Handheld problem in NORDO plane
Old August 19th 06, 02:41 AM posted to rec.aviation.piloting
Default Handheld problem in NORDO plane
Hey folks,
I just bought a Luscombe 8A and am launching tomorrow to fly it home.
The problem is the handheld transceiver I'm using to communicate. It
works fine on the ground. But as soon as I get 100-200 feet off the
ground it gets overwhelmed with static, like the squelch is wide open.
It's a Vertex VXA-300 attached to an external antenna.
I' ve tried turning the squelch to max. I haven't checked whether it
occurs on all frequencies because that didn't occur to me until I had
put the plane back in the hangar.
Any ideas what's going on here? All help is appreciated.
Tailwinds and blue skies,
Mike
Old August 19th 06, 03:27 AM posted to rec.aviation.piloting
Mark Morissette
*Only* when you hit a few hundred feet...or anytime the engine is running?
Personally I'd venture to take a guess that it's picking up electrical
interference from an ignition component.
Old August 19th 06, 03:36 AM posted to rec.aviation.piloting
john smith
I thought that too, but it doesn't make sense that it would start
100-200 feet AGL. If it is ignition, it will be present any time the
engine is running.
Old August 19th 06, 04:19 AM posted to rec.aviation.piloting
engine is running.
Airframe static? Isn't that what they have the static dissipation
wires for? Just a WAG.
Old August 19th 06, 04:22 AM posted to rec.aviation.piloting
Mark Morissette
engine is running.
Agreed, hence my query to double confirm that.
I think someone else further down the thread may have nailed it -
airframe static, perhaps.
Old August 19th 06, 06:14 AM posted to rec.aviation.piloting
Jim Macklin
Squelch is a "dumb" device on cheap radios. It just looks
at the total RF signal level, from any source. You said
that the frequency was 122.7, which is a common frequency,
at 200-300 feet AGL, you're getting your mags [which
probably are not shielded on a NORDO aircraft], and all the
hundreds of transmitters within 200 miles line of sight.
Your hand held may also not be sensitive enough to reject
the adjacent frequencies.
"john smith" wrote in message
| In article
engine is running?
up electrical
would start
any time the
| engine is running.
Connecting handheld to intercom in NORDO plane [email protected] Owning 2 July 7th 06 02:57 PM
aviation vhf handheld radio problem pwm Home Built 3 February 7th 06 02:03 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
