Firewall Insulation Material??
Old November 9th 06, 09:43 PM posted to rec.aviation.homebuilt
Default Firewall Insulation Material??
DonMorrisey wrote:
Hey Everyone. I am looking for a good quality insulating material for
my firewall. I am interested in something that will effectively block
sound and heat. I've looked at what Spruce and Wicks has available but
I'm wondering what some other builders may have used that has worked
well and is relatively easy to install. All comments and leads
appreciated, especially anyone that has flown their application and is
happy with the result.
I guess I need to insulate the rest of the airplane too, so any
comments on that are welcome as well.
Thanks. Don...
While I haven't used it on an aircraft, my mechanic used a thin foil
insulation material on my car after I experimented with how well it
would float. (It didn't).
After the interior was all out and treated, he told me this stuff he
got at the hardware store was better than the original foam matting. It
was about 1/4" thick with foil on both sides and a sort of bubble tape
center section. It came prepared with adhesive on one side so you could
peel-and-stick. He got it at home depot or lowes or something. He was
right, it works, and it was cheap. Not sure what it was, but you might
just buy a bit of it at the store and hold it over a candle to see if
it fits the bill.
-Matt
Old November 10th 06, 04:11 PM posted to rec.aviation.homebuilt
Kyle Boatright
What adhesive did you use on this material?
I used a 3m spray adhesive to attach some PVC foam insulation to the
firewall of my RV-6 and have had problem after problem with the adhesive
releasing. I believe it is heat related.
KB
Thanks. Don...
it fits the bill.
-Matt
Old November 10th 06, 10:36 PM posted to rec.aviation.homebuilt
Bob Kuykendall
Earlier, Kyle Boatright wrote:
I used a 3m spray adhesive to attach some PVC foam insulation...
I have a couple hundred pounds of PVC foam sheet at the shop, but I
don't think I'd use it for firewall insulation. When burned, PVC
releases toxic hydrogen chloride gas. I think I'd prefer to use a more
inert and fire-resistant insulator at a firewall.
Thanks, Bob K.
Old November 10th 06, 11:36 PM posted to rec.aviation.homebuilt
Kyle Boatright
"Bob Kuykendall" wrote in message
Thanks, Bob K.
Aah, but all PVC ain't the same...
My employer used to manufacture a huge line of floorcovering products which
used PVC as a major ingredient. With the right additive package in the PVC,
it passed every flame and smoke test required to be installed in
residential, commercial, or even healthcare property.
I'm sure purpose built PVC insulation sold through major aviation suppliers
uses the same additives.
KB
Airplane insulation Andreas Warberg Piloting 6 April 26th 06 07:45 PM
18 Oct 2005 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 19th 05 02:19 AM
Firewall Insulation Marv Hamm Home Built 2 August 31st 04 02:14 AM
Firewall Insulation Kyle Boatright Home Built 1 August 27th 04 01:11 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
