horiz tail airfoil observations
Old November 14th 06, 04:26 PM posted to rec.aviation.soaring
Brad
Default horiz tail airfoil observations
I've been perusing Fred Thomas's Sailplane Design book lately. I am
curious, why do most of the modern sailplanes use a non-symetrical
airfoil for the horiz surface, and most of the "older" sailplanes use a
symetrical airfoil?
I was looking at a Krokus at the Pensacola airshow over the weekend,
made in the 80's, it is definately using somthing like the Wortman
71-150/30 while my glider, and Apis uses an airfoil that is not
symetrical.
Cheers,
Brad
Old November 14th 06, 08:02 PM posted to rec.aviation.soaring
Jack[_4_]
With a lifting tail, the center of gravity can be moved aft for normal
flight regimes.
Jack Womack
Old November 14th 06, 08:36 PM posted to rec.aviation.soaring
noel.wade
I'm curious, though - with a lifting (i.e. positively-cambered) tail,
how do you avoid serious drag penalties and/or airflow disruption when
deflecting the elevator upwards enough to induce negative Cl (...in
other words, to have enough pitch-up control authority)? Everything
I've read points towards needing a roughly balanced Cl range for
adequate control authority in both pitch directions... I'm curious,
but a little confused...
Thanks! Take care,
--Noel
flight regimes.
Jack Womack
Old November 14th 06, 09:27 PM posted to rec.aviation.soaring
Francisco De Almeida
Modern gliders are designed so that the tailplane produces a moderate =
amount of lift in slow flight.
In steady flight, the tailplane lift coefficient may range from, say =
+0.2 for thermalling to -0.15 at VNE.
This leaves enough margin for transients, and definitely favours an =
airfoil with positive camber.
Old November 14th 06, 10:10 PM posted to rec.aviation.soaring
Eric Greenwell
symetrical airfoil?
symetrical.
Is the fixed portion symmetrical but with a control surface that has a
slight undercamber on the bottom? That's what my ASH 26 elevator is
like, and I believe that is normal.
If the fixed portion is not symmetrical, is the flatter part on the top
or bottom?
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
Old November 14th 06, 10:31 PM posted to rec.aviation.soaring
noel.wade
Ok, let me put on my "total newbie" outfit here...
Thinking in terms of real-world situations: In slow flight I'm sitting
in my glider, holding the stick back and keeping the angle of attack
high. I'm pulling a large Cl out of my main wing. The stick-back
condition corresponds to an upward-deflection of the trailing edge of
the elevator. So am I not generating a negative Cl with the horizontal
tail in this condition? Also, my wing airfoil still shows a Cm of
about -0.09 at this high angle of attack. Its small, but definitely
negative - so I still have a nose-down pitching moment from the wing -
therefore don't I *need* that "negative lift" (i.e. downward force) on
the tail? (I guess this all assumes the CG is ahead of the wing's
center of pressure/center of lift - but isn't that usually the case?)
Thanks, take care,
--Noel
Old November 14th 06, 11:36 PM posted to rec.aviation.soaring
Udo
or bottom?
I know the ASW27 has a small camber (up side down airfoil)
the 26 would most likely have it too. The Elevator under camber acts
like a servo tap, the faster you go the more up elevator you get when
flying with you hands off the stick, even if the trim spring is all
the way forward. This is a safty feature.
Udo
Old November 15th 06, 12:15 AM posted to rec.aviation.soaring
Brad
or bottom?
the fixed portion is pretty much symetrical. the flatter part is on the
top surface
the upper part of the elevator is straight
the lower part of the elevator has a slight undercamber to it, like
what you normally see on the lower surface of a sailplane wing.
Old November 15th 06, 01:00 AM posted to rec.aviation.soaring
Eric Greenwell
or bottom?
top surface
This is consistent with the need to provide a down force, the usual case
for our gliders, so the airfoil is "upside down" compared to the wing.
As Udo pointed out, this is how the designer meets the requirement for
increasing "up elevator" force as speed increases. While this has a
safety advantage, the truly determined performance oriented pilot will
sometimes remove the undercamber to reduce drag. I've never wanted to do
it, because I want the safety advantage and I'm concerned the weight of
filler material might make the elevator flutter. It would take some
paperwork to make it legal, too.
Old November 15th 06, 01:14 AM posted to rec.aviation.soaring
Karl Striedieck
At a crazier age I tried eliminating all the undercamber in my ASW-25
elevator. This affected the pitch stability so drastically that when the
stick was released the only unknown was whether the impending loop would be
inside or outside! As pointed out, the under camber is there for pitch
stability and with passing decades the German airworthiness authority has
increased the forces. A Janus has lower pitch trim forces than a Duo Discus
for instance.
"Eric Greenwell" wrote in message
news:eFt6h.4796$T_.3143@trndny06...
or bottom?
top surface
increasing "up elevator" force as speed increases. While this has a safety
advantage, the truly determined performance oriented pilot will sometimes
remove the undercamber to reduce drag. I've never wanted to do it, because
I want the safety advantage and I'm concerned the weight of filler
material might make the elevator flutter. It would take some paperwork to
make it legal, too.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 07:18 PM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
