I just wanted to open a discussion regarding other's personal weather
minimums for VFR flights. I recently received my PPL ASEL certificate in July and most of the days that I have flown have been very nice days. Yesterday though I got caught a bit off guard and it prompted me to set a few minimums for myself. The sky was perfectly clear, the temperature was mid 50's but it was windy and gusty. In my training I was fairly proficient with cross-winds and my home airport has two strips so usually I'd be landing with a 45 degree component or less. Yesterday however winds were sustained around 15 knots and gusts to 20+. I took off from Wilmington, NC (KILM) in a Cessna 172 and flew a couple of friends to lunch in North Myrtle Beach (KCRE). One of my friends I found out gets air/sea/car sick very easily and he didn't take anything before hand. It was a fairly rough ride and a rough day for him. When we landed in Myrtle the winds of course were roughly 90 degrees but only around 10 knots so it wasn't that bad. I did well with the landing but I was a bit nervous. On the return the wind in Wilmington was much stronger but only about a 60 degree component. The landing wasn't great but it was safe. When I kicked the rudder to line up the plane I didn't lower the left wing enough and moved towards the right side of the runway. I realize that everyone is going to be different based on experience level but I'm trying to get others thoughts for inexperienced pilots like myself. Please comment on ceilings, winds, and visibility. |
FryGuy wrote: I just wanted to open a discussion regarding other's personal weather minimums for VFR flights. First off, there are several aspects of weather to consider, but I'll throw my hat in the ring. I have between 850 and 900 hours, fly a taildragger Maule, and have a bit over 500 hours in the plane. About 1/3 of my time is cross-country. As far as wind goes, I will not go if the crosswind component at one of my destinations is over 20 knots, unless I have an alternate for that destination. Crosswinds over 15 knots will have me asking the old WWII question "Is this trip really necessary?". This is especially true if conditions are getting worse; weather has been known to move faster than forecast. I will not fly into potential icing conditions. I cancelled one trip because the freezing level was 0' AGL at my planned overnight stop and rain was forecast for sometime that afternoon or evening. If conditions are stable, I will fly in ceilings as low as 1,500', especially if conditions are expected to improve along my route. If conditions are stable, I will fly in visibility of 3 miles in haze. If the ceiling is low, I want better visibility. The worst I've been in was a lowering ceiling of about 1,000' in rain. I could see out of the left side of the windshield about as far as you can normally see things at 600' AGL. I put down at the first airport I came to. If there had not been one fairly close, I would have returned to the one I had just left (which was in better weather). I'm also very leery of fog. I will set down if the dew point/temperature spread is getting close. Another "soft" rule I have is to not fly long distances when the weather turns out different from yesterday's forecast. If it was supposed to be lousy weather and turns out to be CAVU, I stay close to home. The weather people obviously don't have clue today. George Patterson Some people think they hear a call to the priesthood when what they really hear is a tiny voice whispering "It's indoor work with no heavy lifting". |
"G.R. Patterson III" wrote:
Another "soft" rule I have is to not fly long distances when the weather turns out different from yesterday's forecast. If it was supposed to be lousy weather and turns out to be CAVU, I stay close to home. The weather people obviously don't have clue today. If the forecast is a bust, it's good to think about *why* it was wrong. Weather changes for two basic reasons -- either the qualities of the airmass where your at has changed, or a different airmass has moved in. Let's say yesterday they were forecasting today to be rainshowers, thunderstorms, and strong gusty winds, but it turns out it's really CAVU. It could just be that an approaching cold front got here faster than expected and the frontal mess is already past. One quick look at the weather map might show you that there's a high over the midwest and perfect weather clear out to colorado. Surely that's no reason to cancel a trip? |
"G.R. Patterson III" wrote in message ...
