The danger of assumption
Old September 13th 05, 02:47 PM
Jay Honeck
Default The danger of assumption
The other night, as we approached rotation speed, we skipped half a dozen
times before breaking cleanly. I made some snide remark about this to Mary,
and assumed that she was holding the nose down too long, causing the skip.
"Poor piloting," I harrumphed to myself... "Danged tires are too expensive
to be mistreated this way," I silently grumbled... (This was the night I
was already in a ****y mood, so everything that had transpired to this point
was fitting into my crappy view of the world at the time...)
Ten minutes later, with me in the left seat, I advanced the throttle
smoothly, reached rotation speed, started to gently pull back -- and skipped
half a dozen times down the runway before breaking cleanly. Dang.
Needless to say, of course, Mary pointed this out to me in blunt and certain
terms... :-)
Here I had assumed that she was holding it down too long before rotation --
but it had now become apparent that she (and I) were in fact rotating
prematurely. Wind conditions were calm, temperatures were in the 80s,
humidity was very high, and a ground fog was developing as we landed.
Otherwise, everything was done according to Hoyle, with 2 notches of flaps
set for take-off.
Usually the plane just "flies itself off" the runway in this
configuration -- but not that night. Conditions of flight were fairly
unusual, for us -- the back seat was empty, no wind, high humidity, fairly
light on fuel -- so I suppose it was just pilot error.
It seems odd, however, that we *both* made the same mistake, which leads me
to wonder if there was something atmospheric going on...
Thoughts?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 13th 05, 02:57 PM
Paul kgyy
Might have been an air density change just above the ground? As ground
fog creeps in, the air right at the surface has a higher relative
humidity, and maybe a temperature change as well.
Old September 13th 05, 03:17 PM
Jim Burns
I think you were simply lighter than you are used to being.
unusual, for us -- the back seat was empty, fairly
light on fuel
The airplane was ready to fly before the pilots were expecting it to be.
Old September 13th 05, 03:24 PM
N93332
"Jay Honeck" wrote in message
news:HLAVe.346894$xm3.194258@attbi_s21...
skipped half a dozen times down the runway before breaking cleanly.
Dang.
me to wonder if there was something atmospheric going on...
Thoughts?
You too??? I think it usually happens to me when there is less fuel and
weight on board than usual and possibly other factors such as humidity,
temperature, technique, pilot error, etc. When it happens to me, I'll do
some touch and goes (or stop and goes) and try it again to see if it
repeats; sometimes it does and sometime it doesn't so I'm not really sure
why...
-Greg B.
Old September 13th 05, 03:50 PM
Jay Honeck
Possibly, but...
light on fuel
Actually, the plane was NOT ready to fly before we were expecting it to
be. In fact, just the opposite -- we both rotated prematurely, BEFORE
the plane was ready to fly, and it just skipped down the runway a few
times before finally achieving a positive rate of climb.
That's what's a bit confusing about this scenario. If this were a
"lighter than normal" thing, we should have lifted off *earlier* than
expected, not later -- right?
Jay Honeck
Iowa City, IA
Pathfinder N56993
"Your Aviation
Old September 13th 05, 04:00 PM
Icebound
1. If there has been a night inversion already starting to develop, your
own motion through the air is causing turbulence and breaking down the
inversion, bringing down air of a different temperature and wind structure.
The conditions that you had while standing still on the apron, are not
exactly the conditions that you are experiencing while hurtling down the
centre line. Whether your AI is reacting quickly enough to the changing
conditions is probably open to debate.
2. A small corollary of 1. If the surface winds were calm, did you check a
recent surface weather chart to see the *likely* wind aloft? If the
pressure configuration indicated a tailwind, the combination of 1 and 2
might result in your symptom.
3. Even if 1 and 2 were not the case, calm winds still have to be watched
carefully. They easily switch to a small tailwind with no notice, which
could make the difference for a light (and lightly-loaded) aircraft. I make
a point to rotate a few knots higher in calm winds just to compensate for
the possibility of a sudden tailwind gust.
Old September 13th 05, 04:12 PM
RK Henry
On Tue, 13 Sep 2005 13:47:19 GMT, "Jay Honeck"
It might be worth considering the possibility that something about the
rigging has changed. An extra-careful preflight or even a trip to the
shop may be in order. If someone has backed a truck into it while it
was parked, the damage might not be immediately obvious.
I've had dragging brakes produce interesting effects when breaking
ground.
RK Henry
Old September 13th 05, 04:55 PM
Jim Burns
Oops, sorry, I read that wrong. Too many allergy meds increaseing the
density altitude in my head.
What indicated airspeed do you normally rotate at? (no real answer, just
curious) Take off with the twin requires us to hold it onto the runway
until 80mph, we definately do not want to rotate prematurely in case of an
engine failure.
Old September 13th 05, 05:16 PM
Trent Moorehead
me
Thoughts?
My first thought was that perhaps you have less power than you usually do,
causing you to hang at the rotation speed a little longer than usual. Did
you rotate by the same point as you normally do? Other things: Mag check
normal? Normal RPM on takeoff run?
-Trent
PP-ASEL
Old September 13th 05, 05:19 PM
Mortimer Schnerd, RN
engine failure.
The behavior of aircraft at rotation vary quite a bit. It's been my experience
you can rotate a Cessna at any speed above stall, roll along on the mains with
the nose up for a few moments, and then the aircraaft will lift off when it's
ready. Makes for a pretty airline style departure (until you're about an inch
off the ground).
Cherokees are the exact opposite. If you try to rotate before it's ready to
fly, you just skip along until the aircraft is finally ready. I've always
preferred to hold of rotation until I've acheived flying speed, then pull it off
all at once. It's not as elegant but it does avoid the nosewheel skipping down
the runway.
I haven't flown enough Beechcraft to comment on them. Twins I do know,
however... and I'm with you on that one. I generally hold off rotation until
well above Vmc but before blue line. The closer to blue line the happier I am.
VE
Laser danger [email protected] Home Built 0 January 9th 05 06:54 AM
IO 360 Power down (danger, long, rambling post!) Jim Harper Home Built 24 July 11th 04 12:04 AM
Winching-Cable danger Andy Davey Soaring 0 March 23rd 04 03:32 PM
Low-Tech Grenades A Danger to Helicopters Otis Willie Military Aviation 9 November 22nd 03 06:13 AM
World War II airmen remember danger Otis Willie Military Aviation 0 September 29th 03 09:32 PM
