#11
Jim Carter wrote:
So contrary to what others have suggested, the NA does not mean “not authorized”; rather, it means “not applicable”. Where do you get that idea? From an incorrectly printed Jepp chart perhaps? Check FAR 97.3, and I quote: (n) "NA" means not authorized. |
Peter Clark wrote:
You don't need CAT IIIc for autoland. Cat IIIa is sufficient. I'm sure one of the airline drivers will chime in - ceiling/visibility ignored for a moment, can't you autoland off a normal CAT I ILS if you so desire? It's the same LOC/GS as the CAT III beam, right? They just flight and obstacle check to a greater tolerance for the CAT III authorization? It depends upon an airline's ops specs and flight ops policy. Autolanding on a non-CAT III ILS does not assure containment on the runway, thus the weather better be sufficient to see if things are not working out. |
-----Original Message----- From: Gary Drescher ] Posted At: Monday, August 07, 2006 8:13 AM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums "Jim Carter" wrote in message news:001c01c6b9e5$41b26ee0$4001a8c0@omnibook6100.. . The lowest authorized ILS minimums, with all required ground and airborne systems components operative, are .... I found ... on page 5-49 of the Instrument Procedures Handbook at http://www.faa.gov/library/manuals/a...ocedures_handb oo k/ .... No, NA means "not authorized". See http://www.naco.faa.gov/content/naco..._IAP_Intro.pdf , p. 53. (Also, Jeppesen's Instrument/Commercial Manual, Appendix B, lists NA as an abbreviation for "not authorized".) The material you cited above is entirely consistent with the "not authorized" meaning. Gary, I pulled up the pdf file you supplied as reference and had adobe search for the "not authorized" phrase. There is only one instance found under the Alternate Minimums paragraph on page 53: "If NA appears, alternate minimums are not authorized due to unmonitored facility or absence of weather reporting service." I did not reference Jeppesen because they are not the authority for this information. Could this be a case of NA meaning one thing for CAT IIIc and something else for other purposes? It probably would have made more sense if the visibility requirement was shown as not required or inapplicable. How could an approach be authorized if the visibility requirement is "not authorized"? There is no CAT IIIc approach into JFK for runway 4R Sorry, can you say how you arrived at that conclusion? There is no CAT IIIc minima listed on the plate even though there is CAT IIIa and b. which is why it is not listed on the plate. Couldn't it be unlisted because there are no DA or RVR limitations to list? --Gary No, then it would be an unpublished approach wouldn't it? The definition of CAT IIIc is zero/zero (more explicit language is found in my original reference). The approach would be listed on the JFK plate if it was approved and published. The EWS plate lists all three approach minima. |
-----Original Message----- From: Sam Spade ] Posted At: Monday, August 07, 2006 8:27 AM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums Jim Carter wrote: So contrary to what others have suggested, the NA does not mean "not authorized"; rather, it means "not applicable". Where do you get that idea? From an incorrectly printed Jepp chart perhaps? Check FAR 97.3, and I quote: (n) "NA" means not authorized. Please notice the quote I pasted from the TERPS manual. Also, please read the notes on the pages I originally referenced. They state that there is no applicable RVR (visibility) requirement for CAT IIIc. They also state that CAT IIIc is operation with visibility unsuitable for taxi. How could an approach be authorized yet have the visibility requirements part of it be not authorized? When you take that NACO plate into consideration in light of the TERPS manual, not applicable is a reasonable conclusion. |
Jim Carter wrote:
-----Original Message----- From: Sam Spade ] Posted At: Monday, August 07, 2006 8:27 AM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums Jim Carter wrote: So contrary to what others have suggested, the NA does not mean "not authorized"; rather, it means "not applicable". Where do you get that idea? From an incorrectly printed Jepp chart perhaps? Check FAR 97.3, and I quote: (n) "NA" means not authorized. Please notice the quote I pasted from the TERPS manual. Also, please read the notes on the pages I originally referenced. They state that there is no applicable RVR (visibility) requirement for CAT IIIc. They also state that CAT IIIc is operation with visibility unsuitable for taxi. How could an approach be authorized yet have the visibility requirements part of it be not authorized? When you take that NACO plate into consideration in light of the TERPS manual, not applicable is a reasonable conclusion. But, NA has a regulatory definition for Part 97 standard instrument approach procedures. There is no provision for conjecture when NA is issued under Part 97. CAT IIIc is not authorized for any operator at the present time. The concept is that it *may* be authorized at some future time, provided something such as enhanced vision systems become good enough to taxi without any visibility. The FAA, being the way it is, had to have a building block of minima that went "all the way" so to speak, when they implemented the Category III program in the 1970s. They like having goals, even unachievable goals. ;-) |
