#31
"Mxsmanic" wrote in message
What kind of plane do you suggest he should have been flying that would have made this accident less likely? I don't have enough information to make a suggestion. That never stopped you before. If there's any increased overall risk in flying a Cirrus, it's the false sense of security it may give some pilots flying IFR. More generally, it's the the false sense of security it may give some pilots. Why is the sense of security false? Are you suggesting that glass cockpits aren't a very good thing? m |
#32
Happy Dog writes:
Why is the sense of security false? Because the set of situations in which the gadgets actually increase security is much smaller than the set of situations in which they _appear_ increase security to the unsophisticated observer. Are you suggesting that glass cockpits aren't a very good thing? In theory, they are fine. In practice, I don't trust them. There are extremely complex systems that are not adequately tested or debugged, and they are backed by computers, which have catastrophic failure modes that more traditional avionics systems do not share. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#33
"Mxsmanic" wrote in
Why is the sense of security false? Because the set of situations in which the gadgets actually increase security is much smaller than the set of situations in which they _appear_ increase security to the unsophisticated observer. Examples, please. Are you suggesting that glass cockpits aren't a very good thing? In theory, they are fine. In practice, I don't trust them. There are extremely complex systems that are not adequately tested or debugged, and they are backed by computers, which have catastrophic failure modes that more traditional avionics systems do not share. And these failures have resulted in how many accidents vs. those caused by failures in old technology avionics? moo |
#34
Happy Dog writes:
Examples, please. Parachutes on Cirrus aircraft. And these failures have resulted in how many accidents vs. those caused by failures in old technology avionics? They aren't widespread enough in most parts of the industry to be a problem yet, and in any case, avionics failures are not a leading cause of accidents, IIRC. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#35
On Fri, 13 Oct 2006 16:32:45 -0400, Happy Dog wrote:
Why is the sense of security false? Are you suggesting that glass cockpits aren't a very good thing? You didn't read about NW_Pilot's Atlantic Crossing? - Andrew |
#36
On Fri, 13 Oct 2006 12:16:43 -0400, Peter R. wrote:
My recollection of these accidents is that at least two of those three were a result of a mechanic incorrectly mounting the ailerons, not inherent control system design flaws. I don't know anything about these incidents. However, if I noted that the number of "mechanic installed incorrectly" was unusually high for something, I'd look for a problem which caused this. It could be design...or perhaps documentation, training, or something else. - Andrew |
#37
On Fri, 13 Oct 2006 09:23:46 -0700, cosmo_kramer1 wrote:
I think we can all agree on that! Balloon? - Andrew |
#38
Dylan Smith wrote:
On 2006-10-13, Mxsmanic wrote: Also, it seems like the aircraft is actively marketed to precisely this type of buyer, which makes things even worse. It looks like Carl Lidle fell for it (in more ways than one). The type of aircraft he was in was utterly irrelevant. Smashing into a building in a Cessna 150 is just as fatal as hitting a building in a Cirrus, or a Learjet, or an ultralight. It is completely relevant. A Cessna 150 could make the turn much tighter than could a Cirrus. They may well have missed the building easily had they been in a slower airplane. Matt |
#39
Dylan Smith wrote:
On 2006-10-13, Mike wrote: The type of aircraft he was in was utterly irrelevant. Smashing into a building in a Cessna 150 is just as fatal as hitting a building in a Cirrus, or a Learjet, or an ultralight. How do you know the aircraft is irrelevant? Please post your source. F=ma (force = mass x acceleration). Or in this case, deceleration. A 100kg human in an ultralight travelling at 25 metres/sec hitting a building and decelerating to zero in 0.5 sec (entirely plausable) will experience a force of 100 * 50 newtons (5,000 newtons) in the initial impact. Not to mention the bits of the building which are likely to shatter and pierce the body. But a force of 5,000 newtons against a human body is usually enough to kill. So it's pretty irrelevant whether a plane is a slow one or a fast one like a Cirrus - slamming (to use Lune's favorite word) into the side of a building is usually not going to be survivable. You are making the flawed assumption that the type of airplane has no bearing on whether the crash occurred. A slower airplane may well have avoided the crash and thus your analysis above is irrelevant. Matt |
#40
Jim Macklin wrote:
Thurman Munson also had a CFI with him too. A CFI who is not experienced in the airspace, or airplane is a broken crutch. A PIC accompanied by a CFI is not doing his command job. Rules by the Yankee's organization to require a CFI should require active crew resource management, planning and dispatch by the CFI. Two pilots waiting for the other to make a decision will have an accident sooner or later. IMHO http://www.airdisaster.com/reports/n...SB-AAR-80-2%22 The report you cite mentions that Munson's "instructor" was merely a passenger for the flight. He had no flying experience in turbojet aircraft (I assume they mean as pilot). The instructor in this accident apparently was well aquainted with the aircraft type and provided instruction in that type. As for airspace awareness, that may well be a factor and there is no subsitute for local experience. However the airspace around Manhattan is not a secret and I would expect an instructor to be able to obtain all of the information needed to safely pass through that airspace, from the terminal chart, from talking to local pilots, and just mentally calculating the turn as well as both pilots keeping their eyes outside the airplane. Does anyone know at what elevation the impact took place? Were the pilots trying to change the turn at the last minute if they suddenly saw the building, or is there anything to suggest that they knew they were headed for the building but unable to change course (mechanical malfunction), despite trying to do so? I'm very curious about the time interval between when they first realized there could be a collision and the impact. |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
Cirrus demo | Dan Luke | Piloting | 12 | December 4th 05 05:26 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
