#21
![]() Jay Honeck wrote: I don't know why...I've never had a lick of trouble out of any of it. Atlas has two Narco coms, a Narco DME, and two Narco GS/VORs. All work perfectly, all the time. I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. They probably are good radios. The bad rap against them came because they were the first to introduce the concept of "non-field serviceable units". They took away the right for avionics shops to work on them, requiring they all be returned to the factory (at a price they set). However, today we have Garmin doing the same. Compare that to a King radio where any just-out-of-school avionics guy can do a field strip in an hour. -Robert |
![]() "Jay Honeck" wrote I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. Perhaps 'cause they are just old, without the new bells and whistles? -- Jim in NC |
Jay Honeck wrote:
I don't know why...I've never had a lick of trouble out of any of it. Atlas has two Narco coms, a Narco DME, and two Narco GS/VORs. All work perfectly, all the time. I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Jay, It came from avionics shops that got pretty ****ed at Narco when Narco decided to pull all service into the factory. Narco's reasons for doing it are understandable, and I think make sense, but the avionics shops have never forgiven them for taking away a good chunk of their repair business. |
On Tue, 08 Aug 2006 00:00:46 -0400, Ray Andraka
wrote: Jay Honeck wrote: I don't know why...I've never had a lick of trouble out of any of it. Atlas has two Narco coms, a Narco DME, and two Narco GS/VORs. All work perfectly, all the time. I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Jay, It came from avionics shops that got pretty ****ed at Narco when Narco decided to pull all service into the factory. Narco's reasons for doing it are understandable, and I think make sense, but the avionics shops have never forgiven them for taking away a good chunk of their repair business. Jay, I can give you an indication why they have their reputation! An aircraft owner had Narco in his aircraft and said they were 'now' ok so we took his advice, but... Purchased 2x MK12D+, CPM136, IDME891 approx 3 years ago. The IDME891 (ILS/DME) does not work properly at very low frequencies (around 108.1MHz) the ILS is ok but the DME doesn't always work. The first flight showed a problem but since it was subsequently not used at these frequencies for some time the fault was not discovered for a considerable time. Both MK12D+ NAV/COM had Transmitter audio failures. Apparently it is a known diode failure problem. Now I know what happens when you have a COM failure when overflying a military airfield :-( The latest is a severe dimming of the NAV display and the first digit has failed completely. The CPM136 AF panel produced smoke when COM 2 button pressed. The IDME891 saved us panel space and should be ideal but the intermittent DME reading problem has still to be solved. David |
Jay Honeck wrote:
I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. I've had several $300 Narco auto-dimming EL displays fail. According to some very reputable local avionics businesses, Narco isn't easy to deal with. |
An aircraft owner had Narco in his aircraft and said they were 'now' ok so we took his advice, but... Awful tale of woe snipped Okay, I'd be plenty ****ed, if that were my plane. I just haven't had any of those problems, thankfully! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In rec.aviation.piloting Jay Honeck wrote:
I don't know why...I've never had a lick of trouble out of any of it. You are apparently among the blessed few who have not had problems (yet). May it ever be thus! Atlas has two Narco coms, a Narco DME, and two Narco GS/VORs. All work perfectly, all the time. I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. Actually, Jay, it is from those of us who have experienced multiple failures of Narco equipment, and been unable to get it repaired or replaced is a timely fashion... because Narco REFUSED to provide schematics and parts to the local avionics shop and INSISTED that the equipment be sent to Narco for repair, and then the equipment would come back MONTHS later with "no problem found", and the equipment won't even turn ON, so you can tell that they did not even attempt to fix the problem. It is those of us who have had BAD experience with Narco "customer service" (read SEVERE lack thereof), who will NEVER purchase Narco equipment again. It is us who had Terra equipment that needed service (and Narco bought Terra) and put it out of business. It is US who tell our FRIENDS to stay away from Narco, and tell our non-friends to purchase Narco. For the few of you with Narco equipment that have not had problems, may it always be well for you. You are the blessed few. Best regards, Jer/ "Flight instruction and mountain flying are my vocations!" -- Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO CELL 970 231-6325 EMAIL jeratfrii.com http://users.frii.com/jer/ C-206 N9513G, CFII Airplane&Glider FAA-DEN Aviation Safety Counselor CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 240 Young Eagles! |
#28
B A R R Y wrote:
Jay Honeck wrote: I've not quite figured out where the anti-Narco sentiment come from, but it's almost as insidious as the anti-Microsoft attitudes out there. I've had several $300 Narco auto-dimming EL displays fail. According to some very reputable local avionics businesses, Narco isn't easy to deal with. "Not easy to deal with" because Narco won't supply them parts or approved repair manuals. For the owner though, it is a pretty good deal except you aren't going to drop into a shop and have them fix it while you wait. Units sent to Narco for factory repair are brought up to the latest mod level and are 100% checked before they are returned to you. After the repair, the whole unit is warrantied for 90 days. If anything breaks on it during the warranty period (anything, not just the repair), they fix it at no additional cost. As an owner, you can take comfort in knowing it is fixed correctly, completely calibrated to factory spec, and brought up to the latest revision. The shop rate is, I believe, $105/hr, which is a little higher than most avionics shops, but they also generally fix it in fewer hours. You can also get the unit evaluated before it is repaired for a flat fee of (IIRC) $105, then if you decide to repair it, that evaluation fee is applied toward the repair. You also have the option of trading it in for another radio, although the trade-in terms are not all that generous. I haven't found the factory service to be hard to deal with at all as an owner. On the other hand, I've got some horrendous stories dealing with avionics shops that applied bandaid fixes to radios, and the warranty most shops I've dealt with offer covers only the repair that they did, and expires more or less as soon as your wheels leave the ground. From the avionics shop's perspective, yeah, Narco gave them a raw deal and is hard to deal with because they won't let the avionics shops service the radios. The Narco radios are not any worse than other radios of the same vintage. Face it, aircraft panels are a harsh environment for avionics, and after being in there for 20 years you are bound to have problems. Buying 20-30 year old used equipment, even if the seller tells you it is like "now" is a crap shoot. You can't blame the manufacturer for that. |
#29
Ray Andraka wrote:
On the other hand, I've got some horrendous stories dealing with avionics shops that applied bandaid fixes to radios, and the warranty most shops I've dealt with offer covers only the repair that they did, and expires more or less as soon as your wheels leave the ground. From the avionics shop's perspective, yeah, Narco gave them a raw deal and is hard to deal with because they won't let the avionics shops service the radios. FWIW, one of the avionics shops I mention is good enough to have a popular "Flying" columnist 1300+ miles for a GPS installation. They don't do band-aids... G Every one of our failed EL displays was replaced by Narco's "factory service". We also had audio output issues were Narco returned the radios and blamed the panel and wiring. On both occasions, the radios WERE screwed up, and we paid Narco AGAIN to fix them. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 05:31 PM |
