap II (panel mounted GPS) when
using an antenna on the top of the instrument panel. The culprit was
the Narco IDME 825 and depended which frequency the DME was tuned. The
DME transmitter blocked the GPS receiver. There was a considerable
improvement when we fitted an external roof antenna. We have now
fitted a Skymap IIIc GPS which is understand has a better receiver
and so far appears ok.
Old August 4th 06, 03:40 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Burns[_1_]
A friend of mine has used http://www.mumetal.com/ on the top of his radio
stacks to shield compasses from magnetic and electro magnetic interference.
He's had wonderful results with this material.
Possibly a combination of mumetal and an RF shield, say from fotofab, would
provide positive results.
"Jay Honeck" wrote in message
this group.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 4th 06, 06:45 PM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
I think its usually a software problem. I've had various issues with
losing signal in different scenarios with my Garmin handhelds and
Garmin has always provided me a ROM update which appears to address the
issue.
-Robert
this group.
Old August 4th 06, 07:53 PM posted to rec.aviation.piloting,rec.aviation.owning
Dan Luke
I've had two radios that would flat-line GPS reception in the airplane. One
was a Sporty's handheld NAV/COM, the other was a Cessna ARC 385 panel
NAV/COM. The Sporty's would squash my portable GPS reception just by being
on; the ARC 385 would kill panel and portable GPS when transmitting.
Dan
C-172RG at BFM
Old August 4th 06, 10:16 PM posted to rec.aviation.piloting,rec.aviation.owning
mbremer216
I have a full Narco stack in my Cherokee and keep the antennae for my Garmin
196 just to the left side of the windshield brace. I've never have seen a
problem with the GPS in the past 5 years.
This spring I upgraded the radios to the 12D+ package with the same results.
this group.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 4th 06, 11:14 PM posted to rec.aviation.piloting,rec.aviation.owning
.Blueskies.
wrote in message ...
: On Fri, 04 Aug 2006 09:37:44 -0400, Jonathan Goodish
: wrote:
: In article .com,
: "Jay Honeck" wrote:
: http://www.scn.org/~bk269/gps.html
: This is an interesting site that explains why some pilots (seemingly
: mostly running Garmin-brand portable GPS units) are having trouble with
: losing satellite lock.
: We had a problem in our PA28 with a Skymap II (panel mounted GPS) when
: using an antenna on the top of the instrument panel. The culprit was
: the Narco IDME 825 and depended which frequency the DME was tuned. The
: DME transmitter blocked the GPS receiver. There was a considerable
: improvement when we fitted an external roof antenna. We have now
: fitted a Skymap IIIc GPS which is understand has a better receiver
: and so far appears ok.
Didn't know DME transmitted...
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Night bombers interception in Western Europe in 1944 Bernardz Military Aviation 205 July 22nd 04 05:31 PM
