--------- KB wrote:
The insulation on the firewall of my RV-6 is coming loose. Originally, I used 3M spray adhesive and aluminum tape to hold the stuff in place, but the insulation has come loose and repair efforts (more tape) have not held up. My guess is that heat simply causes the glue and or tape to release. Any better suggestions for attaching a flexible foam type material to a stainless steel firewall? ---------------------------------------------------------------------------- I have not used the following 3M tapes.....but they have high temp tapes available with details at the following links---long links...you may need to cut & paste them: 3M metal foil tapes brochu http://multimedia.mmm.com/mws/mediaw...6gIwCmtLUD o- ------------------------------------------------------ 3M 363 aluminum glass tape(highest temp): http://multimedia.mmm.com/mws/mediaw...eosnQ9GZHH l- ------------------------------------------------------ 3M 361 glass cloth tape: http://multimedia.mmm.com/mws/mediaw...fTY5RAH&hb T- ------------------------------------------------------ 3M 3633 heat management tape: http://multimedia.mmm.com/mws/mediaw...DNrm5zF824 R- |
I noticed that my suggested 3M links don't work. 3M makes you go
into their website and then work your way to the specialty tapes. I did see that on eBay you can buy a roll of 3M High Temperature Aluminum Foil Tape 433 2 in x 60 yd "Buy it now" priced at $81.99 per roll. ( That seems like a very high price but I think that normal retail is almost $150 per roll. This may be overkill but it looks like it might do the job for you. ) 021200-04800 (Sold by the roll) Shiny Silver, 3.6 mil (0.09 mm) aluminum foil backing with silicone adhesive. Used in many high temperature applications. Good holding, splicing, patching or general protection tape on many applications involving high temperatures. http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V -------------------------------------- For more info and a "pdf" sheet go to 3M's website at: http://www.3m.com/index.jhtml and search: 021200-04800 |
If you're doing a firewall, I have Carborundum-Fiberfrax-1\2" thick X 8" wide
dense blanket insulation---2000deg---Holler if you would like details, picture. sold several rolls to people here on RAH.. Jerry-- Marv Hamm wrote: I noticed that my suggested 3M links don't work. 3M makes you go into their website and then work your way to the specialty tapes. I did see that on eBay you can buy a roll of 3M High Temperature Aluminum Foil Tape 433 2 in x 60 yd "Buy it now" priced at $81.99 per roll. ( That seems like a very high price but I think that normal retail is almost $150 per roll. This may be overkill but it looks like it might do the job for you. ) 021200-04800 (Sold by the roll) Shiny Silver, 3.6 mil (0.09 mm) aluminum foil backing with silicone adhesive. Used in many high temperature applications. Good holding, splicing, patching or general protection tape on many applications involving high temperatures. http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V -------------------------------------- For more info and a "pdf" sheet go to 3M's website at: http://www.3m.com/index.jhtml and search: 021200-04800 |
| Thread Tools | |
| Display Modes | |
| Firewall Insulation | Kyle Boatright | Home Built | 1 | August 27th 04 02:11 AM |
| Firewall | Flyhighdave | Home Built | 18 | February 20th 04 02:41 PM |
| F.S. Fiberfrax Insulation | Jerry Wass | Home Built | 0 | October 6th 03 01:23 AM |
| F.S.Fiberfrax Insulation | Jerry Wass | Home Built | 0 | October 2nd 03 07:46 PM |
| blue foam, pink foam, yellow foam? | Corrie | Home Built | 26 | September 1st 03 06:01 PM |
