Hi,
I'm studying for my IR and having some trouble in calculating the outbound times. Has anyone got any easy way of calculating the times. |
times. Has anyone got any easy way of calculating the times. What I do in real life is to time the inbound, and then whatever the error is on the inbound, I apply it to the outbound the opposite way. It may take a couple of turns to get it right since the relationship is not linear, but for small wind speeds compared to aircraft speeds, it seems to work well enough. Time outbound one minute. Time inbound. Say it's forty seconds. That's twenty seconds too little, so next time go outbound a minute and twenty seconds. Time the inbound. Say it's fifty-five seconds. Next time go outbound another five seconds - that is, go out a minute and twenty-five seconds. Iterate until happy. If interested, the actual formula is: (where v is velocity, t is time, and d is distance) v = d / t or d = v t The two distances (along the inbound course) will be the same, to first order, so set them equal. d = (v1)(t1) = (v2)(t2) Rewrite v1 as v+w and v2 as v-w (where w is wind speed) Rewrite t1 as t and t2 as t+d (where d is the difference between one minute (t1) and the inbound.) We end up with (2w)/(v-w) = d If I didn't mess anything up. (this doesn't take the crosswind's effect on the half circle sizes into effect). Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
On 10/27/06 14:35, Alan Burke wrote:
Hi, I'm studying for my IR and having some trouble in calculating the outbound times. Has anyone got any easy way of calculating the times. Alan, See Jose's answer for the timing. All I wanted to add was that you should guestimate the crosswind correction before entering the hold, and apply this on the first leg. Otherwise, the crosswind may really mess with the timings. Remember to adjust for the crosswind on the inbound leg as well ;-) I would have guessed your question would have been more like "how do you tell when to *begin* timing on the outbound leg". .... perhaps that's still coming ;-) I hope that you'll post more about your IR adventures. I sure would like to read about them and participate in answering questions, etc. Best Regards, -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
On 10/27/06 14:35, Alan Burke wrote: Hi, I'm studying for my IR and having some trouble in calculating the outbound times. Has anyone got any easy way of calculating the times. Keep in mind, as you progress with this, that the "rule" is to not exceed one minute inbound to the NDB. |
Thanks guys for the response. What I suppose I am asking if how do you work
out the times (pre-planning) of the hold. I.e if you know the wind direction and speed for the hold, I've worked out the single drift and in my notes it says to work out the timings use 75% of the head / tail wind factor. This is where I get stuck. How do you work that out?? "Sam Spade" wrote in message ... Mark Hansen wrote: On 10/27/06 14:35, Alan Burke wrote: Hi, I'm studying for my IR and having some trouble in calculating the outbound times. Has anyone got any easy way of calculating the times. Keep in mind, as you progress with this, that the "rule" is to not exceed one minute inbound to the NDB. |
"Alan Burke" wrote: Thanks guys for the response. What I suppose I am asking if how do you work out the times (pre-planning) of the hold. I.e if you know the wind direction and speed for the hold, I've worked out the single drift and in my notes it says to work out the timings use 75% of the head / tail wind factor. This is where I get stuck. How do you work that out?? Don't try to "work it out". Your primary job is to fly the airplane, not work out complex geometry problems. As you're approaching the hold, take a WAG (Wild Assed Guess) at wind strength. In most common trainers, you'll be holding at about 90 kts. A really big headwind component on your outbound leg would be 30 kts, making your outbound groundspeed 60, and your inbound groundspeed 120 (double your outbound). So, that's pretty much an upper limit, and gives you your first WAG: with a really honking headwind outbound, fly the outbound leg for 2 minutes. Estimate down from the with a moderate headwind outbound, try 1.5 minutes. With little or no wind, try 1 minute. With a moderate tailwind outbound, try 50 seconds, and with a really honking tailwind outbound, try 40 seconds. If you're trying to get things any more accurate than that, you're doing way too much work. It's better to fly your first outbound leg a little bit long rather than a little bit short. If you under-estimate how long to fly outbound, by the time you complete your inbound turn, you can be almost on top of the NDB and not have enough time to re-intercept the inbound bearing before you reach station passage. When that happens, you tend to just keep getting more and more confused and lost. But, the real way to do NBD holds is to tear that piece of crap ADF out of the panel and train in a GPS-equipped airplane. If your school doesn't have GPS in their trainers, find another school. |
Alan,
my notes it says to work out the timings use 75% of the head / tail wind factor. Hmm. Why not 100 percent? The way I would do it is to figure out the percentage the head/tail wind is of my IAS (TAS, if you want to get precise). Then, I would correct 1 minute by that percentage. From your notes, your supposed to take 75 percent of that percentage. In reality, this takes way too much brain power away from controlling the aircraft. Make intelligent guesses. E.g. your holding speed is 90 knots, your wind component is an estimated 10 knots, so you try a 10 seconds correction. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
Alan, my notes it says to work out the timings use 75% of the head / tail wind factor. Hmm. Why not 100 percent? The way I would do it is to figure out the percentage the head/tail wind is of my IAS (TAS, if you want to get precise). Then, I would correct 1 minute by that percentage. From your notes, your supposed to take 75 percent of that percentage. In reality, this takes way too much brain power away from controlling the aircraft. Make intelligent guesses. E.g. your holding speed is 90 knots, your wind component is an estimated 10 knots, so you try a 10 seconds correction. At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. |
I wouldn't go that far. We are also building good habits and attitudes for the future. One day we may be flying jet aircraft, who knows? The attitudes you start out with are likely to be the attitudes you end up with, and the skills you learn from day one are the ones that come back to you in an emergency. However, yes, there is plenty of room in the hold for a spam can. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
On 10/28/06 08:24, Sam Spade wrote:
Thomas Borchert wrote: Alan, my notes it says to work out the timings use 75% of the head / tail wind factor. Hmm. Why not 100 percent? The way I would do it is to figure out the percentage the head/tail wind is of my IAS (TAS, if you want to get precise). Then, I would correct 1 minute by that percentage. From your notes, your supposed to take 75 percent of that percentage. In reality, this takes way too much brain power away from controlling the aircraft. Make intelligent guesses. E.g. your holding speed is 90 knots, your wind component is an estimated 10 knots, so you try a 10 seconds correction. At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. Exactly. I think if you show the inspector that you: 1. consider the crosswind when taking a guess at your outbound and inbound headings; 2. consider the head/tail wind when taking a guess at your initial outbound timing; 3. make a reasonable adjustment to your second outbound timing after seeing what your first inbound leg time was. he will be impressed. Note that in all three cases, all that will matter is that you make the correction in the right direction; the *amount* of the correction won't matter to them. I know that during training, I would like to go around the holds over and over, making minor corrections to try to get the time and heading to work out perfectly - my instructor would just get bored and make us move on ;-) -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Academy holds memorial dedication for Navy's Blue Angels | Otis Willie | Naval Aviation | 0 | May 27th 06 04:01 AM |
timing holds | [email protected] | Instrument Flight Rules | 16 | February 17th 05 12:18 AM |
Holds when PT NA | David Rind | Instrument Flight Rules | 19 | April 9th 04 08:28 PM |
Holds for currency requirements | Paul Tomblin | Instrument Flight Rules | 8 | March 12th 04 06:49 PM |
Yokota holds memorial service for NCO | Otis Willie | Military Aviation | 0 | August 15th 03 09:22 PM |
