When do you use autopilots?
Old October 22nd 06, 05:06 PM posted to rec.aviation.piloting
The Visitor
Default When do you use autopilots?
Reasonable.
I must ask and encourage you to at least take a discovery flight at a
local flying school. Have you ever given it a try?
Mxsmanic wrote:
The Visitor writes:
Do you sit there at your sim, droning along for 3,4,5,6,7,8,9 hours
enroute, handflying?
No, but I was wondering if I was "cheating" by using the autopilot.
What aircraft/route are you asking about?
At this very instant (thanks to autopilot), I'm flying VFR from KPHX
to KSAN, via GBN JUDTH MOHAK WARTT BZA ARGUS IPL NICKK KUMBA PILLO
CANNO BARET RYAHH HAILE KSAN. The GPS unit is handling the routing.
I picked 6000 feet MSL for most of the flight because the manual says
the Baron is highly efficient at this altitude; I'll go briefly to
8500 to get over the mountains on the way in to San Diego.
If this is the way real pilots use autopilot, fine. I just don't want
to do anything that would handicap me in real flight (I'm not sure how
experienced real pilots are supposed to be in hand-flying).
Old October 22nd 06, 06:06 PM posted to rec.aviation.piloting
Matt Barrow
m...
Turbulence can actually be more difficult on the autopilot. It
wants to hold you to course and altitude and tends to overcontrol
to stay there.
Some AP's require you to disengage during moderate or stronger turbulence.
There's also a big difference between rate-based and attitude-based.
Hand flying you're willing to take the slight
deviations because you know it will even out in the long term.
As long as one does not over compensate.
Old October 22nd 06, 06:28 PM posted to rec.aviation.piloting
Roy Smith
Is there such a thing as pure "rate-based" vs. "attitude-based" in modern
AP's any more? Back in the days of steam gauges, each state variable
involved another mechanical data pick-off and gobs of discrete circuitry,
so controlling one variable at a time made sense.
In a glass cockpit, I would think you would grab all the data that's
available and come up with a control strategy which mixes inputs.
Old October 22nd 06, 07:20 PM posted to rec.aviation.piloting,rec.aviation.student
Judah
Mxsmanic wrote in
Within what limits? I fly to a heading and then 30 seconds later when
I check it again I've drifted two degrees or so and have to move it
back. Altitude is a much bigger problem, with a constant
roller-coaster ride through as much as 150 feet or so for quite a
while. By the time I wrestle it onto a steady altitude, I'm being
told to climb or descend again.
The accepted limits are documented in the Airmen Practical Test Standards,
which you can read online he
http://www.faa.gov/education_researc...ards/pilot/med
ia/FAA-S-8081-14A.pdf
The limits for Instrument flight are slightly "tighter" and are documented
he
http://www.faa.gov/education_researc...ards/media/FAA
-S-8081-4D.pdf
2 degrees of heading is acceptable. 150 feet of altitude, however, is not.
Old October 22nd 06, 07:28 PM posted to rec.aviation.piloting
Judah
Mxsmanic wrote in
The Visitor writes:
Is this route off-airway? What is the OROCA in that area? 8500 is not an
IFR altitude, so unless you will be changing to VFR on top, you'll probably
either be at 8000 or 10000 in real life. I don't know the area well enough
to know for sure...
It sounds like you have some ideas of what it takes, but you really should
get some formal training. If you're that afraid of flying, you should at
least go to a Ground School course. They are not typically very expensive,
but they are very informative. Another alternative might be to purchase the
Gliem test prep books.
Old October 22nd 06, 07:53 PM posted to rec.aviation.piloting
Mxsmanic
The Visitor writes:
Reasonable.
No. No money and no time to try it.
Old October 22nd 06, 07:57 PM posted to rec.aviation.piloting
Mxsmanic
Ron Natalie writes:
Sometimes it's BETTER FORM to use the autopilot on shorter flights.
Enroute is generally a lot of inactivity. Takeoff and landing
is the busy part of IFR. Best to off-load onto George when
you are busy.
I'm confused. Are you saying that autopilot should be used on
take-off and landing?
It seems that most autopilots aren't much help with take-off and
landing, beyond following an ILS approach most of the way in. Large
aircraft have fancy stuff that can autoland, but I don't know if small
aircraft can be equipped in that way (?).
to stay there. Hand flying you're willing to take the slight
Interesting. Are there any fancy autopilots that are smart enough to
deal with turbulence?
On a commercial airliner, wouldn't it be preferable to let the
autopilot wrestle with the turbulence in order to avoid upsetting
passengers with more radical movements in hand flying (assuming that
the pilot does not attempt to correct for minor movements from
turbulence)?
Old October 22nd 06, 08:00 PM posted to rec.aviation.piloting
The Visitor
Where aare you located?
Old October 22nd 06, 08:23 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Judah writes:
he
-S-8081-4D.pdf
Thanks. I have saved these documents and will examine them in greater
detail as time permits.
Old October 22nd 06, 08:24 PM posted to rec.aviation.piloting
Mxsmanic
The Visitor writes:
Paris, France
Rudder for final runway alignment (?) Mxsmanic Piloting 124 October 2nd 06 09:39 PM
Piper Altimatic II autopilots - anyone? nobody Owning 12 February 8th 06 03:38 PM
DGs and Autopilots Andrew Gideon Owning 11 April 14th 05 06:04 PM
Autopilots... failure modes john smith Instrument Flight Rules 14 October 22nd 04 05:22 AM
Artificial Horizon/Autopilot Connection Jay Honeck Owning 2 September 7th 03 05:07 PM
