A doubt on cabin aircon
Old August 29th 06, 09:07 AM posted to rec.aviation.piloting
Default A doubt on cabin aircon
I've been on aircraft departing from Dubai during summer and wished I
wasn't before engine bleed air starts running the aircon, because for
some reason the cooling doesn't seem to have quite the same effect when
running from APU power, at least on the A3xxs.
Since this is certainly not something psychological, why was I feeling
uncomfortable? It isn't as if doors are kept open either, since
boarding is via airconditioned telescopic chutes, not ladders.
Ramapriya
Old August 29th 06, 10:32 AM posted to rec.aviation.piloting
Montblack[_1_]
wrote)
wasn't before engine bleed air starts running the aircon, because for some
reason the cooling doesn't seem to have quite the same effect when running
In the USofA, we mostly call it "....the A/C."
Montblack
Thought that might interest you.
Old August 29th 06, 10:47 AM posted to rec.aviation.piloting
Montblack wrote:
wrote)
Didn't use it to preclude inadvertent allusions to aircraft
Ramapriya
Old August 29th 06, 02:17 PM posted to rec.aviation.piloting
Jim Macklin
A/C on a jet runs from an air cycle machine using what is
called P3 bleed air. This is air that has been highly
compressed but prior to the burner section of the engine.
The air is at 150 to 300 PSI and over 1,000 degrees F as it
leaves the engine just due to being pressurized. The air
cycle machine is used to cool and expand the compressed air,
to mix ambient air to gain volume and can discharge air into
the cabin at a temperature within the range of 30-120
degrees. But the use of P3 air reduces engine power and on
really hot days [and nights] the crew will turn the P3 A/C
bleed air off to maximize engine power.
Aux power units are much smaller engines and they produce
enough power and bleed air to run a generator and supply
bleed air to start the main engines. That is not usually
enough to fully run the A/C.
www.boeing.com/commercial/cabinair/ecs.pdf
and wished I
because for
same effect when
was I feeling
since
ladders.
| Ramapriya
Old August 29th 06, 06:44 PM posted to rec.aviation.piloting
Jay Beckman
"Jim Macklin" wrote in message
news:n7XIg.6274$SZ3.3157@dukeread04...
In Phoenix, they stick a hose in a hole...
Jay B
Old August 29th 06, 06:52 PM posted to rec.aviation.piloting
Jim Macklin
The FBOs in Phoenix have portable air chillers they roll up
to the airplane to cool the cabin and even the baggage and
battery compartment. But it can get hot inside withy the
engines at ground idle.
"Jay Beckman" wrote in message
news:C1%Ig.18233$RD.12650@fed1read08...
| "Jim Macklin" wrote
in message
is
engine.
it
air
air,
into
on
A/C
produce
usually
| Jay B
Old August 29th 06, 07:13 PM posted to rec.aviation.piloting
Jay Beckman
news:_e%Ig.6303$SZ3.5545@dukeread04...
I was actually thinking commercial flights (as was, I thought, the OP...)
They can get cabins down right frigid when they get the hose in early and if
the compressor is running well...
I've actually heard people ask the FA if they could turn the air DOWN in
July.
Jay B
Old August 30th 06, 12:19 AM posted to rec.aviation.piloting
Jim Macklin
news:Ks%Ig.18236$RD.20@fed1read08...
| "Jim Macklin" wrote
in message
up
and
thought, the OP...)
the air DOWN in
| July.
| Jay B
Old August 30th 06, 12:33 AM posted to rec.aviation.piloting
Jim Macklin
Sorry for the blank post...hit the wrong key. What I was
going to say was that the FBO probably won't roll out the
air machine for your 172, but the bizjets and King Airs use
them all the time. An example, a heat soaked Beechjet
baggage compartment will reach the NiCad battery limiting
temperature and cooling the battery should be done before
engine start.
James H. Macklin
ATP,CFI,A&P
"Jim Macklin" wrote
in message news:3_3Jg.6315$SZ3.3480@dukeread04...
|| "Jim Macklin"
wrote
| in message
roll
| up
| and
| the
| thought, the OP...)
| the air DOWN in
|| July.
|| Jay B
Old August 30th 06, 01:26 AM posted to rec.aviation.piloting
Jay Beckman
news:194Jg.6321$SZ3.4639@dukeread04...
engine start.
James H. Macklin
ATP,CFI,A&P
Interesting...
I've experienced what our desert heat can do to car batteries...it ain't
good.
Jay B
What is cabin air pressure set at scm General Aviation 25 October 16th 05 03:29 AM
Replacement Cabin Knobs Jonathan Goodish Owning 5 April 7th 05 06:34 PM
Cabin Air Pressure [email protected] Piloting 9 December 20th 04 03:07 PM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 08:35 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
