Hint, unless a homebuilt, all parts must be approved parts.
Is this really true? I cannot mount an unapproved CD player someplace so that it won't flop around in flight? Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
My Husky had a really nice minimal IFR panel. A KX155 Nav/Com, a King
KLN90B (with its own seperate CDI), and a Century I autopilot that was all electric and worked off the turn and bank. Loose the electric and you still have the DG and AI. Loose the vacuum and you still have the autopilot and the turn coordinator AND the GPS (which can work as a DG, sort of). Top that all off with a handheld radio (with its own antenna) and a handheld GPS (with it's own permanently mounted outside antennae) and its pretty damn backed up. |
Just a little story about flying with failed instruments.
I was flying with an instrument student, and had been telling him the importance of the gyroscopic instruments to maintaining control of the airplane in the clouds. So I covered up one gyro, he kept flying along fine. He was under the hood, we were flying mostly straight and level, maybe some simple level turns, don't remember all the details now. Then I covered up the second gyro. He kept flying along fine. So I covered the third gyro, expecting him to soon wind up in a spiral dive. He kept flying along fine. So finally I asked him how he was doing it. I had forgotten about the GPS. He was watching the TRK number on the GPS, and that was giving him essentially the same data as the DG, although with a slower update rate. Along with the pressure instruments, he was doing just fine. "Kelly" wrote in message ups.com... I would be interested in getting opinions about backup systems for a vacuum pump failure and/or AI failure. I have a 172P with a single vacuum pump system, standard instruments otherwise, and a Garmin 430. I am most concerned about having a good backup if I lose a vacuum pump or AI in IMC. I have been thinking about either a Garmin 396/496 or the electric AI available from Sporty's. Looks like I could get a 396 or installed electric AI for about the same price ($2200 or so). While I haven't seen the panel page/"6-pack" page on the 396 or 496, I have read (in Aviation Consumer) that it's good enough to keep control of the airplane in an emergency situation. Obviously, the 396/496 has a number of other neat features such as inflight weather, terrain info, etc. Any suggestions on which way to go with this. BTW, I had also considered the Precise Flight backup vacuum system for a while, and it certainly is cheaper (around $700 installed). However, I was concerned by the fact that it would do nothing for you in the event of failure of the AI vs. the primary vacuum pump. Thanks. Kelly |
yes
"Jose" wrote in message m... | Hint, unless a homebuilt, all parts must be approved parts. | | Is this really true? I cannot mount an unapproved CD player someplace | so that it won't flop around in flight? | | Jose | -- | "Never trust anything that can think for itself, if you can't see where | it keeps its brain." (chapter 10 of book 3 - Harry Potter). | for Email, make the obvious change in the address. |
Thanks for all the helpful comments so far. In thinking about what you
all have said, with my current setup (and yes I am an owner), I would realistically have a DG with either a vacuum pump failure or AI failure. In the case of a vacuum pump failure, I could still get current ground track from the 430. And, obviously with the AI failure alone, I would still have the DG. While I don't do a lot of flying in actual IMC, I do enough that I'm willling to spend some extra money to hopefully prevent a major problem in the event of vacuum pump failure. I don't know about the rest of you, but if I encounter a situation where I end up flying partial panel, I plan to get in VMC ASAP, or if I can't do that, land. I haven't yet flown with any of the Garmin handhelds, but my guess (and I could certainly be off on this) is that would be harder to use the panel page on the handheld as a backup versus having a backup electric AI and thus the traditional instrument panel gauges and layout that I trained on. The electric AI from Sporty's also has the ball inclinometer built into it and can replace the turn coordinator. So, if anyone else wants to weigh in on best bang for the buck backup, here again are the options in contention: 1. Engine driven backup vacuum (such as Precise Flight) 2. Electric AI 3. Garmin 396/496 4. $2 failed-instrument covers (I need these anyway, but I had to throw this in as an option). Thanks again. Kelly |