-----Original Message----- From: Sam Spade ] Posted At: Monday, August 07, 2006 8:59 AM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums .... The FAA, being the way it is, had to have a building block of minima that went "all the way" so to speak, when they implemented the Category III program in the 1970s. They like having goals, even unachievable goals. ;-) Then why didn't they produce the same building block of minima for Newark? There is a range of visibility between RVR 06 and RVR 00 that would be below CAT IIIb, yet would allow for properly equipped aircraft, flown by properly trained crews to execute approaches, and still provide sufficient visibility for taxi operations. Is your point that the CAT IIIc approach into JFK is not authorized at all? |
news:000801c6ba26$9bd59ff0$4001a8c0@omnibook6100.. . Could this be a case of NA meaning one thing for CAT IIIc and something else for other purposes? No. In addition to the inherent implausibility of such an inconsistency, Sam has pointed out that FAR 97.3n explicitly defines NA to mean "not authorized" with regard to IAPs. How could an approach be authorized if the visibility requirement is "not authorized"? I don't follow. If "NA" appears in the IIIC line, it means a IIIC approach is not authorized. Couldn't it be unlisted because there are no DA or RVR limitations to list? No, then it would be an unpublished approach wouldn't it? Not necessarily. The IIIC approach is published by virtue of the approach plate that is labeled "CAT III". By definition, CAT III comprises IIIA, IIIB, and IIIC. There's a section of the plate that lists visibility limitations for the subcategories; the omission of IIIC from that section means that there is no visibility limitation for IIIC. The EWS plate lists all three approach minima. Assuming that's a typo for EWR (I find no EWS), the plate for ILS 4R CAT III does not list minima for IIIC; rather, it says the IIIC approach is not authorized (NA). http://www.naco.faa.gov/d-tpp/0608/00285I4RC3.PDF --Gary |
so desire? It's the same LOC/GS as the CAT III beam, right? They If I remember correctly, the glide slope reception and usability for vertical guidance are only guaranteed above DA for the approach. So, I'd assume CAT I and CAT II beams don't officially reach the surface of the runway. Andrey just flight and obstacle check to a greater tolerance for the CAT III authorization? On Mon, 07 Aug 2006 04:37:55 +0000, Andrey Serbinenko wrote: From FAA's 2004 Instrument Procedures Handbook, chapter 5: [...] The weather conditions encountered in CAT III opera- tions range from an area where visual references are adequate for manual rollout in CAT IIIa, to an area where visual references are inadequate even for taxi operations in CAT IIIc. To date, no U.S. operator has received approval for CAT IIIc in OpsSpecs. [...] But I heard that airlines are not only authorized, but required to do an auto-land every so often. Am I missing something here? Andrey Jim Carter wrote: -----Original Message----- From: Andrey Serbinenko ] Posted At: Sunday, August 06, 2006 2:42 PM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums A question: the landing minimums section for ILS CAT-III approaches may have separate lines for A, B, and C. In some cases the C line has an "NA" for visibility, and on some other plates the whole C line is missing. So, what's the difference? Does "NA" mean "not authorized", i.e. CAT-IIIC cannot be used? Thanks! Andrey Can you give us a particular plate or approach to reference please? |
Jim Carter wrote:
-----Original Message----- From: Sam Spade ] Posted At: Monday, August 07, 2006 8:59 AM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums ... The FAA, being the way it is, had to have a building block of minima that went "all the way" so to speak, when they implemented the Category III program in the 1970s. They like having goals, even unachievable goals. ;-) Then why didn't they produce the same building block of minima for Newark? There is a range of visibility between RVR 06 and RVR 00 that would be below CAT IIIb, yet would allow for properly equipped aircraft, flown by properly trained crews to execute approaches, and still provide sufficient visibility for taxi operations. Is your point that the CAT IIIc approach into JFK is not authorized at all? My point is: CAT III c is supposed to be included on all CAT III charts with the entry "NA" (Not Authorized). Where a CAT III chart does not have a line for CAT IIIc, it is not in compliance with FAA policy. |
ignored for a moment, can't you autoland off a normal CAT I ILS if you so desire? It's the same LOC/GS as the CAT III beam, right? They If I remember correctly, the glide slope reception and usability for vertical guidance are only guaranteed above DA for the approach. So, I'd assume CAT I and CAT II beams don't officially reach the surface of the runway. Andrey The G/S is not used for Autoland below 100 feet, or so. It is all radar altimetry and computer logic starting at 150 feet, when the system goes from autoland tracking to autoland align. |
| Thread Tools | |
| Display Modes | |
| Alternate minimums same as forecast weather | [email protected] | Instrument Flight Rules | 17 | February 21st 06 11:45 PM |
| Middle Marker minimums | S Herman | Instrument Flight Rules | 5 | June 9th 05 06:28 PM |
| Canadian departure minimums? | Derrick Early | Instrument Flight Rules | 3 | August 9th 04 02:43 PM |
| Skymap IIIC Mounting Options | NW_PILOT | Owning | 15 | July 8th 04 02:41 PM |
| Personal Weather Minimums | FryGuy | Piloting | 26 | December 9th 03 07:09 AM |