Another "soft" rule I have is to not fly long distances when the weather turns out different from yesterday's forecast. If it was supposed to be lousy weather and turns out to be CAVU, I stay close to home. The weather people obviously don't have clue today. George, I would say the "devil is in the details" here. ie, if it was supposed to be lousy wx but is CAVU, why? Is there a frontal system approaching which has slowed down, leaving its bad wx parked somewhere else? Or is there a frontal system which blew through faster than forecast leaving everything clear and blue for miles in its wake? I guess I don't see the point of staying home categorically if the wx is different than forecast. The question is "why"? Cheers, Sydney |
Snowbird wrote: I guess I don't see the point of staying home categorically if the wx is different than forecast. The question is "why"? You and Roy are correct. That's why it's a "soft" rule. George Patterson Some people think they hear a call to the priesthood when what they really hear is a tiny voice whispering "It's indoor work with no heavy lifting". |
Please comment on ceilings, winds, and visibility. I live in central PA, where the airports are usually in the valleys and the ridges are typically a thousand feet higher, so I won't set out on a VFR cross-country unless the ceiling at the airport is at least 2000. If it's less than that, I file IFR. I'll also file IFR if the viz is less than six miles; it may be less a few miles from here. The ridges are aligned 060-240. A NW wind at 20k or more can produce serious turbulence (but also produce excellent soaring conditions). A SW wind of the same velocity is not as turbulent. vince norris |
On Sun, 30 Nov 2003 17:49:41 +0000, FryGuy wrote:
I realize that everyone is going to be different based on experience level but I'm trying to get others thoughts for inexperienced pilots like myself. Please comment on ceilings, winds, and visibility. I like to fly at least 1,000 AGL, so the ceiling would be that which gives me the clearance to legally fly, it varies depending on where I fly however, i.e. rough terrain it goes up. Winds, depends on if I'm flying by myself or passengers. I'll accept a very rough ride by myself, less so with passengers. As a general rule I don't fly passengers when the wind gets above 25 knots on the ground. I'll fly up to 30 knots as long as I know I can takeoff and land within the limitations of my plane, I like a 5 knot margin on it, so if my plane will handle 15 knots crosswind, then I won't fly away from the pattern if the winds exceed 10 knots crosswind either where I'm going or coming back to. Too much risk of not being able to land where I take off from. Visibility depends on the direction I fly and what I'm doing. 3 miles is no fun on a cross country, yet I would do 5. What you have to realize is that if you have 3 miles visibility when you are flying away from the sun, you won't have that flying into the sun, so that's why the direction is important, i.e. AWOS may claim 5 miles, but you try flying with that 5 miles into the sun and you'll quickly find it's less, at least with the AWOS at our field it works that way. So you'll notice my minimums vary according to the type of flying I'll be doing. Even though you can legally fly with 1 mile vis in G you'll be taking a big risk in doing so because it can quickly go less, same goes with 3 miles vis. I think you'll find there is no single figure that will work for a minimum, it's how they all fit together and how you feel that day that determines if I fly. |
We require 3000' and five miles visibility for all student solo flights,
with maximum crosswinds of six knots. I recommend that new private pilots maintain those minimums for some time, preferably until they start their instrument training. |
"C J Campbell" wrote
We require 3000' and five miles visibility for all student solo flights, with maximum crosswinds of six knots. I recommend that new private pilots maintain those minimums for some time, preferably until they start their instrument training. As a contrasting opinion, I consider those limitations appropriate to a newly soloed student who is still having problems with crosswind landings and navigation by pilotage, and that's about all. They are both overly restrictive for most normal conditions and overly simplistic. I would consider sending someone to the checkride who actually needed such limitations for safety to be a gross abdication of instructor responsibility. Such minimums are absolutely not appropriate for a certificated pilot. I wouldn't even accept an instrument student who needed (or felt he needed) such weather minimums. Personal minimums are a lot more complex than a simple statement of ceiling, vis, and crosswind component. What constitutes an acceptable ceiling greatly depends on terrain, obstructions, and visibility under the ceiling. It also depends a lot on WHY the ceiling is what it is, and what it can reasonably be expected to do as the flight progresses. Over flatlands in good vis and stable weather, 3000 is clearly excessive. In the mountains in poor vis, it may not be nearly enough. Adequate visibility is another can of worms. Five miles (or even three) is plenty in daylight, well above terrain, over land, if navigation can be assured (either by following a road or electronically). Try that trick over water or desolate terrain at night, and your instrument attittude flying skills better be in good shape. Crosswinds are similarly complicated. A competent pilot really shouldn't need ANY crosswind minimum. Obviously this does not mean that he should be able to handle unlimited crosswinds - nobody can do that. However, it DOES mean he should be able to reliably asess the approach and landing he is making, and make the decision to go around in a timely manner. With experience, most pilots develop a feel for what they can and can't handle, depending on the airplane, runway, and other variables. Michael |
On Mon, 1 Dec 2003 08:15:36 -0800, "C J Campbell"
wrote: We require 3000' and five miles visibility for all student solo flights, with maximum crosswinds of six knots. I recommend that new private pilots maintain those minimums for some time, preferably until they start their instrument training. That would effectively ground me for most of the summer. Things just don't get that good visibility wise in the PHL area in the hot months. Rich Russell |
| Thread Tools | |
| Display Modes | |
| Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 01:27 AM |
| FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 01:07 AM |
| Flight plan | Hankal | Instrument Flight Rules | 15 | October 11th 03 09:03 AM |
| Airspace / Weather Minimums | Rose Goetsch | General Aviation | 0 | September 24th 03 09:45 PM |
| And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 05:03 PM |
