Connecting handheld to intercom in NORDO plane
Old July 6th 06, 01:31 AM posted to rec.aviation.owning
Default Connecting handheld to intercom in NORDO plane
Hey folks,
I'm buying an airplane with no electrical system. I want to outfit it
with portable coms. I have a Vertex VXA-300 handheld with headset
connector, a Lightspeed QFR Solo headset, and a David Clark DC10
headset. I haven't bought the intercom yet.
Is there an easy way to get all this to work together? Are there any
special features I need to look for in the intercom to make it work?
Will adding a PTT switch present a problem?
I'm getting some dual in a borrowed Luscombe with a portable intercom,
and for the life of me I can't figure out how to talk on the radio and
to my instructor at the same time. I suspect it's because the
intercom's not set up for connection to a handheld, but know little
about the subject.
Old July 6th 06, 01:47 AM posted to rec.aviation.owning
john smith
In article .com,
Hey folks,
about the subject.
I have an RST-442 intercom and an ICOM-A20 handheld with the HS-10
Headset Adaptor. I plug the DC-10-40's into the intercom and the
intercom plugs into the HS-10 receptacles. I then use the PTT to
transmit over the HT. I have been doing it this way 14 years without any
problems. You may have to adjust the HS-10 sidetone to minimum if you
hear feedback in your headset or someone receiving your transmission
reports feedback on your signal.
Old July 7th 06, 02:57 PM posted to rec.aviation.owning
Doug[_1_]
Get a portable intercom with a music input. Your interface troubles
will be over. You can plug the portable radio into the music input.
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
