Rotation
Old September 13th 06, 11:22 PM posted to rec.aviation.piloting
Roger (K8RI)
Default Rotation
On Wed, 13 Sep 2006 21:27:32 GMT, "Allen"
"Mxsmanic" wrote in message
Allen writes:
I'm not a simmer but try pulling the left throttle to idle, right
throttle
wide open and then stall it :-)
Ahhh, what the heck... Why not also push the left rudder pedal to the
floor at the stall break?
Is this going to cause some sort of sim catastrophe?
No, just an exciting ride :-)
www.rogerhalstead.com
  #82
Old September 14th 06, 03:42 AM posted to rec.aviation.piloting
Mxsmanic
Default Rotation
Allen writes:
I was unable to get the Baron to stall. A warning of some kind sounds
and the aircraft pitches forward each time I try to stall it. Since I
can't see the yoke in the sim, I don't know if the change in pitch is
a result of a stall or some sort of automated attempt to prevent it,
but in any case it's very irritating (although perhaps I'd be thankful
for it in real life?).
With one engine set to idle and pulling all the way back, the warning
sounds, the aircraft bounces forward and backward, and it eventually
meets the terrain in a rather lazy roll.
  #83
Old September 14th 06, 07:44 AM posted to rec.aviation.piloting
John Gaquin
Default Rotation
What did you expect to happen when you stalled the airplane?
  #84
Old September 14th 06, 08:31 AM posted to rec.aviation.piloting
Thomas Borchert
Default Rotation
Allen,
I'm not a simmer but try pulling the left throttle to idle, right throttle
Sims don't sim that very well.
Thomas Borchert (EDDH)
  #85
Old September 14th 06, 12:50 PM posted to rec.aviation.piloting
Mxsmanic
Default Rotation
John Gaquin writes:
I expect it to lose altitude rapidly. Beyond that, it depends on the
design of the aircraft.
  #86
Old September 14th 06, 05:50 PM posted to rec.aviation.piloting
John Gaquin
Default Rotation
Well, in the category of "beyond that", in light aircraft the rapid
altitude loss is usually preceded and/or accompanied by an abrupt pitch
down. One caveat: there may be some newer light craft designs that don't
pitch too abruptly. I don't know about that. But in the great bulk of
light aircraft, such as the Baron you were discussing, there will be a nose
drop. I don't think you're dealing with a major design flaw in your sim
program, perhaps just a question of degree or intensity.
  #87
Old September 15th 06, 02:18 AM posted to rec.aviation.piloting
Mxsmanic
Default Rotation
John Gaquin writes:
As long as the sim is faithful to the real aircraft, I'll deal with
it. I just want to make sure that it's not a sim artifact, as I don't
want to build bad habits based on errors in simulation, just in case I
ever actually do have an occasion to pilot a real aircraft.
  #88
Old September 17th 06, 05:10 AM posted to rec.aviation.piloting
Skywise
Default Rotation
Mxsmanic wrote in
Skywise writes:
Before I got the force feedback stick, trim didn't make sense
since you couldn't feel it in the controls.
The hundred bucks I spent on mine were well worth the enhanced
simulation experience. Flight is much smoother and landings
are greased much more often.
What brand and model of stick was this? And has it been reliable?
It's a Microsoft Force Feedback 2. It's been a while since I
bought it so it may not even be made anymore.
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html
Sed quis custodiet ipsos Custodes?
  #89
Old September 17th 06, 05:12 AM posted to rec.aviation.piloting
Skywise
Default Rotation
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in
Snipola
I don't understand what non-force feedback joysticks you guys are using but
my MS stick is not force feedback and if I don't trim I have to move the
stick to a non-centered position which requires constant force to keep it
there. Are you guys using joysticks with no centering springs?
Mirosoft Force Feedback 2.
No springs. It has active servos powerful enough to whip the
stick out of your hand. But that usually only happens on the
third party aircraft I download that don't have the feedback
design done right. On the default aircraft in MSFS the feedback
can be strong and firm, but not violent.
Brian
  #90
Old September 17th 06, 01:04 PM posted to rec.aviation.piloting
Mxsmanic
Default Rotation
Skywise writes:
I note that PMDG recommends that you not use force feedback with their
aircraft. According to them, it's so far from the real aircraft that
it does more harm than good (at least for the large aircraft that they
model).
The danger of assumption Jay Honeck Piloting 26 September 15th 05 12:37 PM
Thermal Rotation - Revisited.... Mark Zivley Soaring 3 July 3rd 04 02:11 PM
Fighter takeoff rotation Boomer Military Aviation 10 March 17th 04 06:43 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
Airmen in Europe may go back to three-month rotation schedules Otis Willie Military Aviation 0 August 22nd 03 11:47 PM
