Replacing innertubes without replacing tires?
Old November 1st 06, 11:10 PM posted to rec.aviation.owning
Ben Jackson
Default Replacing innertubes without replacing tires?
On 2006-11-01, Gig 601XL Builder wrote:
Fill them with Nitrogen they won't leak as much. Not that I've tried it.
The way my A&P drives a nitrogen cylinder they wouldn't leak because
the wheel halves would be in different counties...
Ben Jackson AD7GD
http://www.ben.com/
Old November 1st 06, 11:55 PM posted to rec.aviation.owning
Ray Andraka
How do you figure that? Air is already mostly nitrogen. Why would a
higher concentration of nitrogen leak any less than plain old air? The
difference in atom sizes between nitrogen and the other major
constituents of air is on the order of a few percent, so even the other
constituents aren't going to leak out leaving just nitrogen.
Old November 2nd 06, 12:20 AM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
"Ray Andraka" wrote in message
difference in atom sizes between nitrogen and the other major constituents
of air is on the order of a few percent, so even the other constituents
And, that few percent difference makes a small fraction of a percent
difference in how fast they leak. Not enough to notice, but enough that tire
stores around here (Detroit) make all kinds of wild claims about the
advantages of buying tires from them and having them filled with N2...
Geoff
Old November 2nd 06, 02:15 AM posted to rec.aviation.owning
RST Engineering
Because back in the good old daze when inner tubes weren't quite as well
done from a chemistry point of view the oxygen in the air WOULD attack the
rubber and cause it to deteriorate quicker than with pure nitrogen. Back
when I wuz wit da airlines, we used nitrogen exclusively to fill tires on
the torches.
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
news:hdSdnbmXe9pLpNTYnZ2dnUVZ_sidnZ2d@wideopenwest .com...
tire stores around here (Detroit) make all kinds of wild claims about the
Geoff
Old November 2nd 06, 02:43 PM posted to rec.aviation.owning
Gig 601XL Builder
As I said I haven't tried it but there are 398,000 hits when you Google
Nitrogen filled tires. I saw and ad for it in one of the aircraft mags the
other day and hadn't really looked into it that much. But glancing at the
Google results the opinions are mixed between works well and snake oil.
Old November 2nd 06, 06:48 PM posted to rec.aviation.owning
Ray Andraka
There are reasons for using nitrogen in tires, but leakage isn't one of
them. From what I understand, high pressure tires often need nitrogen
because if regular air was used the high pressure of the oxygen mix
becomes combustible and can lead to tire fires. In our spam cans
though, the pressures aren't high enough to cause problems. There's
also the convenience thing if you happen to have bottled nitrogen in the
hangar, and finally some have said that it keeps the rubber from
oxidizing, but I doubt that is a real issue since the outsides will
deteriorate long before the inside oxidizes enough to be a problem.
Old November 2nd 06, 07:33 PM posted to rec.aviation.owning
Mike Noel
I don't know the practical aspects of N2 v O2 in modern tubes, but the
partial pressure of O2 in a tire inflated to 30 psi is 3x that on the
outside of the tube. If anything in the rubber tended to oxidize, it would
oxidize significantly faster at the higher O2 partial pressure.
It may not be a practical problem in tubes, but I'll bet it makes a
difference in a strut (1000 psi?)
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
the other day and hadn't really looked into it that much. But glancing at
the Google results the opinions are mixed between works well and snake
oil.
becomes combustible and can lead to tire fires. In our spam cans though,
the pressures aren't high enough to cause problems. There's also the
convenience thing if you happen to have bottled nitrogen in the hangar,
and finally some have said that it keeps the rubber from oxidizing, but I
doubt that is a real issue since the outsides will deteriorate long before
Old November 2nd 06, 09:48 PM posted to rec.aviation.owning
Gig 601XL Builder
"Mike Noel" wrote in message
Is anybody suggesting the use of O2?
Old November 2nd 06, 10:05 PM posted to rec.aviation.owning
How do you not use O2 if you use air?
Jim Pennino
Remove .spam.sux to reply.
Old November 3rd 06, 02:17 PM posted to rec.aviation.owning
Gig 601XL Builder
news
would
Well if we are going to call using "air" using O2 we might as well call it
using N2. There is a lot more N than O.
Shelf Life of [Spare] Tires? [email protected] Soaring 8 November 16th 05 07:03 PM
airing tires Fly Owning 6 August 30th 05 04:24 AM
Replacing Cobra trailer 13 inch tires with larger? Andy Blackburn Soaring 6 August 19th 04 03:15 AM
WTB: Good Set 500 x 5 Wheels, Tires and Brakes Steve Sharp Restoration 0 March 20th 04 04:48 AM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
