airing tires
Old August 24th 05, 10:59 PM
Fly
Default airing tires
Not often since I started using the 'airstop' tubes.
Desser tires has the best deal.
Kent Felkins
Subject: Flat Tires?
Date: Wednesday, August 24, 2005 4:51 PM
One of our least favorite jobs (thanks to our "Fancy Pants" with their
stupid, under-sized access doors) is airing up the tires on our Pathfinder.
I pull the plane back and forth while Mary fishes around for the stupid
nipple. If you want to hear a woman cuss like a sailor, just stop by the
hangar on tire-filling day!
It seems like we're having to fill the tires way too often. At least every
3 - 4 weeks, we notice that the plane has become a real bear to pull out of
the hangar, and that our take-off roll has become noticeably longer. Sure
enough, the tires will be down around 25%, from 40 to 30 lbs on the mains,
and from 30 to 23 lbs (or so) in the nosewheel.
This seems ridiculous. Is it a product of tubed tires, or do I have slow
leaks that should be fixed? Can you use "Fix-a-Flat" in aircraft tires?
(I'll bet not.)
How often do you guys have to fill your tires?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 26th 05, 12:35 AM
Oracle
Kent Felkins
(I'll bet not.)
Use lots of caution when using Fix-a-Flat. By design, the product is
suppose to ONLY get you to a shop to get your tire repaired or replaced.
Fix-a-Flat is VERY bad about putting tires out of balance. Their formula
is also known to steadily destroy the rubber in which it remains in
contact. I understand they have a newer formula out, which is said not to
eat rubber, but the patch does not last anywhere near as long. Any any
rate, Fix-a-flat, reguardless of the formula should never be thought of as
anything other than a short-term fix.
Long story short...use Fix-a-flat if you are stuck and have no other
option. Otherwise, get the tire fixed or replaced before you need to use
it.
Greg
Old August 26th 05, 09:58 PM
NVArt
I have small pant doors, too. Center the valve stem in the door opening
and yellow-chalk a line vertically from pant to floor on the tire. That
makes it a one man job to locate the stem in the door opening. I use
one of those small "picks" with a handle to bend the stem a little so I
can do the inflation.
Blue Skies
5217D HTH
Old August 28th 05, 02:49 AM
pbc76049
Buy a jug of "Tire Slime"
at Walmart. Stops leakdown of
all the tires I own...
Old August 28th 05, 03:07 AM
George Patterson
pbc76049 wrote:
Buy a jug of "Tire Slime" at Walmart.
Anything like that is illegal in aircraft tires, according to one A&P I asked.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 28th 05, 04:24 AM
Fly
i used some in my lawn tractor tires.
couple years later I put new tires on. It was tough because the wheels were
so rusty
"pbc76049" wrote in message
Old August 30th 05, 04:24 AM
pbc76049
"George Patterson" wrote in message
news:a%8Qe.1268$Re1.1008@trndny04...
asked.
Well George, it just go's to show you how many A&P's have different opinions
of what the reg's say.
This isn't a prohibited act in AC43, it falls into the same category as
strut leak stopper, Marvel Oil,
ZDP, Mouse Milk, Automotive Greases, LPS3, and a whole world of other
chemicals which are
not specifically prohibited. Your mileage may vary.........
pbc76049
Flat Tires? Jay Honeck Owning 40 August 31st 05 01:59 AM
Sources for retread tires?? Jim Burns Aviation Marketplace 15 November 24th 04 03:48 AM
WTB: Good Set 500 x 5 Wheels, Tires and Brakes Steve Sharp Owning 0 March 20th 04 04:48 AM
WTB: Good Set 500 x 5 Wheels, Tires and Brakes Steve Sharp Restoration 0 March 20th 04 04:48 AM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