player someplace so that it won't flop around in flight? yes Actually, I spoke to our FSDO not too lona ago with this very question, and the answer came back that it is legal to do so. The =installation= needs to be approved (the installer can self-approve) but the device being installed need not be an approved device, so long as it is not powered directly by the aircraft system (cigarette lighter power is ok). They are concerned that the installation not interfere with flight controls and such. They are concerned that a non-approved device not take the place of an approved instrument, but according to my FSDO, once I explaned all we wanted to do (install an electric backup AI), they were ok with it. YMMV Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
throw this in as an option). 5: MSFS and practice. ![]() Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Kelly wrote:
I would be interested in getting opinions about backup systems for a vacuum pump failure and/or AI failure. ..stuff snipped Looks like I could get a 396 or installed electric AI for about the same price ($2200 or so). While I haven't seen the panel page/"6-pack" page on the 396 or 496, I have read (in Aviation Consumer) that it's good enough to keep control of the airplane in an emergency situation. Obviously, the 396/496 has a number of other neat features such as inflight weather, terrain info, etc. Funny you should ask. I covered up my AI and DG and tried flying via the panel page on my 396. Downright freaky. I figured the lag would not be too bad but it really does present a challenge. I suppose with practice it might do. But in bumpy IMC I might be chasing the TC and altimeter indications all over the place. The 496 has a faster refresh that may make this less of an issue. On the other hand, the lag might keep me from overworking the controls as I often do in IMC on a bumpy day. You won't correct for every little deviation because the unit won't update that fast. I like the idea of that little box that had solid state gyros in it and you would velcro to the floor and hook up to a PDA. Instant electric gyros without the gyro wear and tear. If only you could USB the signal into the 396... Good Luck, Mike |
![]() Is this really true? I cannot mount an unapproved CD player someplace so that it won't flop around in flight? yes Not true in the slightest. You want to velcro your CD player to the top of the glareshield or maybe to the floor have at it. I have my satellite radio attached to the far left side of the panel with that two sided 3M sticky tape they give you with the radio. That stuff is better than screws because when I want to remove it you'll never know it was there and if you've worked with that tape before you know how solid it is. I run the power, antenna and audio out cables under the glareshield and then out to where they need to go. |
I've been struggling with the same issue. I have a 396 but not a 430. I
also want more utility out of my airplane. I finally said screw it..... I ordered the electric backup attitude indicator from Sporty's. $1,871.45 with the AOPA discount. All of the other options are not really usable. This way I have two indicators inches apart that require no switching, batteries, cables, etc.... "Kelly" wrote in message ups.com... I would be interested in getting opinions about backup systems for a vacuum pump failure and/or AI failure. I have a 172P with a single vacuum pump system, standard instruments otherwise, and a Garmin 430. I am most concerned about having a good backup if I lose a vacuum pump or AI in IMC. I have been thinking about either a Garmin 396/496 or the electric AI available from Sporty's. Looks like I could get a 396 or installed electric AI for about the same price ($2200 or so). While I haven't seen the panel page/"6-pack" page on the 396 or 496, I have read (in Aviation Consumer) that it's good enough to keep control of the airplane in an emergency situation. Obviously, the 396/496 has a number of other neat features such as inflight weather, terrain info, etc. Any suggestions on which way to go with this. BTW, I had also considered the Precise Flight backup vacuum system for a while, and it certainly is cheaper (around $700 installed). However, I was concerned by the fact that it would do nothing for you in the event of failure of the AI vs. the primary vacuum pump. Thanks. Kelly |
backup for vacuum pump/attitude indicator failure | Kelly | Owning | 27 | November 29th 06 06:58 AM |
Backup Flight Data Recorder? | Fox Two | Soaring | 14 | August 27th 06 09:42 AM |
Fllight Recorder Wars, Part II: What Backup to Use? | Chip Bearden | Soaring | 13 | March 31st 04 10:10 PM |
Good AI backup, wish me luck | Robert M. Gary | Instrument Flight Rules | 29 | March 1st 04 05:36 PM |
Solid State Backup AI | Dan Truesdell | Instrument Flight Rules | 20 | January 15th 04 09:53 PM |
